MOT-IG52GM 24V-L
MOT-IG52GM 24V-L
    ISL
    52MM PLANETARY GEAR MOTOR - BRUS
MOT-IG52GM 24V-L 数据手册
ø 52mm Planetary Gear Motor Carbon - Brushed MOT-IG52GM 24V-L Our Planetary Gear Motors are an inline solution providing excellent torque output at various speeds. They are equiped to handle varying loads and are best for intermittent duty operation. With endless performance combinations, we have a fully tailored gear motor solution for you. Contact Us for alternative solutions! Specifications Gearhead Type: Motor Type: Rated Voltage: Rated Speed: Rated Torque: Rated Current: Planetary Carbon - Brushed 24V DC 186 rpm 19 kg.cm 2.9 A No-Load Speed: No-Load Current: Stall Torque: Max. Power: Reduction Ratio: Termination Style: 210 rpm (+/- 10%) < 600 mA 164 kg.cm 88 W 19:1 Terminals Dimensions units: mm Performance Curve © 2022 ISL Products International Ltd. Specifications subject to change without notice. ISL Products International Ltd. • 572 Walt Whitman Rd., Suite 100 • Melville, NY 11747 • T 516-937-3475 • www.islproducts.com
MOT-IG52GM 24V-L 价格&库存
很抱歉,暂时无法提供与“MOT-IG52GM 24V-L”相匹配的价格&库存,您可以联系我们找货
