P.S-I-81338-A
P.S-I-81338-A
    ISL
    110/240VAC UVC BALLAST - PROGRAM
P.S-I-81338-A 数据手册
Electronic Ballast for UV Bulbs 110 ~ 240VAC - "PS" Program Start P.S-I-81338-A This electronic ballast is designed to operate different ultraviolet quartz germicidal lamps at 110~240VAC. It's equiped with push style terminals for seamless installation and has Intertek approvals, UL 935 standards. Contact Us for alternative solutions! Electrical Specifications Lamp Type: Input Voltage: Lamps Operated: Input Power (W): Line Current (A): Power Factor: THD: Lamp Voltage (V): Ballast Type: Current Crest Factor: GPH212T5 GPH287T5 GPH357T5 GPH436T5 100 / 240VAC 100 / 240VAC 100 / 240VAC 100 / 240VAC 1/1 1/1 1/1 1/1 16.19 / 17.96 20.40 / 22.44 25.01 / 25.71 29.27 / 28.81 0.164 / 0.093 0.207 / 0.111 0.253 / 0.124 0.293 / 0.137 0.967 / 0.803 0.98 / 0.84 0.986 / 0.857 0.982 / 0.872 15.6 / 35.6 11.3 / 13.8 7.2 / 12.2 6.9 / 10.4 25 34 42 51 Program Start (PS) < 1.7 Lamp Current: Voltage Transients: 425mA (+/- 10%) ANSI 62.41 Environmental Specifications Sound Rating: Weight Class A Min. Operating Temp: Max. Case Temp: 0°C / 32°F 70°C / 158°F Protections Input Protection: Output Protection Fuse EOL Dimensions (in.) Approvals: UL.935 / CSA.C22.2 Class "P"/1 Outdoor Wiring Diagram © 2021 ISL Products International Ltd. Specifications subject to change without notice. ISL Products International Ltd. • 572 Walt Whitman Rd., Suite 100 • Melville, NY 11747 • T 516-937-3475 • www.islproducts.com
P.S-I-81338-A 价格&库存
很抱歉,暂时无法提供与“P.S-I-81338-A”相匹配的价格&库存,您可以联系我们找货
