80.00000062
80.00000062
    INNOSENT
    接近/占位传感器 雷达 模拟信号
80.00000062 数据手册
Innovation in Radar Technology Data Sheet IPM-165 designed and manufactured in Germany Version 8.5 - 02.04.2014 PRODUCT FAMILY Low Cost K-Band Transceiver APPLICATIONS • Security applications • Door openers • Industrial applications Movement Velocity Direction Presence Distance Angle FEATURES: »» radar-based motion detector working in the 24GHz - ISM - Band »» available in different frequency ranges for worldwide use »» advanced LCO-oscillator with low current consumption »» split transmit and receive path for maximum gain Certified and approved according to • ETSI EN 300 440 • FCC part 15.245 (UXS-IPM165) • IC RSS210 Issue 7 (6902A-IPM165) ADDITIONAL INFORMATION RoHS-INFO InnoSenT Standard Product. Changes will not be notified as long as there is no influence on form, fit and within this datasheet specified function of the product. This product is compliant to the restriction of hazardous substances (RoHS - European Union directive 2011/65/EU). CONFIDENTIAL AND PROPRIETARY The information contained in this document shall remain the sole and exclusive property of InnoSenT GmbH and shall not be disclosed by the recipient to third parties without prior consent of InnoSenT in writing. DATA SHEET IPM-165 InnoSenT GmbH has established and applies a quality system for: development, production and sales of radar sensors for industrial and automotive sensors. The IPM-165 is a 24GHz Doppler module with an asymmetrical wide beam for detection of moving objects. Low power consumption components are quickly enabled supporting duty cycles for battery or solar panel operation. CERTIFICATES Page 1 DESCRIPTION Version 8.5 »» very compact outline dimensions Innovation in Radar Technology ELECTRICAL CHARACTERISTICS PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNITS Oscillator transmit frequency1 @ 25°C fstandard 24.050 24.250 GHz US-frequency band @ 25°C fF 24.075 24.175 GHz UK-frequency band @ 25°C fUK 24.150 24.250 GHz 20 dBm output power Pout 16 temperature drift Δf -1 MHz/°C Receiver IF-output Signal level 2 Noise level2 voltage offset -300 300 mV category A 563 855 mVP-P category B 856 1177 mVP-P category C 1178 1819 mVP-P 116 mV R 4.75 5.00 5.25 V supply current ICC 18 30 40 mA TOP -20 +60 °C Tstorage -20 +60 °C Environment operating temperature storage temperature Mechanical Outlines outline dimensions length width height 25 25 7 (12.7) Details to the frequency bands you can find in Annex A 2 Relative output signal level and noise is measured at room temperature in a dedicated InnoSenT test setup CONFIDENTIAL AND PROPRIETARY The information contained in this document shall remain the sole and exclusive property of InnoSenT GmbH and shall not be disclosed by the recipient to third parties without prior consent of InnoSenT in writing. Page 2 1 mm Version 8.5 VCC DATA SHEET IPM-165 supply voltage Power supply Innovation in Radar Technology ANTENNA ORIENTATION: PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNITS TX-antenna pattern / RX-antenna pattern Tx antenna pattern (3dB width) side-lobe suppression squinting angle azimuth 80 ° vertical elevation 35 ° horizontal azimuth 12 dB vertical elevation 13 dB 0 ° 9.5 dBi CONFIDENTIAL AND PROPRIETARY The information contained in this document shall remain the sole and exclusive property of InnoSenT GmbH and shall not be disclosed by the recipient to third parties without prior consent of InnoSenT in writing. Page 3 Antenna gain horizontal DATA SHEET IPM-165 Version 8.5 normalized gain [dB] TX / RX-ANTENNA PATTERN: Innovation in Radar Technology INTERFACE The sensor provides a 2.54mm grid, single row pin header (square pin 0.635mm) PIN # DESCRIPTION IN / OUT COMMENT 1 VCC input supply voltage (4.75 - 5.25V) 2 IF1 output signal I(nphase) 3 