PRODUCT
SPECIFICATION
DOCUMENT NO. ENS000108240
DESCRIPTION
DRAWN BY
DESIGNED BY
CHECKED BY
APPROVED BY
MOVS2825DG Series
Sandy
Hung Tsai
C.P. Huang
Shawn Yeh
10
INPAQ TECHNOLOGY CO., LTD.
MOVS2825DG Series Engineering Specification
1. Scope
(1)
(2)
(3)
(4)
(5)
SMD type Metal Oxide Varistor
High transient current capability
Encapsulation material according to UL94-V0
RoHS compliant
UL/cUL 1449 approved
Applications
(1).
(2).
(3).
(4).
Power supply
Home appliance
Industrial equipment
Telecommunication or telephone system
2. Explanation of Part Number
MOV S 2825 101 _DG_
(1)
(2)
(3)
(4)
(5)
(1). Metal oxide varistor
(2). Type: S=single; A=array
(3). Size
(4). Varistor voltage
(5). Inpaq Control code
TITLE : MOVS2825DG series Engineering
Specification
DOCUMENT NO.
ENS000108240
SPEC REV.: A1
Page 1 of 9
www.inpaq.com.tw ; www.inpaqgp.com
B
I -FM-04-41
10
3. Construction & Dimension
L
W
L
C1
W
T
C2
Bottom View
Unit : mm
2825
L
7.2 ± 0.2
W
6.4 ± 0.2
Note
3.2 ± 0.3
T
4.2 ± 0.3
reference table 4.1
5.6 ± 0.3
C1
5.8 ± 0.3
C2
1.1 ± 0.3
Specification
DOCUMENT NO.
ENS000108240
SPEC REV.: A1
Page 2 of 9
B
I -FM-04-41
10
4. Part ratings and characteristics:
4.1. Rating
Working
voltage
Symbol
Units
VRMS
VDC
Volts
Volts
(Max.)
(Max.)
Varistor
voltage
IL
Vc
imax
T
uA
Volts
Amps
mm
(Max.)
(Max.)
(Max.)
VV
Volts
1mA DC
Test Condition
Leakage Clamping Peak Component
Current Voltage current thickness
Vv*80%
(at initial state)
8/20s 8/20s
MOVS2825180DG
11
14
16.2~19.8
50
40(1A)
150
3.2
MOVS2825220DG
14
18
19.8~24.2
50
48(1A)
150
3.2
MOVS2825270DG
17
22
24.3~29.7
50
60(1A)
150
3.2
MOVS2825330DG
29.7~36.3
50
73(1A)
150
4.2
MOVS2825390DG
25
31
35.1~42.9
50
80(1A)
150
4.2
MOVS2825470DG
30
38
42.3~51.7
50
104(1A)
150
4.2
MOVS2825560DG
35
45
50.4~61.6
50
123(1A)
150
4.2
MOVS2825680DG
40
56
61.2~74.8
50
145(1A)
150
4.2
MOVS2825820DG
50
66
73.8~90.2
50
150(5A)
400
3.2
MOVS2825101DG
60
85
90~110
50
175(5A)
400
3.2
MOVS2825121DG
75
102
108~132
50
210(5A)
400
4.2
MOVS2825151DG
95
127
135~165
50
260(5A)
400
4.2
MOVS2825181DG
120
160
170~207
50
320(5A)
400
4.2
MOVS2825201DG
130
175
185~225
50
355(5A)
400
4.2
MOVS2825221DG
140
180
198~242
50
380(5A)
400
4.2
MOVS2825241DG
150
200
216~264
50
415(5A)
400
4.2
MOVS2825271DG
180
230
255~311
50
475(5A)
400
4.2
MOVS2825301DG
195
250
270~330
50
520(5A)
400
4.2
MOVS2825331DG
210
275
297~363
50
570(5A)
400
4.2
MOVS2825361DG
230
300
324~396
50
620(5A)
400
4.2
MOVS2825391DG
250
330
351~429
50
675(5A)
400
4.2
MOVS2825431DG
275
370
387~473
50
745(5A)
400
5.6
MOVS2825471DG
300
385
423~517
50
810(5A)
400
5.6
MOVS2825511DG
320
420
459~561
50
845(5A)
400
5.6
MOVS2825561DG
360
470
522~638
50
920(5A)
400
5.6
Specification
DOCUMENT NO.
ENS000108240
SPEC REV.: A1
Page 3 of 9
B
I -FM-04-41
10
Working
voltage
Symbol
Units
VRMS
VDC
Volts
Volts
(Max.)
(Max.)
Varistor
voltage
IL
Vc
imax
T
uA
Volts
Amps
mm
(Max.)
(Max.)
(Max.)
VV
Volts
1mA DC
Test Condition
Vv*80%
(at initial state)
8/20s 8/20s
MOVS2825621DG
390
505
558~682
50
1025(5A)
400
5.6
MOVS2825681DG
420
560
612~748
50
1120(5A)
400
5.6
VDC –Maximum DC operating voltage the varistor can maintain
VV – Voltage across the device measured at 1mA DC current.
