MOT-IG42-12V-3600
MOT-IG42-12V-3600
    ISL
    42MM PLANETARY GEAR MOTOR - BRUS
MOT-IG42-12V-3600 数据手册
ø42mm Planetary Gear Motor Carbon - Brushed MOT-IG42-12V-3600 Online ID#: PGM-42-12-3600-2-01 Our Planetary Gear Motors are an inline solution providing excellent torque output at various speeds. They are equiped to handle varying loads and are best for intermittent duty operation. With endless performance combinations, we have a fully tailored gear motor solution for you. Contact Us for alternative solutions! Specifications Gearhead Type: Motor Type: Rated Voltage: Rated Speed: Rated Torque: Rated Current: Planetary Carbon - Brushed 12V DC 1.65 rpm 861 kg.cm * 4.50 A No-Load Speed: No-Load Current: Stall Torque: Max. Power: Reduction Ratio: Termination Style: 2 rpm (+/- 10%) < 0.90 A > 1,264 kg.cm 29 W 3,600:1 Terminals * Gearbox limitations are set at 250 kg.cm, operating past this torque limit may create premature failure. Dimensions units: mm Performance Curve © 2022 ISL Products International Ltd. Specifications subject to change without notice. ISL Products International Ltd. • 572 Walt Whitman Rd., Suite 100 • Melville, NY 11747 • T 516-937-3475 • www.islproducts.com
MOT-IG42-12V-3600 价格&库存
很抱歉,暂时无法提供与“MOT-IG42-12V-3600”相匹配的价格&库存,您可以联系我们找货
