IN-505FCHWV
IN-505FCHWV
    INOLUX(英诺斯)
    SMD
    发光二极管/LED 红色,翠绿色,蓝色,白色 SMD
IN-505FCHWV 数据手册
High Power RGBW LED IN-505FCHWV Inolux Surface Mount High Power LED IN-505FCHWV Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 1/12 High Power RGBW LED IN-505FCHWV DISCLAIMER............................................................................................................................ 3 LABEL SPECIFICATIONS ....................................................................................................... 4 PRODUCT CHARACTERISTICS ............................................................................................. 5 ABSOLUTE MAXIMUM RATINGS ................................................................................................. 5 ELECTRO-OPTICAL CHARACTERISTICS ...................................................................................... 6 PACKAGE OUTLINE DIMENSION................................................................................................. 7 RECOMMENDED SOLDERING PATTERN FOR REFLOW SOLDERING ................................................ 7 CHARACTERISTIC CURVES ....................................................................................................... 8 REFLOW SOLDERING .......................................................................................................... 10 PACKING INFORMATION ...................................................................................................... 11 REVISION HISTORY .............................................................................................................. 12 Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 2/12 High Power RGBW LED IN-505FCHWV DISCLAIMER INOLUX reserves the right to make changes without further notice to any products herein to improve reliability, function or design. INOLUX does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. LIFE SUPPORT POLICY INOLUX’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of INOLUX or INOLUX Technologies. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 3/12 High Power RGBW LED IN-505FCHWV Label Specifications INOLUX P/N: I N - 5 0 Series Name 5 F C H W V Substrate / Emitting Color - X X X X Customer Code IN-505 FCHW - XXXX Inolux 5050 package RGB White Customer Product Code V– 700mA Lot No.: Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 4/12 High Power RGBW LED IN-505FCHWV Product Characteristics Absolute Maximum Ratings (Tj =25 °C) Parameter Symbol Rating Unit DC Forward Current (mA) If 700mA mA Peak Pulsing Current IPeak 1000mA mA Reverse Voltage VR 5 V LED Junction Temperature TJ 125°C °C LED Operating Temperature TOpr -40°C ~ 85°C °C Storage Temperature TStg -40°C ~ 110°C °C Tsol 20~40 sec. s HBM 8,000V (MIL-STD-883G Class 3B) V MM 400V (JESD22-A115-B Class C) V Soldering Temperature at Tp (JEDEC-020-D) ESD Sensitivity Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 5/12 High Power RGBW LED IN-505FCHWV Electro-Optical Characteristics (Tj 25 oC) Part Number IN-505FCHWV CCT / Dominate Wavelength Min Max Luminous Flux (lm) @ 350mA Red 620nm 630nm >45 Green 515nm 535nm Blue 455nm White 5000k Color Luminous Flux (lm) @ 700mA Forward Voltage @ 700mA Min Max 80-113.6 2.1 3.2 >100 150-195 3.2 4.2 470nm >18 40-70 3.2 4.0 8300k >100 180-220 3.2 4.0 Notes: 1. The peak/dominant wavelength is measured with an accuracy of ±1nm. 2. Luminous Flux is measured with an accuracy of ±10% 3. The forward voltage is measured with an accuracy of ±0.2V 4. Never operate the LEDs in reverse bias. 5. Do not drive at rated current for more than 5 seconds without proper thermal management. 6. When the LEDs are illuminating, operating current should be decided after considering the packages maximum temperature. 7. Caution: These devices emit high intensity light. Necessary precautions must be taken during operation. Do not look directly into the light or look through the optical system when in operation. Protective eyewear should be worn at all times during operation. Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 6/12 High Power RGBW LED IN-505FCHWV Package Outline Dimension Recommended Soldering Pattern for Reflow Soldering Unit: mm Tolerance: +/-0.13 Outline Dimension Solder Pattern Recommended Soldering Pad Design Recommended Stencil Pattern Design (Marked Area is Opening) Chip Color A Red B Green C Blue D White - - Soldering terminals may shift in the x, y direction. Unit: mm Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 7/12 High Power RGBW LED IN-505FCHWV Characteristic Curves Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 8/12 High Power RGBW LED IN-505FCHWV Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 9/12 High Power RGBW LED IN-505FCHWV Reflow Soldering The LEDs can be soldered using the parameter listed below. As a general guideline, the users are suggested to follow the recommended soldering profile provided by the manufacturer of the solder paste. Although the recommended soldering conditions are specified in the list, reflow soldering at the lowest possible temperature is preferred for the LEDs. Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 10/12 High Power RGBW LED IN-505FCHWV Packing Information Note : All Dimensions are in millimeter Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 11/12 High Power RGBW LED IN-505FCHWV Revision History Changes since last revision Page Initial release Update Electro-Optical Characteristics 6 Version No. Revision Date 1.0 10-03-2014 1.1 03-13-2020 Official Product Product: IN-505FCHWV Data Sheet No. Tentative Product **************** IN-505FCHWV Specifications are subject to change without notice. Data and drawings herein are copyrighted. Mar. 13, 2020 Version of 1.1 Page 12/12
IN-505FCHWV 价格&库存
很抱歉,暂时无法提供与“IN-505FCHWV”相匹配的价格&库存,您可以联系我们找货
IN-505FCHWV
  • 1+72.698951+9.45063
  • 10+55.2275510+7.17941
  • 100+45.00867100+5.85098
库存:2157
IN-505FCHWV
    IN-505FCHWV
      IN-505FCHWV
        • 1+84.13200
        • 200+33.57720
        • 500+32.45400
        • 1000+31.89240
        IN-505FCHWV
        • 500+40.55596500+5.27215
        • 1000+39.110451000+5.08424
        • 1500+38.370691500+4.98807
        库存:2157
