TAU-3019,04-A
TAU-3019,04-A
    INDUSTRIFIL
    4 芯 多芯 线缆 白色 30 AWG 编织线 100.0'(30.5m)
TAU-3019,04-A 数据手册
FICHE TECHNIQUE / TECHNICAL DATA SHEET CABLES - TAU - (AWG26 - AWG30) CABLES TAU BLINDES MINIATURE ISOLATION ET GAINE EN FLUOROPOLYMERE (PFA) MINIATURE TAU SHIELDED CABLES SILVER PLATED CONDUCTORS & BRAID FLUOROPOLYMER (PFA) INSULATION & SHEATH COMPOSITION / COMPOSITION 1 - Toron de cuivre recuit argenté / Silvered copper stranded conductor 2 - Isolant en PFA (Couleurs selon commande) / PFA insulation (colors on request) 2 x Cds : Blanc, Rouge / White, Red 3 x Cds : Blanc, Noir, Rouge / White, Black, Red 3 x Paires : Blanc+Rouge, Noir+Vert, Bleu+Jaune / White+Red, Black+Green, Blue+Yellow 4 x Cds : Blanc, Rouge, Noir, Vert / White, Red, Black, Green 4 x Paires : Bc+R, N+V, Bleu+Jaune, Violet+Gris / W+R, Bk+Gn, Blue+Yellow, Purple+Grey 5 x Cds : Blanc, Rouge, Noir, Vert, Jaune / White, Red, Black, Green, Yellow 5 x Paires : Bc+R, N+V, B+J, Vi+G, Marron+Orange / W+R, Bk+Gn, B+Y, Pu+G, Brown+Orange 6 x Cds : Blanc, Rouge, Noir, Vert, Bleu, Jaune / White, Red, Black, Green, Blue, Yellow 6 x Paires : Bc+R, N+V, B+J, Vi+G, M+O, Rose+Naturel / W+R, Bk+Gn, B+Y, Pu+G, Br+O, Pink+Natural 3 7 x Cds : Blanc, Rouge, Noir, Vert, Bleu, Jaune, Violet / White, Red, Black, Green, Blue, Yellow, Purple 8 x Cds : Blanc, Rouge, Noir, Vert, Bleu, Jaune, Violet, Gris / White, Red, Black, Green, Blue, Yellow, Purple, Grey 10 x Cds : Bc, R, N, V, B, J, Violet, Gris, Marron, Orange / W, R, Bk, Gn, B, Y, Purple, Grey, Brown, Orange 12 x Cds : Bc, R, N, V, B, J, V, G, Marron, Orange, Rose, Naturel / W, R, Bk, Gn, B, Y, P, Gy, Brown, Orange, Pink, Natural - Blindage tresse en cuivre argenté / Silvered copper braid shielding AWG 44 (0,05 mm) & ≥ 85 % Ø des brins et surface couverte / Wire diameter & Percent coverage : 4 - Gaine PFA (Cod. W = Blanc, Bk = Noir) / PFA sheath (Cod. W = White, Bk = Black) DIMENSIONS / DIMENSIONS Désignation Designation Nbre de Cond. Qty of Cds Jauge (AWG) Gauge (AWG) Construction des Conducteurs Conductors construction Résistance (Ω/m) Resistance (Ω/m) TAU-3019.01-* 1 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 1,05/0,041 ±7% ≃ 2,59 TAU-3019.02-* 2 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 1,6/0,063 ±7% ≃ 4,84 TAU-3019.03-* 3 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 1,69/0,067 ±7% ≃ 5,96 TAU-3019.04-* 4 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 1,83/0,072 ±7% ≃ 7,21 TAU-3019.05-* 5 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 1,99/0,078 ±7% ≃ 8,50 TAU-3019.06-* 6 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 2,17/0,085 ±7% ≃ 9,94 NF C 32-070 C1 NF C 32-070 C2 Ind.2 -196 +200°C par Rémi de Foucaud WATER RESISTANT OIL RESISTANT UV RESISTANT le 04/02/2022 Ø Isolant (mm/inch) Insulation Ø (mm/inch) FLEXIBLE 1/3 Ø Extérieur (mm/inch) Outer Ø (mm/inch) Poids câble (kg/km) Cable weith (kg/km) Ce document est la propriété exclusive de INDUSTRIFIL et ne peut pas être utilisé ou divulgué sans son accord / This document is the exclusive property of INDUSTRIFIL and may neither be used nor disclosed without its agreement CONDUCTEURS ET TRESSE EN CUIVRE ARGENTE FICHE TECHNIQUE / TECHNICAL DATA SHEET CABLES - TAU - (AWG26 - AWG30) Désignation Designation Nbre de Cond. Qty of Cds Jauge (AWG) Gauge (AWG) Construction des Conducteurs Conductors construction Résistance (Ω/m) Resistance (Ω/m) Ø Isolant (mm/inch) Insulation Ø (mm/inch) Ø Extérieur (mm/inch) Outer Ø (mm/inch) Poids câble (kg/km) Cable weith (kg/km) TAU-3019.3x2-* 6 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 2,41/0,095 ±7% ≃ 10,54 TAU-3019.07-* 7 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 2,17/0,085 ±7% ≃ 10,84 TAU-3019.08-* 8 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 2,35/0,093 ±7% ≃ 12,20 TAU-3019.4x2-* 8 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 2,64/0,104 ±7% ≃ 12,92 TAU-3019.10-* 10 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 2,75/0,108 ±7% ≃ 15,21 TAU-3019.5x2-* 10 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 2,94/0,116 ±7% ≃ 15,70 TAU-3019.12-* 12 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 