12V-SB-RGB-5M
12V-SB-RGB-5M
    INSPIREDLED
    LED 照明 COB、引擎、模块 LED 引擎 - 红色,绿色,蓝色(RGB) 线性灯条,弹性
12V-SB-RGB-5M 数据手册
Spectrum Series RGB 12V Super Bright RGB Flex The Spectrum Series 12V RGB system from Inspired LED is a creative, customizable way to add a splash of color to your world! Our flexible strips feature a series of color changing LED diodes encased in silicone for increased durability. Using compatible connectors and controllers, you can create a unique system of light and color suited for almost any application. SKU: 12V-SB-RGB Product Features:        Specifications: Color changing 5050 RGB diodes Custom lengths or 12 meter reels Low profile design (10 mm x 2mm) Minimal heat production- no IR or UV light Adhesive mounts to almost any flat surface European Union CE, RoHS compliant To be used with compatible 12V 4-conductor RGB products     Power: 12V DC, 5 Watts/foot 60 LEDs/meter (18 LEDs/foot) Cut points every 1.625 inches Rated to last up to 100,000 hours To be installed in accordance with NEC, compatible with non-dimmable single output 12V power supplies only Total Length 1.6” to 463” .40” Wiring Diagram: - PWR 12VDC Power RGB Controller B G R V+ + .55” per each LED .09” Installation Instructions: RGB Light Strip PWR OUTPUT RGB Amplifier B G R V+ + - INPUT V+ R G B 12VDC Power 1. Clean desired mounting surface(s) and test all products prior to installation 2. Temporarily mount RGB flex strips in desired locations using scotch or painter’s tape 3. Terminate RGB strips with compatible 4-conductor end connectors or direct solder leads 4. Run 4-conductor cable from LED system to RGB controller and/or RGB amplifier 5. Using 4-conductor cable, connect RGB controller and/or RGB amplifier to 12VDC power supply 6. When satisfied with placement & functionality, peel adhesive backing from LED strips and press firmly to secure in place RGB Light Strip inspiredled.com orders@inspiredled.com (480) 941-4286
12V-SB-RGB-5M
1. 物料型号:12V-SB-RGB 2. 器件简介:该系统是一系列可定制的12V RGB柔性灯带,采用硅胶封装的5050 RGB二极管,具有增强的耐用性。 3. 引脚分配:文档中提供了RGB放大器和RGB灯带的接线图,包括12VDC电源、RGB信号和控制器的连接方式。 4. 参数特性: - 电压:12V直流 - 功率:每英尺5瓦 - LED数量:每米60个(每英尺18个) - 寿命:长达10万小时 - 热产生量低,无红外或紫外线光 - 可定制长度或12米卷装 - 低剖面设计(10毫米 x 2毫米) - 可粘贴在几乎任何平面上 5. 功能详解:使用兼容的连接器和控制器,可以创建适合几乎所有应用的独特光和颜色系统。 6. 应用信息:适用于需要定制颜色和光线的场合,需与兼容的12V 4线RGB产品一起使用。 7. 封装信息:符合欧盟CE和RoHS标准。
安装说明包括清洁安装表面、使用胶带临时固定灯带、使用兼容端连接器或直接焊接引线、连接控制器和放大器到12VDC电源等步骤。
12V-SB-RGB-5M 价格&库存
很抱歉,暂时无法提供与“12V-SB-RGB-5M”相匹配的价格&库存,您可以联系我们找货
12V-SB-RGB-5M
库存:5206
12V-SB-RGB-5M
库存:5206
