MOT-IG-30GM 1:189
MOT-IG-30GM 1:189
    ISL
    30MM PLANETARY GEAR MOTOR - BRUS
MOT-IG-30GM 1:189 数据手册
ø30mm Planetary Gear Motor Carbon - Brushed MOT-IG-30GM 1:100 Online ID#: PGM-30-12-100-74-03 Our Planetary Gear Motors are an inline solution providing excellent torque output at various speeds. They are equiped to handle varying loads and are best for intermittent duty operation. With endless performance combinations, we have a fully tailored gear motor solution for you. Contact Us for alternative solutions! Specifications Gearhead Type: Motor Type: Rated Voltage: Rated Speed: Rated Torque: Rated Current: Planetary Carbon - Brushed 12V DC 63 rpm 7 kg.cm 0.95 A No-Load Speed: No-Load Current: Stall Torque: Max. Power: Reduction Ratio: Termination Style: 74 rpm (+/- 10%) < 0.25 A 50 kg.cm 9.40 W 100:1 Terminals * Gearbox limitations are set at 40 kg.cm, operating past this torque limit may create premature failure. Dimensions units: mm Performance Curve © 2022 ISL Products International Ltd. Specifications subject to change without notice. ISL Products International Ltd. • 572 Walt Whitman Rd., Suite 100 • Melville, NY 11747 • T 516-937-3475 • www.islproducts.com
MOT-IG-30GM 1:189 价格&库存
很抱歉,暂时无法提供与“MOT-IG-30GM 1:189”相匹配的价格&库存,您可以联系我们找货
