DESSL-A28DK1GCADFA
DESSL-A28DK1GCADFA
    INNODISK(宜鼎)
    固态硬盘(SSD) FLASH - NAND(TLC) 128GB SATA III 电子硬盘,SATA DOM
DESSL-A28DK1GCADFA 数据手册
Datasheet SATADOM-SL 3TE7 series - SATA III soultion for industrial field - Exclusive L3 architecture - DRAM-less, 100% data integrity - Excellent random performance - Designed with hardware LDPC ECC engine - Built-in Pin 8 power supply Introduction Innodisk SATADOM-SL 3TE7 is characterized by L3 architecture with the latest SATA III (6.0GHz) Marvell NAND controller. Innodisk’s exclusive L 3 architecture is L2 architecture multiplied LDPC (Low Density Parity Check). L 2 (Long Life) architecture is a 4K mapping algorithm that reduces WAF and features a real-time wear leveling algorithm to provide high performance and prolong lifespan with exceptional reliability. Innodisk SATADOM-SL 3TE7 is designed for industrial field, and supports several standard features, including TRIM, NCQ, and S.M.A.R.T. In addition, Innodisk’s exclusive industrial-oriented firmware provides a flexible customization service, making it perfect for a variety of industrial applications. The innovative Pin 8 uses the SATA connector itself as a power supply to drive the device without external cables. It could be connected directly to the SATA on-board socket on customer’s system without additional power cable. Besides, the booting time for operation and the power consumption is less than hard disk drive (HDD), and can work under harsh environment compile with ATA protocol, no additional drives are required, and the SSD can be configured as a boot device or data storage device. www.innodisk.com SATADOM-SL 3TE7 series Diagram Contact us for more information about the SATADOM-SL 3TE7. Innodisk is a service-driven provider of industrial embedded flash storage and Dram products and technologies, with a focus on the cloud computing, industrial/embedded, and aerospace and defense industries. Headquarters (Taiwan) 5F., No. 237, Sec. 1, Datong Rd., Xizhi Dist., New Taipei City, Taiwan (R.O.C.) Tel: +886-2-7703-3000 Email: sales@innodisk.com Specifications Branch Offices: USA usasales@innodisk.com +1-510-770-9421 Europe eusales@innodisk.com +31-40-3045-400 Japan jpsales@innodisk.com +81-3-6667-0161 China sales_cn@innodisk.com +86-755-21673689 www.innodisk.com Interface Flash Type Capacity Max. Channels Sequential R/W (MB/sec, max.) Max. Power Consumption Thermal Sensor © 2021 Innodisk Corporation. All right reserved. Specifications are subject to change without prior notice. SATA III 3D TLC 32GB~512GB 2 550/490 1.4W √ Extended DRAM buffer - H/W Write Protect - ATA Security √ S.M.A.R.T. √ Dimension (WxLxH) 33.06 x 29.6 x 10.5 mm Vibration: 20G @7~2000Hz Environment 20210712 Shock: 1500G @ 0.5ms Storage Temperature: -55°C ~ +95°C MTBF: 3 million hours Ordering Information 32GB Standard Grade (0°C ~ +70°C) Industrial Grade (-40°C ~ +85°C) 64GB 128GB 1CH 2CH 256GB 512GB DESSL32GDK1EC1SF* DESSL64GDK1EC1SF* DESSLA28DK1EC1SF* DESSLA28DK1**CADF* DESSLB56DK1**CADF* DESSLC12DK1GCADF* DESSL32GDK1EW1SF* DESSL64GDK1EW1SF * DESSLA28DK1EW1SF * DESSLA28DK1EWADF* DESSLB56DK1EWADF* N/A *=A-> Pin 8+ power cable / *=B-> Pin 8+ Pin 7 **=E-> 64 layers 3D Flash / **=G-> 96 layers 3D Flash www.innodisk.com
DESSL-A28DK1GCADFA 价格&库存
很抱歉,暂时无法提供与“DESSL-A28DK1GCADFA”相匹配的价格&库存,您可以联系我们找货
