80.00000361
80.00000361
    INNOSENT
    接近/占位传感器 雷达 SPI 底座安装
80.00000361 数据手册
Experience and Reliability in Radar Technology www.InnoSenT.de Data Sheet iSYS-5020 designed and manufactured in Germany Version 1.5 - 08.05.18 PRODUCT FAMILY 3D-MIMO-RADAR APPLICATIONS • Area Surveillance Movement Velocity Direction Presence Distance Angle FEATURES »» MIMO-Radar working in the 24GHz - ISM - Band »» Simultaneous capture of speed, distance and angular deviation of a target »» Detection of targets up to 150m in distance »» Unambiguous velocity: 35.3 km/h »» FOV ±75° with an angular resolution of default interface for target list output, CLK 5 MHz max. 6 ETH_EXT.TPIA_P Ethernet -> secondary interface for target list output, 100 Mbit/s 7 SPI_CS SPI -> default interface for target list output 8 ETH_EXT.TPIA_N Ethernet -> secondary interface for target list output 9 SPI_MOSI SPI -> default interface for target list output 10 ETH_EXT.TPIB_P Ethernet -> secondary interface for target list output, 11 SPI_MISO SPI -> default interface for target list output 12 ETH_EXT.TPIB_N Ethernet -> secondary interface for target list output, 100 Mbit/s 13 UART_RX UART -> command interface for configuration (3.3 V) 14 UART_TX DATA SHEET iSYS-5020 • Version 1.5 • CONFIDENTIAL AND PROPRIETARY The information contained in this document shall remain the sole and exclusive property of InnoSenT GmbH and shall not be disclosed by the recipient to third parties without prior consent of InnoSenT in writing. Page 5 PIN # Experience and Reliability in Radar Technology www.InnoSenT.de MECHANICAL DRAWING top view side view The module must be installed with this side up 76.75 ±0.376.75 ±0.3 23.25 3.3 x) (4 x) (4 11.5 ±0.2 11.5 ±0.2 3.3 23.25 70 ±0.2 70 ±0.2 CAUTION 14.5 ±0.3 14.5 ±0.3 bottom view 1 ±1 Label content: DataMatrixCode Model: iSYS-5020 FCC: UXS-ISYS-5020 Canada 310 InnoSenT SN: 8-digit 95 ±0.2 9.5 ±5 x) (4 70 ±0.2 DATA SHEET iSYS-5020 3.3 12.4 ±0.3 14.5 ±0.3 CONFIDENTIAL AND PROPRIETARY The information contained in this document shall remain the sole and exclusive property of InnoSenT GmbH and shall not be disclosed by the recipient to third parties without prior consent of InnoSenT in writing. Page 6 11.5 ±0.2 Version 1.5 x) (4 x) (4 12.4 ±0.3 12.4 ±0.3 .5 R1 .5 R1 antenna centroid antenna centroid rotationalrotational pivot pivot 95 ±0.2 95 ±0.2 1.1 101.8 ±0.3 1.1 101.8 ±0.3 THIS SIDE UP Experience and Reliability in Radar Technology www.InnoSenT.de LABELING Type FCCID data matrix code company name Serial No. Annex A The information that will be given below is only a rough overview; for details please contact the local approval agencies. An overview over the frequency bands in Europe can also be found in the REC 70-03 (Annex 6) which is available under www.ero.dk 24.000 24.050 24.250 CONFIDENTIAL AND PROPRIETARY The information contained in this document shall remain the sole and exclusive property of InnoSenT GmbH and shall not be disclosed by the recipient to third parties without prior consent of InnoSenT in writing. Page 7 Europe-frequency DATA SHEET iSYS-5020 Generally the iSYS-5020 standard version can be used for all countries in Europe except UK. Version 1.5 Frequency Bands in Europe Experience and Reliability in Radar Technology www.InnoSenT.de Frequency Bands in US FCC 15.249 24.000 24.250 US-frequency FCC approval This device complies with Part 15 of the FCC Rules and with RSS-310 of Industry Canada. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. Warning: Changes or modifications made to this equipment not expressly approved by InnoSenT GmbH may void the FCC authorization to operate this equipment. NOTICE: Changes or modifications made to this equipment not expressly approved by (manufacturer name) may void the FCC authorization to operate this equipment. ESD-INFORMATION This InnoSenT sensor is sensitive to damage from ESD. Normal precautions as usually applied to CMOS devices are sufficient when handling the device. Touching the signal output pins has to be DATA SHEET iSYS-5020 Le présent appareil est conforme aux CNR d‘Industrie Canada applicables aux appareils radio exempts de licence. L‘exploitation est autorisée aux deux conditions suivantes: (1) l‘appareil ne doit pas produire de brouillage, et (2) l‘utilisateur de l‘appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d’en compromettre le fonctionnement. Version 1.5 Manufacturers of mobile or fixed devices incorporating iSYS-5020 modules are authorized to use the FCC Grants for their own final products according to the conditions referenced in these documents. In this case, the FCC label of the module shall be visible from the outside, or the host device shall bear a second label stating „Contains FCC ID: UXS-ISYS-5020“. CONFIDENTIAL AND PROPRIETARY The information contained in this document shall remain the sole and exclusive property of InnoSenT GmbH and shall not be disclosed by the recipient to third parties without prior consent of InnoSenT in writing. Page 8 avoided at any time before soldering or plugging the device into a motherboard. Experience and Reliability in Radar Technology This Data Sheet contains the technical specifications of the described product. Changes of the specification must be in written form. All previous versions of this Data Sheet are no longer valid. VERSION DATE COMMENT 1.0 21.12.2017 initial release 1.1 10.01.2018 adding in mechanical drawing 1.2 20.04.2018 changing in mechanic; adding labeling; adding Annex A; adding Frequency Bands in Europe; adding Frequency Bands in US FCC 15.249 1.3 24.04.2018 changing in mechanic; adding labeling; adding in command interface; adding in output power; adding in detection range; changing in distance error; changing in angle error; adding transient current 1.4 07.05.2018 changing in install information 1.5 08.05.2018 changing in operating temperature +49 (0)9528 - 9518 - 0 Tel.: E-Mail: info@innosent.de www.innosent.de URL: CONFIDENTIAL AND PROPRIETARY The information contained in this document shall remain the sole and exclusive property of InnoSenT GmbH and shall not be disclosed by the recipient to third parties without prior consent of InnoSenT in writing. Page 9 Am Rödertor 30 97499 Donnersdorf GERMANY InnoSenT GmbH DATA SHEET iSYS-5020 APPROVAL Version 1.5 www.InnoSenT.de
80.00000361 价格&库存
很抱歉,暂时无法提供与“80.00000361”相匹配的价格&库存,您可以联系我们找货
