MOT-RA37GM12V330R
MOT-RA37GM12V330R
    ISL
    37MM SPUR GEAR MOTOR - BRUSHED,
MOT-RA37GM12V330R 数据手册
ø 37mm Spur Gear Motor Carbon - Brushed MOT-RA37GM12V330R Our Spur Gear Motors are an inline solution providing ample torque output at various speeds. They are best for intermittent duty operation. With endless performance combinations, we have a fully tailored gear motor solution for you. View Alternative Solutions! Specifications Gearhead Type: Motor Type: Rated Voltage: Rated Speed: Rated Torque: Rated Current: Spur Carbon - Brushed 12V DC 330 rpm 2.5 kg.cm 1.6 A No-Load Speed: No-Load Current: Stall Torque: Max. Power: Reduction Ratio: Termination Style: 375 rpm (+/- 10%) < 300 mA 21 kg.cm 20 W 16:1 Terminals Dimensions mm units: mm Performance Curve © 2022 ISL Products International Ltd. Specifications subject to change without notice. ISL Products International Ltd. • 572 Walt Whitman Rd. ,Ste 100 • Melville, NY 11747 • T 516-937-3475 • www.islproducts.com
MOT-RA37GM12V330R 价格&库存
很抱歉,暂时无法提供与“MOT-RA37GM12V330R”相匹配的价格&库存,您可以联系我们找货