2,84/0,112 ±7% ≃ 17,25 TAU-3019.6x2-* 12 30 19x42 AWG ≤ 0,36 0,55/0,022 ±7% 3,19/0,126 ±7% ≃ 18,16 TAU-2819.01-* 1 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 1,15/0,045 ±7% ≃ 3,27 TAU-2819.02-* 2 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 1,8/0,071 ±7% ≃ 6,20 TAU-2819.03-* 3 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 1,9/0,075 ±7% ≃ 7,79 TAU-2819.04-* 4 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 2,07/0,081 ±7% ≃ 9,55 TAU-2819.05-* 5 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 2,26/0,089 ±7% ≃ 11,36 TAU-2819.06-* 6 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 2,47/0,097 ±7% ≃ 13,33 TAU-2819.3x2-* 6 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 2,76/0,109 ±7% ≃ 14,06 TAU-2819.07-* 7 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 2,47/0,097 ±7% ≃ 14,68 TAU-2819.08-* 8 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 2,68/0,106 ±7% ≃ 16,55 TAU-2819.4x2-* 8 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 3,03/0,119 ±7% ≃ 17,43 TAU-2819.10-* 10 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 3,15/0,124 ±7% ≃ 20,65 TAU-2819.5x2-* 10 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 3,38/0,133 ±7% ≃ 21,25 TAU-2819.12-* 12 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 3,25/0,128 ±7% ≃ 23,61 TAU-2819.6x2-* 12 28 19x40 AWG ≤ 0,20 0,65/0,026 ±7% 3,67/0,144 ±7% ≃ 24,70 TAU-2619.01-* 1 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% TAU-2619.02-* 2 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 2,02/0,08 ±7% ≃ 7,98 TAU-2619.03-* 3 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 2,14/0,084 ±7% ≃ 10,24 TAU-2619.04-* 4 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 2,33/0,092 ±7% ≃ 12,67 TAU-2619.05-* 5 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 2,56/0,101 ±7% ≃ 15,20 2,8/0,11 ±7% 1,26/0,05 ±7% ≃ 4,16 TAU-2619.06-* 6 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% TAU-2619.3x2-* 6 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 3,13/0,123 ±7% ≃ 18,71 ≃ 17,89 TAU-2619.07-* 7 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 2,8/0,11 ±7% ≃ 19,85 TAU-2619.08-* 8 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 3,05/0,12 ±7% TAU-2619.4x2-* 8 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 3,45/0,136 ±7% ≃ 22,44 ≃ 23,45 TAU-2619.10-* 10 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 3,59/0,141 ±7% ≃ 28,01 TAU-2619.5x2-* 10 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 3,86/0,152 ±7% ≃ 28,71 TAU-2619.12-* 12 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 3,71/0,146 ±7% ≃ 32,26 TAU-2619.6x2-* 12 26 19x38 AWG ≤ 0,13 0,76/0,03 ±7% 4,2/0,165 ±7% ≃ 33,53 * : Code couleur / Color code NF C 32-070 C1 Ind.2 NF C 32-070 C2 -196 +200°C par Rémi de Foucaud WATER RESISTANT OIL RESISTANT UV RESISTANT le 04/02/2022 FLEXIBLE 2/3 Ce document est la propriété exclusive de INDUSTRIFIL et ne peut pas être utilisé ou divulgué sans son accord / This document is the exclusive property of INDUSTRIFIL and may neither be used nor disclosed without its agreement DIMENSIONS / DIMENSIONS FICHE TECHNIQUE / TECHNICAL DATA SHEET CABLES - TAU - (AWG26 - AWG30) Tension de service : 600 V Résistance d'isolement / Insulation resistance : ≥ 1000 MΩ.km (à/at 20°C) Rigidité diélectrique cd./extérieur / Dielectric strength : 1500 V (CC/DC 1min) Non propagation de la flamme / Flame retardancy : NF C 32-070 C2 (IEC 60332-1) Non propagation de l'incendie / Fire retardancy : NF C 32-070 C1 (IEC 60332-3) Température de service / Service temperature : -196 +200 °C Environnement / Environmental : ROHS + REACH Conditionnement selon commande / Packaging according to the order NF C 32-070 C1 Ind.2 NF C 32-070 C2 -196 +200°C par Rémi de Foucaud WATER RESISTANT OIL RESISTANT UV RESISTANT le 04/02/2022 FLEXIBLE 3/3 Ce document est la propriété exclusive de INDUSTRIFIL et ne peut pas être utilisé ou divulgué sans son accord / This document is the exclusive property of INDUSTRIFIL and may neither be used nor disclosed without its agreement CARACTERISTIQUES / CHARACTERISTICS
TAU-3019,04-A 价格&库存
很抱歉,暂时无法提供与“TAU-3019,04-A”相匹配的价格&库存,您可以联系我们找货
