PRODUCT
SPECIFICATION
DOCUMENT NO. ENS000144630
DESCRIPTION
DRAWN BY
DESIGNED BY
CHECKED BY
APPROVED BY
TVN 0201 01 5V AA0DG
Eric
Eric
Anderson
Shawn
INPAQ TECHNOLOGY CO., LTD.
TVN 0201 01 5V AA0DG Product Engineering Specification
1. Scope
TVN 0201 01 5V AA0 is a TVS diode designed to protect one power/control line or one low
speed signal line from overvoltage hazard of Electrostatic Discharge (ESD).
These interfaces can be used in computer interfaces protection, microprocessors protection,
serial and parallel ports protection, control signal lines protection, power lines on PCB
protection, latch-up protection. The actual application examples are USB2.0, VBUS, and VGA,
etc. The ESD protection of TVS meets the immunity standard of IEC 61000-4-2, level 4 (±20kV
air, ±20kV contact discharge).
2. Explanation of Part Number
TV
N
0201
01
5V
AA0 DG
(1)
(2)
(3)
(4)
(5)
(6) (7)
(1)
(2)
(3)
(4)
(5)
(6)
(7)
Product Type:TV=TVS Diode
Capacitance Code:L=Low Capacitance
Package Code
Channel Code:01=1 Channels
Working Voltage
Special code
Inpaq Control Code
3. Circuit Diagram & Dimension
TITLE : TVN 0201 01 5V AA0DG
Specification
Engineering
DOCUMENT NO.
ENS000144630
Unit: mm
0201
L
0.60±0.05
W
0.30±0.04
T
0.30±0.04
C
0.20±0.06
SPEC REV.: A0
Page 1 of 7
www.inpaq.com.tw ; www.inpaqgp.com
B
I-FM-04-40
4. Specifications
4.1. Absolute Maximum Ratings
Parameter
Symbol
Rating
Units
Operating Supply Voltage
VDC
5
V
Peak Pulse Current (8/20 µs)
IPP
8
A
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
VESD
±20
±20
kV
Lead Soldering Temperature
TSOL
260 (10 sec.)
o
C
4.2. Electrical Characteristics
Parameter
Symbol
Conditions
o
Reverse Stand-Off Voltage
VRWM
T=25 C.
Reverse Leakage Current
ILeak
VRWM = 5V, T=25 oC.
Reverse Breakdown
Voltage
VBV
IBV = 1mA, T=25 oC.
Clamping Voltage
VTLP
Channel Input
Capacitance
CIN
Min
Typ
-5
7
9
ITLP = 16A(100ns transmission line)
6.2
7.4
VR = 0V, f = 1MHz, T=25 oC.
18
ITLP = 1A (100ns transmission line)
Max
Units
5
V
1
μA
11.5
V
pF
4.3. Typical Characteristics
Specification
Engineering
DOCUMENT NO.
ENS000144630
SPEC REV.: A0
Page 2 of 7
B
I-FM-04-40
5. Taping Package and Label Marking
5.1. Packaging Method (Material: paper)
Products shall be heat-sealed in the chip pocket, spacing pitch 4-mm of paper carrier
tape with plastic cover tape, and the carrier tape shall be reeled to the reel.
5.2. Carrier Tape Dimensions
Type
0201
A'
B'
W
E
F
P0
P1
P2
D0
T
K
0.35
0.67
8.0
1.75
3.5
4.0
2.0
2.0
1.55
0.42
0.35
±0.02
±0.02
±0.1
±0.05
±0.05
±0.03
±0.03
±0.03
±0.05
±0.03
±0.02
5.3. Taping Reel Dimensions
Unit: mm
Specification
Engineering
DOCUMENT NO.
ENS000144630
SPEC REV.: A0
Page 3 of 7
B
I-FM-04-40
5.4. Taping Specifications
There shall be the portion having no product in both the head and the end of taping, and
there shall be the cover tape in the head of taping.
5.5. Label Marking
The label specified as follows shall be put on the side of reel.
(1)Part No.
(2)Quantity
(3)Lot No.
*Part No. And Quantity shall be marked on outer packaging.
5.6. Quantity of Products in the Taping Package
(1) Standard quantity:15000pcs/Reel for TVN0201 Series
(2) Shipping quantity is a multiple of standard quantity.
5.7. Storage Condition with Package
Storage Time: 12 months max
Storage Temperature : 5 to 40℃
Relative Humidity: 0 to 60 %
Specification
Engineering
DOCUMENT NO.
ENS000144630
SPEC REV.: A0
Page 4 of 7
B
I-FM-04-40
6. Precautions for Handling
6.1. Solder Cream in Reflow Soldering
Refer to the recommendable land pattern as printing mask pattern for solder cream.
(1) Print solder in a thickness of 150 to 200 m.
(2) Dimensions: millimeters (inches)
0201
c
b
b
a
Unit: mm
Type
a
b
c
0201
0.2~0.3
0.25~0.30
0.3~0.4
Notes: This LAND LAYOUT is for reference purposes only. Please consult your manufacturing partners
to ensure your company’s PCB design guidelines are met.
6.2. Precaution for Handling of Substrate
Do not exceed to bend the board after soldering this product extremely.
(Reference examples)
Mounting place must be as far as possible from the position, which is close to the
break line of board, or on the line of large holes of board.
Do not bend extremely the board, in mounting other components.
If necessary, use back-up pin (support pin) to prevent from bending extremely.
Do not break the board by hand. We recommend using the machine or the jig to
break it.
6.3. Precaution for Soldering
Note that rapid heating, rapid cooling or local heating will easily damage this product.
Do not give heat shock over 100C in the process of soldering. We recommend taking
preheating and gradual cooling.
Specification
Engineering
DOCUMENT NO.
ENS000144630
SPEC REV.: A0
Page 5 of 7
B
I-FM-04-40
6.4. Recommendable Reflow Soldering
Profile Feature
Pb free Assembly
Average Ramp Rate
(Ts max to Tp)
3℃/second max
Preheat
- Temperature Min (Tsmin)
150℃
200℃
Temperature Min (Tsmax)
Time(tsmin to tsmin)
60-180 seconds
Time maintained above:
- Temperature (TL)
- Time (tL)
217℃
Peak Temperature (Tp)
260℃ +0/-5 ℃
60-150 seconds
Time within 5 ℃ of actual Peak
Temperature (Tp)
Ramp-Down Rate
Time 25℃ to Peak Temperature
Max 10 seconds.
6℃/second max.
8 minutes max
*According to J-STD-020C
Specification
Engineering
DOCUMENT NO.
ENS000144630
SPEC REV.: A0
Page 6 of 7
B
I-FM-04-40
6.5. Soldering Gun Procedure
Note the follows, in case of using solder gun for replacement.
(1) The tip temperature must be less than 330C for the period within 6 seconds by using
soldering gun less than 30 W.
(2) The soldering gun tip shall not touch this product directly.
6.6. Soldering Volume
Note that excess of soldering volume will easily get crack the body of this product.
6.7. MSL Level:
Level 1
Specification
Engineering
DOCUMENT NO.
ENS000144630
SPEC REV.: A0
Page 7 of 7
B
I-FM-04-40
很抱歉,暂时无法提供与“TVN0201015VAA0DG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.12366
- 200+0.04785
- 500+0.04623
- 1000+0.04536
