PRODUCT
SPECIFICATION
DOCUMENT NO. ENS000139520
DESCRIPTION
DRAWN BY
DESIGNED BY
CHECKED BY
APPROVED BY
AIP0630GX Series
Irene
Peter
Logan
Phil
INPAQ TECHNOLOGY CO., LTD.
RoHS
Pb
Molding Type Power Choke
◢ Scope
Features
- Thickness max. 3mm.
- Flux shielded structure, low radiation.
- High saturation current realized by coil design and alloy powder.
- Low power loss and temperature rising realized by low DC Resistance.
- Low AC loss realized by powder, binder and structure design.
- 100% Pb free meet RoHS standard.
Applications
- 5G
- ADAS / Infotainment
- Server / Industry / VGA
- Desktop / NB / MB
- DC to DC converter in low profile high current system such as
- CPU, VRM, V-core, VGA card…etc.
◢ Explanation of Part Number
A I P 0 6 3 0 GX - 1 R 0MP B DG
Control code
Tolerance
M : ±20%
Inductance
R24=0.24μH ; 1R0=1.0μH ; 100=10μH
Type Name
Dimensions
Product
TITLE : AIP0630GX Series Engineering
Specification
DOCUMENT NO.
ENS000139520
Product Code
SPEC REV.: A0
Page
2 of 9
www.inpaq.com.tw ; www.inpaqgp.com
B
I-FM-04-40
◢ Dimensions
Code Dimensions[mm]
A
7.2 ± 0.4
B
6.5 ± 0.4
C
3.0 max
D
5.0 ± 0.3
E
3.0 ± 0.3
F
3.6 max
◢ Recommended land pattern
Code Dimensions[mm]
Specification
DOCUMENT NO.
ENS000139520
A
5.5
B
2.6
C
5.5
SPEC REV.: A0
Page
3 of 9
B
I-FM-04-40
◢ Marking
The inductor is marked with a 3-digit code (using ink for marking).
Example:
R24 means 0.24μH
1R0 means 1.0μH
100 means 10μH
1R0
Specification
DOCUMENT NO.
ENS000139520
SPEC REV.: A0
Page
4 of 9
B
I-FM-04-40
◢ Specifications
0630
Series PN
Li [μH]
Rdc [mΩ]
Isat [A]
Irms [A]
SRF [MHz]
Initial Value
DC resistance
Li drop 30%
Temp. rising 40℃
Resonance
+/-20%
typ.
max.
typ.
max.
typ.
max.
typ.
AIP0630GX-1R0MPBDG
1.0
5.3
5.95
23
20.7
18
17.1
48
Notes
1. Test environment of all data is referenced to 25°C ambient.
2. Test conditions: 1MHz, 1Vrms.
3. Isat : DC current (A) that will cause L to drop approximately 30%.
4. Irms : DC current (A) that will cause an approximate ΔT of 40°C(reference ambient temperature is 25°C).
5. Operating temperature range – 40°C to +125°C.
6. The part temperature (ambient + temp rise) should not exceed 125°C under worst case operating
conditions. PCB land pattern, trace size - thick, circuit design and proximity to other components are all
the factors will affect the temperature performance of the device. Therefore should be approved in
application conditions and end product.
7. Rdc Measured with DC resistance meters RM3543(HIOKI) or equivalent.
Specification
DOCUMENT NO.
ENS000139520
SPEC REV.: A0
Page
5 of 9
B
I-FM-04-40
◢ Bias Properties
◢ Frequency Response
Specification
DOCUMENT NO.
ENS000139520
SPEC REV.: A0
Page
6 of 9
B
I-FM-04-40
◢ Recommendable Reflow Soldering
Profile Feature
Preheat
- Temperature Min(Tsmin)
- Temperature Max(Tsmax)
- Time (ts) from (Tsmin to Tsmax)
150°C
200°C
60-120 seconds
Ramp-up rate (TL to TP)
1°C / second max.
Liquidous temperature(TL)
Time (t) maintained above TL
217°C
60-120 seconds
Peak package body temperature(TP)
Time within 5°C of actual peak temperature(tp)
Ramp-down rate (TP to TL)
250°C
10-20 seconds
6°C / second max.
Time 25°C to peak temperature
Number of Reflow cycles allowed
Specification
Pb-Free Assembly
DOCUMENT NO.
ENS000139520
6 minutes max.
2 cycles max.
SPEC REV.: A0
Page
7 of 9
B
I-FM-04-40
◢ Tape & Reel
► Reel dimensions (unit : mm)
Type
A
B
C
D
13’x16
16.3±0.2
100±0.2
13+0.3/-0.1
330±1.0
► Tape dimensions (unit : mm)
Type
AIP0630GX
W
P1
P0
P2
D0
D1
t
A0
B0
K0
E
F
16
12
4
2
1.5
0.4
6.9
7.6 3.4 1.75 7.5
NIL
±0.3 ±0.1 ±0.1 ±0.1 +0.1
±0.05 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1
Specification
DOCUMENT NO.
ENS000139520
SPEC REV.: A0
Page
8 of 9
B
I-FM-04-40
► Taping Drawings
► Taping Package Storage Condition
Storage Temperature: 5 to 40°C
Relative Humidity: < 65%RH
Storage Time: 12 months max
► Label Marking
The label specified as follows shall be put on the side of reel.
(1)
(2)
(3)
Part No.
Quantity.
Lot No.
* Part No. And Quantity shall be marked on outer packaging.
► Quantity of products in the package
Type
Reel
Inner Box
Outer Box
AIP0630GX
1000
2000
10000
Specification
DOCUMENT NO.
ENS000139520
SPEC REV.: A0
Page
9 of 9
B
I-FM-04-40
很抱歉,暂时无法提供与“AIP0630GX-1R0MPBDG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.17329
- 200+0.84111
- 500+0.81152
- 1000+0.79694
