IT6502D
IT6502D
    ITECH(艾德克斯)
    0 ~ 80V 输出 工作台式(DC 至 DC) 电源 模拟 0 ~ 60A 输出 800W 特性 可编程
IT6502D 数据手册
YOUR POWER TESTING SOLUTION IT6500 Wide Range High-Power DC Power Supply High-power Wide-range Fast curve changing without overshoot Maintain excellent performance after paralleling Simple programming on the front panel Full protection APPLICATIONS Automotive Electronics Electric Vehicle Battery Test Battery Simulation Civil avionics Solar Panel I-V Curve Simulation LED Overcome the toughest high power test challenges With ITECH’s latest technology, the IT6500 series offers a full-featured high-performance power test solution. With fast response these DC power supplies provide users with a new level of power supply performance. From 800W to 6kW, the maximum output voltage and current is up to 1000V and 240A respectively. With its autoranging capabillity, it also has a super wide range of voltage and current applications. Users can choose the power supply that fits their testing requirements perfectly. Choose the right power supplies that fit your test requirements IT6502D/IT6512/IT6512A/ IT6513/IT6513A Good performance and compact size, designed for general purpose testing in R&D and production. IT6500C/D series High performance with stable output, designed for automobile, green energy, high speed testing, high-power testing etc. IT6502D 800W 80V/60A/800W 1200W 80V/60A/1200W 1800W 80V/120A/1800W 3kW 80V/120A/3kW 6kW IT6512/A IT6512C/D IT6522C/D IT6532C/D 80V/240A/6kW IT6513/A 150V/30A/1200W IT6513C/D 200V/60A/1800W IT6523C/D 200V/60A/3kW IT6533C/D 200V/120A/6kW IT6514C/D 360V/30A/1800W IT6524C/D 360V/30A/3kW IT6534C/D 360V/60A/6kW IT6515C/D 500V/20A/1800W IT6525C/D 500V/20A/3kW IT6535C/D 500V/40A/6kW IT6516C/D 750V/15A/1800W IT6526C/D 750V/15A/3kW IT6536C/D 750V/30A/6kW IT6517C/D 1000V/10A/1800W IT6527C/D 1000V/10A/3kW IT6537C/D 1000V/20A/6kW * For higher power test, please contact ITECH. 01 IT6500 Wide-range High-power DC Power Supply Your Power Testing Solution IT6500 Wide-range High-power DC Power Supply Fast curve changing without overshoot CC & CV Priority Function Fast response Independent settable slew rate in different modes IT6500C series can be used as a power supply and an electronic load. As a power supply, CV, CC, CP modes are available. As an electronic load, CC and CP mode are available. IT6500C supports independent adjustable rise/fall time setting in different modes. For every single model of IT6500C/D series, no matter it is a single unit or multiple units paralleled together, the rise and fall time of each power supply in IT6500C/D series are the same. Take IT6522C as an example: To conquer the demanding testing requirements existing for a long time in various applications, ITECH developed an innovative industry-leading CV & CC priority concept. The IT6500 is available for high-speed test applications with-out overshoot. Users can chose the desired output mode. Voltage high-speed mode or current no overshoot mode by choosing the loop response speed and loop operation mode. It is suitable for high-power integrated circuit test, solar array simulation and the transient simulation / characteristic of automotive electronics. Within 30V voltage range, with 0-90% load, up and down speed
IT6502D 价格&库存
很抱歉,暂时无法提供与“IT6502D”相匹配的价格&库存,您可以联系我们找货
