DESDC-B56S06GW1SL
DESDC-B56S06GW1SL
    INNODISK(宜鼎)
    存储卡 SD™ 256GB TLC
DESDC-B56S06GW1SL 数据手册
Datasheet Industrial SD Card 3TE4 - SD 3.0 interface - High performance - Power fail Management - LDPC ECC algorithm implement Introduction Innodisk 3TE4 is an industrial-grade SD card solution with an integrated industrial controller, which is designed for embedded applications. With enhanced flash technologies and a powerful configurable LDPC ECC engine, SD 3TE4 can achieve high-speed data transfer rates. Innodisk industrial SD 3TE4 provides a wide range of capacities from 32GB to 256GB with TLC NAND Flash, and is fully compliant with SD3.0 and SD2.0 specifications. Innodisk industrial SD 3TE4 are specifically designed for industrial PC and embedded applications for high performance. With its low power consumption and the above mentioned features, Innodisk industrial SD 3TE4 can be applied for industrial automation, SBC (single-board computer), medical equipment, infotainment, and mobile applications. www.innodisk.com Industrial SD Card 3TE4 Contact us for more information about the Industrial SD Card 3TE4. Diagram Innodisk is a service-driven provider of industrial embedded flash storage products and technologies, with a focus on the cloud computing, industrial/embedded, and aerospace and defense industries. Headquarters (Taiwan) 5F., No. 237, Sec. 1, Datong Rd., Xizhi Dist., New Taipei City 221, Taiwan Tel: +886-2-77033000 Email: sales@innodisk.com Branch Offices: USA usasales@innodisk.com +1-510-770-9421 Europe eusales@innodisk.com +31-40-3045-400 Japan jpsales@innodisk.com +81-3-6667-0161 China sales_cn@innodisk.com +86-755-21673689 www.innodisk.com © 2021 Innodisk Corporation. All right reserved. Specifications are subject to change without prior notice. Specifications Interface Flash Type Capacity Max. Channels Sequential R/W (MB/sec, max.) Max. Power Consumption TLC 32GB~256GB 1 90/80 0.47W (3.3V x 145mA ) Thermal Sensor - Extended DRAM buffer - H/W Write Protect √ ATA Security - S.M.A.R.T. - Dimension (WxLxH) 20210211 SD 3.0 24 X 32.0 X 2.1 mm Vibration: 20G @7~2000Hz Shock: 1500G @ 0.5ms Environment Storage Temperature: -55°C ~ +95°C MTBF: 3 million hours Endurance:3,000 P/E cycles Ordering Information Operation Temp. Extend Grade (-25°C ~ +85°C) Industrial Grade (-40°C ~ +85°C) 32GB 64GB 128GB 256GB DESDC32GS06EE1SL DESDC64GS06GE1SL DESDCA28S06GE1SL DESDCB56S06GE1SL DESDC32GS06EW1SL DESDC64GS06GW1SL DESDCA28S06GW1SL DESDCB56S06GW1SL www.innodisk.com
DESDC-B56S06GW1SL 价格&库存
很抱歉,暂时无法提供与“DESDC-B56S06GW1SL”相匹配的价格&库存,您可以联系我们找货
