P.S-I-81243-A
P.S-I-81243-A
    ISL
    24VAC - RAPID START BALLAST - UV
P.S-I-81243-A 数据手册
Electronic Ballast for UV Bulbs 24VAC - "RS" Rapid Start P.S-I-81243-A This electronic ballast is designed to operate ultraviolet quartz germicidal lamps at 24VAC, a common industry voltage. It's equiped with push style terminals for seamless installation and has Intertek approvals to UL 935 standards. Contact Us for alternative solutions! Electrical Specifications Lamp Type: Input Voltage: Lamps Operated: Input Power (W): Line Current (A): Power Factor: THD: Lamp Voltage (V): Ballast Type: Current Crest Factor: GPH212T5 24VAC 1 14.28 0.738 0.086 38 25 Rapid Start (RS) < 1.7 Lamp Current: Voltage Transients: 420mA (+/- 10%) ANSI 62.41 Environmental Specifications Sound Rating: Weight Class A 12.9 oz Min. Operating Temp: Max. Case Temp: 0°C / 32°F 70°C / 158°F Protections Input Protection: Output Protection Fuse EOL Dimensions (in.) Approvals: UL.935 / CSA.C22.2 Class "P"/1 Outdoor Wiring Diagram © 2020 ISL Products International Ltd. Specifications subject to change without notice. ISL Products International Ltd. • 235 Robbins Ln.,Ste 270 • Syosset, NY 11791 • T 516-937-3475 • www.islproducts.com
P.S-I-81243-A 价格&库存
很抱歉,暂时无法提供与“P.S-I-81243-A”相匹配的价格&库存,您可以联系我们找货
