24V COB LED Tape 480 LED/m
Flexible LED Strip
265216
Inspired LED’s 24 Volt COB Flexible Strip Lights are a simple, costeffective solution for various task lighting applications. The higher
density LEDs are encapsulated under epoxy creating seamless
light uniformity. The higher density of LED diodes emits a strong
light intensity while maintaining efficiency. Available in 12 Meter
reels or bulk strips, these unique strips can easily be cut and
terminated with the iDea Series Screw Terminal Solderless
Connector for easy DIY installation. Energy efficient, long-lasting,
and dimmable with compatible systems, Inspired LED COB flex
strips are the perfect option for any lighting application!
Specifications:
Voltage
LED Density
Wattage
Luminosity
Color Temp
CRI
Warm White
24VDC
144 LEDs/ft., 480 LEDs/m
3.15W/ft.
320 lm/ft.
3000K
91
Pure White
24VDC
3.15W/ft.
340 lm/ft.
4000K
91
Product Features:
Chip-on-Board (COB) LEDs
8mm flex, cut points available every 1.97” (24 LEDs)
Available in bulk pre-cut lengths or full 12m reels
Class 2 DC plug-in connector (3.5 x 1.3mm), iDea Series
Solderless Connectors or 18AWG-22AWG direct
soldered leads available
3M adhesive mounting to almost any flat surface
Dimmable with compatible systems
Rated to last up to 100,000 hours
CSA C22.2 No. 250.0-08/ANSI/UL Standard 1598, 8750
To be installed in accordance with NEC,
using Class 2 24V power supply or constant voltage
transformer only!
Power Requirements:
Power Source
20W Transformer
40W Transformer
60W Transformer
3.75 AMP (90W)
96W Transformer
150W Transformer
200W Transformer
300W Transformer
Product Dimensions:
*Dimensions show in inches
Installation Instructions:
Max Length
60” (15.9 W)
126” (33W)
183” (48W)
274” (72W)
292” (76.8W)
457” (120W)
609” (160W)
914 (240 W)
*70% brightness at 130”. Longer strips
should be powered from the center to avoid
further voltage drop.
inspiredled.com
1. Clean desired mounting surface(s) and test all products prior to installation.
2. Terminate iDea Series Screw Terminal Connector or solder 18AWG-22AWG
wire directly to LED strip copper pads.
3. Temporarily mount LED flex strips using scotch or painters tape.
4. If using a low-voltage in-line switch or dimmer, connect the accessory to
the LED strip using a low-voltage cable.
4. Connect 12VDC Class 2 Power Supply to in-line accessory or LED strip.
5. Test lighting system. When satisfied with the placement, peel adhesive
backing from components and press firmly to adhere to surface.
Troubleshooting: If LEDs are flickering, double check connection to be sure flex
is fully inserted and secured, if no lights turn on check polarity to be sure they
are properly matched.
orders@inspiredled.com
(480) 941-4286
很抱歉,暂时无法提供与“24V-COB-4000K-12M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.848951+1.40425
- 国内价格 香港价格
- 240+10.84331240+1.40352
