MOT-IG-32PGM-10KG
MOT-IG-32PGM-10KG
    ISL
    32MM PLANETARY GEAR MOTOR - BRUS
MOT-IG-32PGM-10KG 数据手册
ø32mm Planetary Gear Motor Carbon - Brushed MOT-IG-32PGM-10KG Our Planetary Gear Motors are an inline solution providing excellent torque output at various speeds. They are equiped to handle varying loads and are best for intermittent duty operation. With endless performance combinations, we have a fully tailored gear motor solution for you. Contact Us for alternative solutions! Specifications Gearhead Type: Motor Type: Rated Voltage: Rated Speed: Rated Torque: Rated Current: Planetary Carbon - Brushed 12V DC 38 rpm 19 kg.cm 1.6 A No-Load Speed: No-Load Current: Stall Torque: Max. Power: Reduction Ratio: Termination Style: 43 rpm (+/- 10%) < 410 mA 145 kg.cm 16 W 139:1 Terminals Dimensions units: mm Performance Curve © 2022 ISL Products International Ltd. Specifications subject to change without notice. ISL Products International Ltd. • 572 Walt Whitman Rd., Suite 100 • Melville, NY 11747 • T 516-937-3475 • www.islproducts.com
MOT-IG-32PGM-10KG 价格&库存
很抱歉,暂时无法提供与“MOT-IG-32PGM-10KG”相匹配的价格&库存,您可以联系我们找货
