F2780Y001L-001
F2780Y001L-001
    ITG
    1.5A CAT6A DATA LINE EMI FILTER
F2780Y001L-001 数据手册
F2780Y001L-001 1. Features : • CAT6a filter provides clean signal and data into Shielded rooms or MRI rooms through RJ45 Connector. The filters provide: 50dB attenuation from 30MHz to 70MHz. 100dB attenuation from 100MHz to 1GHz. 120dB attenuation from 1GHz to 10GHz. • Voltage Rating: 100VDC • Hi-Pot: Line to Ground: 200VDC for 2 sec • Ambient Temperature Range: -25°C To +85°C • Filter components are encapsulated in a plated metal enclosure • The filters comply with UL and cUL construction requirements 2. Electrical Characteristics : ITG Part Number Operating Current (A) at 60ºC Output terminal F2780Y001L-001 1.5 RJ45 Plug 3. Schematic: Output Input ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision A.1, March 3, 2020 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. F2780Y001L-001 4. Mechanical Dimensions in mm, ±2mm: ● ITG Part Number L W H F2780Y001L-001 200.0 70.0 50.0 ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision A.1, March 3, 2020 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
F2780Y001L-001 价格&库存
很抱歉,暂时无法提供与“F2780Y001L-001”相匹配的价格&库存,您可以联系我们找货