Equivalent to Vb, “Breakdown Voltage”.
Vc – Maximum peak voltage across the varistor measured at 8/20us waveform .
imax – Maximum peak current which may be applied with 8/20us waveform without device
failure
Specification
DOCUMENT NO.
ENS000108240
SPEC REV.: A1
Page 4 of 9
B
I -FM-04-41
10
5. General electrical specifications
5.1. General technical data (OTHER SPEC)
Operating temperature
-40 … +85oC
Storage temperature (on board)
-40 … +85oC
Solderability
245±5oC, 3 ±1sec
Solder leach resistance
260±5oC,10 ±1sec
5.2. Taping Package Storage Condition
Storage Temperature: 5 to 40oC
Relative Humidity: to 65%
Storage Time: 12 months max
6. Taping Package and Label Marking
6.1. Carrier tape dimensions
Type
2825
W
E
F
D0
D1
P0
P0 x10
16.00
±0.30
1.75
±0.10
7.50
±0.15
1.50
+0.10/-0.00
1.50
+0.10/-0.00
4.00
±0.10
40.00
±0.20
t
A0
B0
K0
P1
P2
0.50
±0.05
6.75
7.55
6.20(max)
12.00
±0.10
2.00
±0.15
+0.15/-0.05 +0.15/-0.05
Specification
DOCUMENT NO.
ENS000108240
SPEC REV.: A1
Page 5 of 9
B
I -FM-04-41
10
6.2. Taping reel dimensions
單位:(mm)
Type
A
B
C
D
E
F
G
13”
330
±2.00
99
±1.50
13.50
±0.20
2.30
±0.20
16.50
±0.50
2.20
±0.20
10.75
±0.20
6.3. Taping specifications
There shall be the portion having no product in both the head and the end of taping,
and there shall be the cover tape in the head of taping.
6.4. Label Marking
The label specified as follows shall be put on the side of reel.
(1)Part No.
(2)Quantity
(3)Lot No.
Part No. And Quantity shall be marked on outer packaging.
6.5. Quantity of products in the taping package
(1) Standard quantity: 900pcs/Reel for MOVS2825 T=5.6mm,1100pcs/Reel for
MOVS2825 T=4.2mm,1400pcs/Reel for MOVS2825 T=3.2mm。
(2) Shipping quantity is a multiple of standard quantity.
Specification
DOCUMENT NO.
ENS000108240
SPEC REV.: A1
Page 6 of 9
B
I -FM-04-41
10
7. Precautions for Handling
7.1. Solder cream in reflow soldering
Refer to the recommendable land pattern as printing mask pattern for solder cream.
(1) Print solder in a thickness of 0.1mm
L
A
C
B
Item
Size(EIA)
2825
Unit: mm
A
B
C
L
6.8
1.5
4.6
7.6
7.2. Precaution for handling of substrate
Do not exceed to bend the board after soldering this product extremely.
(Reference examples)
Mounting place must be as far as possible from the position, which is close to the
break line of board, or on the line of large holes of board.
Do not bend extremely the board, in mounting another component.
If necessary, use back-up pin (support pin) to prevent from bending extremely.
Do not break the board by hand. We recommend to using the machine or the jig to
break it.
7.3. Precaution for soldering
Note that rapid heating, rapid cooling or local heating will easily damage this
product.
Do not give heat shock over 100C in the process of soldering. We recommend
taking preheating and gradual cooling.
Specification
DOCUMENT NO.
ENS000108240
SPEC REV.: A1
Page 7 of 9
B
I -FM-04-41
10
7.4. Recommendable reflow soldering
Profile Feature
Pb-Free Assembly
Average Ramp-Up Rate
(Tsmax to Tp)
3° C/second max.
Preheat
– Temperature Min (Tsmin)
– Temperature Max (Tsmax)
– Time (tsmin to tsmax)
150 °C
200 °C
60-180 seconds
Time maintained above:
– Temperature (TL)
217 °C
– Time (tL)
60-150 seconds
Peak/Classification Temperature (Tp)
250 °C
Time within 5 °C of actual Peak
Temperature (tp)
20-40 seconds
Ramp-Down Rate
6 °C/second max.
Time 25 °C to Peak Temperature
8 minutes max.
*According to J-STD-020C
Specification
DOCUMENT NO.
ENS000108240
SPEC REV.: A1
Page 8 of 9
B
I -FM-04-41
10
7.5. Soldering gun procedure
Note the follows, in case of using solder gun for replacement.
(1) The tip temperature must be less than 280C for the period within 3 seconds by
using soldering gun under 30 W.
(2) The soldering gun tip shall not touch this product directly.
7.6. Soldering volume
Note that excess of soldering volume will easily get crack the body of this product.
Specification
DOCUMENT NO.
ENS000108240
SPEC REV.: A1
Page 9 of 9
B
I -FM-04-41
很抱歉,暂时无法提供与“MOVS2825101DG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.65165
- 200+0.63926
- 500+0.61679
- 1000+0.60567
