DEM28-A28DD1GWADF
DEM28-A28DD1GWADF
    INNODISK(宜鼎)
    固态硬盘(SSD) FLASH - NAND(TLC) 128GB NVMe M.2 模块
DEM28-A28DD1GWADF 数据手册
Datasheet M.2 (P42) 3TE6 series - PCIe Gen. III x4, NVMe 1.3 DRAM-less Solution Less Controller Heat Anti-Vibration mechanical design Hybrid Write Mode LDPC ECC engine supported. iPowerGuard Protection Introduction Innodisk M.2 (P42) 3TE6 is a NVM Express DRAM-less SSD designed with PCIe interface and industrial 3D TLC NAND Flash. M.2 (P42) 3TE6 supports PCIe Gen III x 4 and it is compliant with NVMe 1.3 providing excellent top and also outstanding sustained performance. With sophisticated error detection and correction (ECC) functions, the module can ensure full End-to-End data path protection that secures the data transmission between host system and NAND Flash. In addition, with a customized embedded AES-256 bit engine, your data can be further secured. www.innodisk.com M.2 (P42) 3TE6 series Diagram Contact us for more information about the M2 (P42) 3TE6. Innodisk is a service-driven provider of industrial embedded flash and DRAM storage products and technologies, with a focus on the cloud computing, industrial/embedded, and aerospace and defense industries. Headquarters (Taiwan) 5F., No. 237, Sec. 1, Datong Rd., Xizhi Dist., New Taipei City 221, Taiwan Tel: +886-2-7703-3000 Email: sales@innodisk.com Branch Offices: USA usasales@innodisk.com +1-510-770-9421 Europe eusales@innodisk.com +31-40-3045-400 Japan jpsales@innodisk.com +81-3-6667-0161 China sales_cn@innodisk.com +86-755-21673689 www.innodisk.com Interface Flash Type 3D TLC P/E cycle 3,000 Capacity 64GB~1TB Max. Channels Sequential R/W (MB/s, Max) Sustained Sequential Write (MB/s, Max) Max. Power Consumption (RMS) Thermal Sensor © 2020 Innodisk Corporation. All right reserved. Specifications are subject to change without prior notice. PCIe Gen. III x4 4 2,000/1,850 650 3.5W √ External DRAM buffer NA H/W Write Protect NA iCell NA 22.0 X 42.0 X 1.35 mm (Top side without Heat-Dissipating Copper Foil ) Dimension (WxLxH) 22.0 X 42.0 X 1.95 mm (Top side with Heat-Dissipating Copper Foil. Default setting for Industrial Grade PNs.) Vibration: 20G @7~2000Hz Environment Shock: 1500G @ 0.5ms Working Temperature: -40°C ~ +85°C MTBF: 3 million hours Ordering Information Operation Temp. Standard Grade (0°C ~ +70°C) Industrial Grade (-40°C ~ +85°C) 64GB 128GB 256GB 512GB 1TB* DEM24-64GDD1ECADF DEM24-A28DD1%CA&F DEM24-B56DD1%CAQF DEM24-C12DD1%CAQF DEM24-01TDD1%CAQF DEM24-64GDD1EWADF DEM24-A28DD1%WA&F DEM24-B56DD1%WAQF DEM24-C12DD1%WAQF DEM24-01TDD1%WAQF %. E: 64 layers 3D TLC; G: 96 layers 3D TLC; K: 112 layers 3D TLC &. D=2 channels; Q=4 channels *. 1TB only supported in 96 / 112 layers 3D TLC www.innodisk.com
DEM28-A28DD1GWADF 价格&库存
很抱歉,暂时无法提供与“DEM28-A28DD1GWADF”相匹配的价格&库存,您可以联系我们找货
