8000000421
8000000421
    INNOSENT
    - iSYS-5011 收发器; RADAR 24GHz 评估板
8000000421 数据手册
USER MANUAL iSYS-5011 Evaluation Kit Revision: 1 Date: 10.12.2018 page 1 of 9 Table of content 1. Brief description ............................................................................................... 3 1.1. iSYS-5011 ................................................................................................... 4 1.2. Interface-Board ......................................................................................... 5 1.3. Power-Supply ............................................................................................ 6 1.3.1. Prepare USPS-1000 ............................................................................ 6 1.3.2. Supply voltages .................................................................................. 6 1.4. SPI protocol analyzer ................................................................................. 7 1.5. USB cable ................................................................................................... 7 1.6. Software-Package...................................................................................... 7 2. Setup iSYS-5011 Evaluation Kit ......................................................................... 8 History Document revision Date Change log Author 1 2017-03-22 First release TP Documents [1] iSYS-5011 user manual rev_.pdf [2] target viewer manual rev_.pdf [3] serial radarSDK readMe rev_.pdf [4] iSYS serial interface protocol rev_.pdf page 2 of 9 1. Brief description The Evaluation Kit brings all necessary devices and stuff for a quick installation setup to evaluate the iSYS-5011 performance. Detected targets are shown in a 2D-plot within the Target-Viewer. The iSYS-5011 Evaluation Kit consists of: (1) iSYS-5011 (2) Interface-Board (3) Power-Supply (4) SPI protocol analyzer (5) USB cable (6) Software-Package page 3 of 9 1.1. iSYS-5011 Please regard the iSYS-5011 datasheet [1] and User Manual [2] for detailed product information. page 4 of 9 1.2. Interface-Board The interface board contains a voltage regulator for iSYS-5011 power supply, a connector for Beagle SPI protocol analyzer and an USB to UART Bridge for UART connection. 71 mm (1) (2) 50 mm 57 mm (3) 64 mm (1) Micro USB plug (Part No: 629105136821, Würth Elektronik) (2) DC power jack (Part No: 694108105102, Würth Elektronik) (3) Box Header 2.54mm for Beagle SPI Protocol-Analyzer page 5 of 9 1.3. Power-Supply The Evaluation Kit contains the VOLTCRAFT USPS-1000 plug-in power unit. 1.3.1. Prepare USPS-1000 (1) Unpack power supply (2) Set voltage to 12V (3) Insert correct plug with GND outside 1.3.2. Supply voltages If not using the VOLTCRAFT USPS-1000 please prepare your power supply according Table 1. Comment Symbol min. typ. max. Unit Supply voltage VCC 11 12 13 V Ripple Vripple 360 mV Current I 500 mA Table 1: power supply parameters page 6 of 9 350 1.4. SPI protocol analyzer The Target-Viewer supports the Beagle SPI protocol analyzer from Total-Phase only. Install the Beagle drivers delivered on the attached CD for proper working. 1.5. USB cable Please use attached USB cable with USB-A to micro-USB plugs for UART connection. The driver for the USB to UART Bridge of the CP2102 device will be installed automatically after connection to a Windows PC. 1.6. Software-Package The Software-Package includes all iSYS-5011 Evaluation Kit documents and the Software-Tools provided by InnoSenT. page 7 of 9 2. Setup iSYS-5011 Evaluation Kit Prepare the iSYS-5011 Evaluation Kit in a few steps: 1) Setup USPS-1000 Power-Supply according 1.3.1 2) Connect Beagle to Interface-Board and PC 3) Connect USB-cable to Interface-Board and PC 4) Align iSYS-5011 into direction of the targets described in iSYS-5011 user manual [1] page 8 of 9 5) Install Beagle driver first, then InnoSenT TargetViewer described in target viewer manual [2] Both attached in the Software-Package folder \GUI\.. 6) Start Target-Viewer and connect interfaces described in target viewer manual [2] InnoSenT GmbH Am Roedertor 30 97499 Donnersdorf GERMANY Tel.: +49 95289518-0 E-Mail: info@innosent.de www.innosent.de page 9 of 9
8000000421 价格&库存
很抱歉,暂时无法提供与“8000000421”相匹配的价格&库存,您可以联系我们找货
