CW2400J
CW2400J
    CHEMTRONICS
    EPOXY
CW2400J 数据手册
CHEMTRONICS Technical Data Sheet TDS # CW2400 CircuitWorks Conductive Epoxy PRODUCT DESCRIPTION CircuitWorks Conductive Epoxy is a two part, silver epoxy used in prototype, repair and general conductive bonding applications. CW2400 features strong mechanical bonds, excellent electrical conductivity, and quick room temperature curing. CircuitWorks Conductive Epoxy bonds aggressively to a wide variety of materials.  Two-component product  Simple mixing ratios  Excellent electrical conductivity  Fast curing  High strength bond  Bonds dissimilar surfaces  Operating temperature range from  -91°C (-131°F) to 100°C (212°F) TYPICAL PRODUCT DATA AND PHYSICAL PROPERTIES Composition Material Part A Part B Specific Gravity (Parts A & B Mixed) Cured Compound Volume Resistivity Thermal Conductivity Cal-cm/sec-cm2 -°C BTU-in/hr-ft2 -°F W/m°K Operating Temperature Range Lap Shear (ASTM D-1002) Shore Hardness TYPICAL APPLICATIONS CircuitWorks Conductive Epoxy may be used for electronics applications including:  Conductive Bonds Between Heat Sensitive Components  Solderless Surface Mount Connections  Circuit Board Trace Repair  Static Discharge and Grounding  Solder Repair  Conductive Structural Adhesions Epoxy Hardener 4.0 Dropping Point (ASTM D-2266) 1200 lbs/in. >70 None @ 650°F (343°C) Adhesion Excellent Cured Flexibility Excellent Chemical Resistance Excellent Moisture Resistance Good Typical Thickness Shelf life 5 mil 9 months Conditions: Store at temperatures below 77° F COMPATIBILITY CircuitWorks Conductive Epoxy is generally compatible with most materials used in printed circuit board fabrication. As with any adhesive/sealant, compatibility with substrate should be determined on a non-critical area prior to use. USAGE INSTRUCTIONS AVAILABILITY CW2400 7g/ 0.25 oz. Adhesive & 7g/ 0.25 oz. Hardener CW2400J 10g/ 0.35 oz. Adhesive & 10g/ 035 oz. Hardener TECHNICAL & APPLICATION ASSISTANCE Read MSDS carefully prior to use. Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401. Cleaning: For best results, clean the board with one of Chemtronics Electro-Wash or Pow-R-Wash cleaners in order to remove any surface contamination which may prevent adequate material contact. NOTE: Mixing: Mix equal amounts (1:1) by weight or volume of Part A and Part B. Mix thoroughly for 2 minutes and apply within 8 minutes. Thinning: Do not attempt to thin. Curing: Curing times and electrical conductivity depend primarily on temperature. For fastest curing times, maximum conductivity and adhesion, cure the bond between 150-250°F (65-121°C) for 5-10 minutes. CircuitWorks Conductive Epoxy can be room temperature cured at or above 75°F (25°C), for 4 hours. Maximum conductivity and bond strength are achieved in 24 hours. Curing at temperatures below 75°F (25°C) will result in a loss of conductivity and adhesion. Pot Life: 8-10 Minutes at 75°F (25°C) after mixing. This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. CHEMTRONICS 8125 COBB CENTER DRIVE KENNESAW, GA 30152 1-770-424-4888 DISTRIBUTED BY: REV. K (08/13)
CW2400J 价格&库存
很抱歉,暂时无法提供与“CW2400J”相匹配的价格&库存,您可以联系我们找货
