ACD-3216-A1-CC-S
ACD-3216-A1-CC-S
    INPAQ(台湾佳邦)
    GPS, 1575MHZ, COUPLING, 3.2*1.7*
ACD-3216-A1-CC-S 数据手册
Contact: INPAQ USA -James Lee Email: jameslee@inpaqusa.com TEL: 267-265-4079 Title: Business Manager ACD-3216-A1-CC-S Specification Product Name Series/PN Size INPAQ RF Chip Antenna ACD-3216-A1-CC-S EIAJ 3216 PN:ACD-3216-A1-CC-S Specification 1. Application GPS L1 band、1575.42MHz 2. Explanation of Part Number AC D _ (1) (2) (1) (2) (3) (4) (5) (6) (7) 3216 _ A1 (3) _ CC _ S (4) (5) (6) (7) Product Type:Chip Antenna Center Frequency/Band Code:D—1575.42 MHz group Product Code:3.2mm(Length) x 1.6mm(Width) Design Revision Code:Rev.1 CC= Coupling Ceramic Type Special Code:S=RoHS Compliant Suffix For Special Requirements 3. Electrical Specification Electrical Specification* Center Frequency 1575.42 MHz Frequency Range 1570 ~ 1580 MHz (S11≦ -10dB)* Polarization Linear Pattern Omni-Directional Ref. Impedance 50 ohm Peak Gain 1.80 dBi (typ.)@1575.42 MHz Efficiency 62.2% (typ.)@1575.42 MHz Size 3.2mm x 1.7mm x 0.5mm * Test condition:Test board size 100*50 mm. Matching circuit:Pi matching circuit will be required. 4. Physical Dimension (Unit:mm) TOP view 2 Bottom view 1 1 1 2 1 Chip Antenna L W A ACD-3216 3.2±0.30 1.7±0.30 0.3±0.15 2 1 3 2 1 B L1 W1 0.3±0.15 0.47±0.20 0.7±0.20 H 0.5±0.1 ACD-3216-A1-CC-S Engineer Specification Version: A1 Page 1 of 6  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com 5. Recommended PCB layout (Unit:mm) Contact: INPAQ USA -James Lee Email: jameslee@inpaqusa.com TEL: 267-265-4079 Title: Business Manager 6. Electrical Characteristics Return Loss Frequency (MHz) Return Loss (dB) 1570 -19.5 1575 -39.0 1580 -20.3 Radiation Pattern The Gain pattern is measured in INPAQ’s FAR-field chamber. DUT is placed on the table of rotator, a standard horn antenna and Vector Network Analyzer is used to collect data. 3D Chamber Definition ACD-3216-A1-CC-S Engineer Specification Version: A1 Page 2 of 6  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com ◎ 3D Gain Pattern (1575 MHz) 7. Taping Package and Label Marking (Unit:mm) 甲、Quantity:4000pcs/Reel, T(Thickness of chip)≦1.2 乙、Plastic Tape (Unit:mm) Type 3216 W 8±0.1 A 2.0~2.2 B 3.50~3.60 K Max. 1.40 t 0.22±0.05 F 3.50±0.1 P 4.00±0.1 丙、Tape Packing 丁、Cover Tape Reel Off Force ACD-3216-A1-CC-S Engineer Specification Version: A1 Page 3 of 6  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com 戊、Reel Dimensions (Unit: mm) W 8±0.5 12±0.5 A 178±0.5 178±0.5 B 13±0.5 13±0.5 8. Environmental Characteristics (1) Reliability Test Item Thermal shock 1. 2. 3. 4. 5. Condition 30±3 minutes at -40°C±5°C, Convert to +105°C (5 minutes) 30±3 minutes at +105°C±5°C, Convert to -40°C (5 minutes) Total 100 continuous cycles Specification No apparent damage Fulfill the electrical spec. after test. 1. Humidity:85% R.H. Humidity resistance 2. Temperature:85±5°C No apparent damage Fulfill the electrical spec. after test. 3. Time:1000 hours. High temperature resistance 1. Temperature:150°C±5°C Low temperature resistance 1. Temperature:-40°C±5°C Soldering heat resistance Solderability 2. Time:1000 hours. 2. Time:1000 hours. 1. Solder bath temperature:260±5℃ 2. Bathing time:10±1 seconds No apparent damage Fulfill the electrical spec. after test. No apparent damage Fulfill the electrical spec. after test. No apparent damage The dipped surface of the terminal shall be at least 95% covered with solder after dipped in solder No apparent damage bath of 245±5℃ for 3±1 seconds. ACD-3216-A1-CC-S Engineer Specification Version: A1 Page 4 of 6  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com (2) Storage condition (a) At warehouse: The temperature should be within 0 ~ 30℃ and humidity should be less than 60% RH. The product should be used within 1 year from the time of delivery. (b) On board: The temperature should be within -40~85℃ and humidity should be less than 85% RH. (3) Operating temperature range Operating temperature range:-40℃ to +105℃. 9. Recommended reflow soldering ACD-3216-A1-CC-S Engineer Specification Version: A1 Page 5 of 6  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com (1) Soldering gun procedure Note the follows, in case of using solder gun for replacement. (a) The tip temperature must be less than 350C for the period within 3 seconds by using soldering gun under 30 W. (b) The soldering gun tip shall not touch this product directly. (2) Soldering volume Note that excess of soldering volume will easily get crack the body of this product. ACD-3216-A1-CC-S Engineer Specification Version: A1 Page 6 of 6  All Specifications are subject to change without notice. www.inpaq.com.tw ; www.inpaqgp.com
ACD-3216-A1-CC-S 价格&库存
很抱歉,暂时无法提供与“ACD-3216-A1-CC-S”相匹配的价格&库存,您可以联系我们找货
