8000000409
8000000409
    INNOSENT
    - iSYS-5021 收发器; RADAR 24GHz 评估板
8000000409 数据手册
USER MANUAL iSYS-5021 Evaluation Kit Revision: 1 Date: 11.12.2018 page 1 of 9 Table of content 1. Brief description ............................................................................................... 3 1.1. Quick Start Guide ...................................................................................... 4 1.2. iSYS-5021 ................................................................................................... 6 1.3. Interface-Board ......................................................................................... 7 1.4. Power-Supply ............................................................................................ 8 1.4.1. Prepare USPS-1000 ............................................................................ 8 1.4.2. Supply voltages .................................................................................. 8 1.5. USB cable ................................................................................................... 9 1.6. Ethernet cable ........................................................................................... 9 1.7. Software-Package...................................................................................... 9 History Document revision Date Change log Author 1 2018-12-11 First release TP Documents [1] iSYS-5021 user manual.pdf [2] target viewer manual.pdf [3] serial radarSDK readMe.pdf [4] iSYS serial interface protocol.pdf page 2 of 9 1. Brief description The Evaluation Kit contains all necessary equipment for a quick installation setup to evaluate the iSYS-5021 performance. Detected targets are shown in a 2D-plot within the Target-Viewer software. The iSYS-5021 Evaluation Kit consists of: (1) iSYS-5021 (2) Interface-Board (3) Power-Supply (4) USB cable (5) Ethernet cable (6) Software-Package page 3 of 9 1.1. Quick Start Guide Follow these steps to evaluate the iSYS-5021 with Ethernet interface. 1. Install target viewer software from the software package on your Windows PC. (s. target viewer manual rev_x.pdf for further information if needed) 2. Prepare your PC for fixed IP address. (s. screenshot for default configuration. IP: 192.168.252.2.) 3. Assemble the power USPS-1000 power supply and set output voltage to 12 V.(s. section 1.4 for further information) 4. Connect the power supply to the power plug of iSYS-5021 interface board 5. Connect the USB cable to the iSYS-5021 interface board and to your PC. (if necessary install: CP2102 USB to UART BRIDGE driver from Software package) 6. Connect the Ethernet cable to the iSYS-5021 interface board and to the RJ-45 Plug on your PC. (Important: The sensor must be connected directly to your PC. A switch or router in between is not allowed.) 7. Align iSYS-5021 into direction of the targets (described in iSYS-5021 user manual [1]) 8. Start target viewer software and connect UART to the sensor. (Important: Choose correct COM port) -> Sensor information will be displayed. 9. Choose Target List Settings to ETHERNET. 10. Connect to sensor for target list output (Important: Choose correct Network Connection) page 4 of 9 11. Targets are displayed in the target viewer main window. page 5 of 9 1.2. iSYS-5021 Please read the iSYS-5021 datasheet [1] and User Manual [2] for detailed product information. page 6 of 9 1.3. Interface-Board The INF-5021 interface board contains a voltage regulator for iSYS-5021 power supply, a connector for Beagle SPI protocol analyzer and an USB to UART Bridge for UART connection. (4) (3) (1) (2) (1) Micro USB plug (Part No: 629105136821, Würth Elektronik) (2) DC power jack (Part No: 172-0250, Kobiconn) (3) Box Header 2.54mm (for Beagle SPI Protocol-Analyzer - not included in delivery) (4) RJ-45 socket for target list over Ethernet page 7 of 9 1.4. Power-Supply The Evaluation Kit contains the VOLTCRAFT USPS-1000 plug-in power unit. 1.4.1. Prepare USPS-1000 (1) Unpack power supply (2) Set voltage to 12V (3) Insert correct plug with GND outside 1.4.2. Supply voltages If not using the VOLTCRAFT USPS-1000 please prepare your power supply according to Table 1: power supply parameters. Comment Symbol min. typ. max. Unit Supply voltage VCC 10 12 30 V Power consumption P 4.9 6.4 W Table 1: power supply parameters page 8 of 9 1.5. USB cable Please use attached USB cable with USB-A to micro-USB plugs for UART connection. The driver for the USB to UART Bridge of the CP2102 device will be installed automatically after connection to a Windows PC. 1.6. Ethernet cable Please use attached Ethernet cable for target list transmission. The Ethernet cable needs to connect the iSYS-5021 Eval-Kit and the windows PC with target viewer software directly. A switch or router between the two devices is not allowed. 1.7. Software-Package The Software-Package includes all iSYS-5021 Evaluation Kit documents and the Software-Tools provided by InnoSenT. InnoSenT GmbH Am Roedertor 30 97499 Donnersdorf GERMANY Tel.: +49 95289518-0 E-Mail: info@innosent.de www.innosent.de page 9 of 9
8000000409 价格&库存
很抱歉,暂时无法提供与“8000000409”相匹配的价格&库存,您可以联系我们找货