GND input analog ground MECHANICAL OUTLINES 9.96 2.54 PIN 1 12.70 10.50 1.90 antenna PIN 1 6.60 +1.00 - 0.20 backside 25.00 +- 0.20 0.20 20.20 +- 0.20 0.20 all dimensions in mm 20.20 +- 0.20 0.20 25.00 +- 0.20 0.20 bottom view side view DATA SHEET IPM-165 top view Labeling IPM-165 B A0000000001 Type Category IPM-165UK A0000000001 Serial No. IPM-165_UK IPM-165_F CONFIDENTIAL AND PROPRIETARY The information contained in this document shall remain the sole and exclusive property of InnoSenT GmbH and shall not be disclosed by the recipient to third parties without prior consent of InnoSenT in writing. Page 4 IPM-165 Version 8.5 1.25 PIN 1 Innovation in Radar Technology Annex A The IPM-165 is available in different frequency ranges for worldwide use. Depending on the country in which the product is intended to be used, different frequency ranges can be ordered at InnoSenT. The information that will be given below is only a rough overview; for details please contact the local approval agencies. An overview over the frequency bands in Europe can also be found in the REC 70-03 (Annex 6) which is available under www.ero.dk Frequency Bands in Europe Generally the IPM-165 standard version can be used for all countries in Europe except for the UK. For the UK market you have to order the IPM-165_UK modules to be conform with the regulations of the UK-Approval-Agency. 24.000 24.050 24.250 24.150 UK-frequency Europe-frequency Frequency Bands in US 24.175 24.250 US-frequency InnoSenT has a limited modular approval for the IPM-165_F with the following grant: UXS1 FCC approval This device complies with Part 15 of the FCC Rules and with RSS-210 of Industry Canada. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. Warning: Changes or modifications made to this equipment not expressly approved by InnoSenT GmbH may void the FCC authorization to operate this equipment. CONFIDENTIAL AND PROPRIETARY The information contained in this document shall remain the sole and exclusive property of InnoSenT GmbH and shall not be disclosed by the recipient to third parties without prior consent of InnoSenT in writing. Page 5 Manufacturers of mobile or fixed devices incorporating IPM-165 modules are authorized to use the FCC Grants and IC Certificates of the IPM-165 modules for their own final products according to the conditions referenced in these documents. In this case, the FCC label of the module shall be visible from the outside, or the host device shall bear a second label stating „Contains FCC ID: UXS-IPM165F“ and „Contains IC: 6902A-IPM165“. Version 8.5 24.075 DATA SHEET IPM-165 24.000 For the US-market the IPM-165_F version has to be used! Innovation in Radar Technology ESD-INFORMATION This InnoSenT sensor is sensitive to damage from ESD. Normal precautions as usually applied to CMOS devices are sufficient when handling the device. Touching the signal output pins has to be avoided at any time before soldering or plugging the device into a motherboard. APPROVAL This Data Sheet contains the technical specifications of the described product. All previous versions of this Data Sheet are no longer valid. VERSION DATE COMMENT 8.2 06.03.2013 new layout 8.3 24.10.2013 FCC ID updated 8.4 06.12.2013 Max. output power added + Min. supply current added + modified format 8.5 02.04.2014 Antenna orientation + system pattern DATA SHEET IPM-165 Version 8.5 The sensor uses Hydrocarbon based material which may change its dielectric properties when used in an oxidative environment. This may vary based on temperature. Therefore InnoSenT recommends evaluating this influence within the specific environment. Tel.: +49 (0) 9528 - 9518 - 0 E-Mail: info@innosent.de URL: www.innosent.de Page 6 Am Rödertor 30 97499 Donnersdorf GERMANY InnoSenT GmbH
80.00000062 价格&库存
很抱歉,暂时无法提供与“80.00000062”相匹配的价格&库存,您可以联系我们找货
