IS31AP2112-ZLS2-TR
IS31AP2112-ZLS2-TR
    LUMISSIL
    SOIC28_EP
    放大器 IC 2 通道(立体声) D 类 28-eTSSOP
IS31AP2112-ZLS2-TR 数据手册
IS31AP2112 2×20W STEREO CLASS-D AUDIO AMPLIFIER WITH POWER LIMIT Preliminary Information August 2020 DESCRIPTION FEATURES The IS31AP2112 is a high efficiency stereo Class-D audio amplifier with adjustable power limit function. The loudspeaker driver operates from 4.5V~26V supply voltage and analog circuit operates at 5V supply voltage. It can deliver 20W/CH output power into 8Ω loudspeaker within 1% THD+N at 24V supply voltage and without external heat sink when playing music.          IS31AP2112 provides parallel BTL (Mono) application, and it can deliver 40W into 4Ω loudspeaker at 24V supply voltage. The adjustable power limit function allows user to set a voltage rail lower than half of 5V to limit the amount of current through the speaker. Output DC detection prevents speaker damage from long-time current stress. IS31AP2112 provides the spread spectrum function to improve EMI performance. The output short circuit and over temperature protection include auto-recovery feature. APPLICATIONS      TV audio Boom-box Powered speaker Monitors Consumer audio equipment             Single supply voltage 4.5V ~ 26V for loudspeaker driver Built-in LDO output 5V for others Loudspeaker power from 24V supply BTL Mode: 20W/CH into 8Ω @
IS31AP2112-ZLS2-TR 价格&库存
很抱歉,暂时无法提供与“IS31AP2112-ZLS2-TR”相匹配的价格&库存,您可以联系我们找货
IS31AP2112-ZLS2-TR
