601-4200
601-4200
    INTEGRITY
    9X9 PRE-WET WIPER LASER SEALED
601-4200 数据手册
integrity TM CLEANROOM PRODUCTION SOLUTIONS TECHNICAL DATASHEET PRODUCT Integrity Pre-Wetted Wipe 601-4200 FEATURES DESCRIPTION Integrity Cleanroom pre-wetted wipe is a 100% Polyester wipe, pre-saturated with blended 70% semiconductor grade IPA (Isopropyl Alcohol) and 30% deionized water (DI). It is packed in a resealable zip-lock bag for easier wipe access while preserving wipe cleanliness and reducing solvent evaporation. • • • • • • APPLICATIONS This product is recommended for use in a cleanroom ISO 4-7 (Class 10-10,000). This pre-wetted wipe is engineered for use in cleaning of critical surfaces and ideal for removing different cleaning and disinfecting residues in required environments. The wipe is designed for general cleaning in biotech, pharmaceutical, semiconductor and medical device industries. Laser sealed edge for reduced fiber contamination The pre-wet solution increases cleaning efficiency and cleaning protocol consistency Pre-wetted with specified IPA/DI water to achieve optimum 38% saturation level 100% continuous filament, double-knit polyester fiber Vacuum packaged Product code and lot traceable PRODUCT CODE DESCRIPTION SIZE (INCH) IPA/DI % QUANTITY 601-4200 Pre-wetted Wipe 9x9 70/30 75 wipes/bag, 2 bags/pack, 4 packs/case, 600 wipes/case, carton lined To request a quotation or for more information, please call +1 512-713-0127 email sales@integritycleanroom.com or visit www.integritycleanroom.com IMPORTANT: This data sheet and its contents (the “Information”) belong to Integrity Cleanroom or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but Integrity Cleanroom assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where Integrity Cleanroom was aware of the possibility of such loss or damage arising) is excluded. © Integrity Cleanroom. 601-4200 - Pre-wetted wipe | 14 May 2021 9:22 am V1 integrity TM CLEANROOM PRODUCTION SOLUTIONS TECHNICAL DATASHEET SPECIFICATIONS (IN DRY STATE ) VALUE TEST METHOD Basis weight 140 +/- 5gsm TAPPIT-410 Thickness 0.48 - 0.56 mm - Absorbency Capacity Rate ≥ 300 mL/m2 < 1 sec IEST-RP-CC004.3, Sec 8.1/Sec 8.2 Particle Counts APC ≥ 0.5 μm 50 counts/pc IEST-RP-CC003.2, Helmke drum @10rpm LPC ≥ 0.5 μm 7.0 x 106 counts/m2 IEST-RP-CC004.3, Sec 6.1.3/Sec 6.2.1 Fiber >100 μm 593 counts/m2 (IEST-RP-CC004.3, Sec 6.1.4, 6.2.2.1, 6.2.2.2) Non Valatile Residue (NVR) DI Water IPA Organics by FTIR 0.0023 g/m2 0.018 g/m2 IEST-RP-CC004.3, Sec 7.1.2 No silicone oil, Amide, DOP detected IONICS, IC Sodium (Na) Potassium (K) Calcium (Ca) Magnesium (Mg) Chloride (Cl) 0.097 ppm 0.04 ppm 0.085 ppm 0.001 ppm 0.126 ppm IEST-RP-CC004.3, Sec 7.2.2 Data shown are typical values and should not be used as specifications To request a quotation or for more information, please call +1 512-713-0127 email sales@integritycleanroom.com or visit www.integritycleanroom.com IMPORTANT: This data sheet and its contents (the “Information”) belong to Integrity Cleanroom or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but Integrity Cleanroom assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where Integrity Cleanroom was aware of the possibility of such loss or damage arising) is excluded. © Integrity Cleanroom. 601-4200 - Pre-wetted wipe | 14 May 2021 9:22 am V1
601-4200 价格&库存
很抱歉,暂时无法提供与“601-4200”相匹配的价格&库存,您可以联系我们找货
库存:19950
