CHEMTRONICS®
TDS # CW9000
Technical Data Sheet
CircuitWorks® Flux Remover Pens
TYPICAL PRODUCT DATA AND
PHYSICAL PROPERTIES
PRODUCT DESCRIPTION
CircuitWorks® Flux Remover Pens are
designed specifically to remove each type of
flux. The Rosin Flux Remover Pen quickly
cleans type R, RMA, and RA flux residues.
The No Clean Flux Remover Pen precisely
removes both organic and synthetic low solid
no clean fluxes.
A pen for removing rosin flux residues
A pen for spot removal of no clean fluxes
Penetrates hard to reach areas
Marker pen dispenser provides controlled
and exact application
Removes ionic and non-ionic residues
Excellent material compatibility
Fast drying
TYPICAL APPLICATIONS
CircuitWorks® Flux Remover Pens remove
flux residues and clean precise areas on:
Printed Circuit Boards
Chip Carriers
Heat Sinks
Surface Mount Device Pads
Switches
Sockets
Flash Point (TCC)
70 °F (21 °C)
Vapor Density (air=1)
>1
Surface Tension
21.3 dyne/cm
Appearance
Clear Liquid
Odor
Alcohol
Flash Point (TCC)
102 °F (39 °C)
>1
Surface Tension
17.7 dyne/cm
Appearance
Clear Liquid
Odor
Characteristic
Water Soluble Flux Remover Pen
Flash Point (TCC)
Surface Tension
Appearance
Odor
Shelflife
RoHS/WEEE
Status
70 °F (21 °C)
>1
21.1 dyne/cm
Clear Liquid
Alcohol
5 years
COMPATIBILITY
generally compatible with most materials used
in the electronics industry. As with any
cleaning agent, material compatibility should
be determined on a non-critical area prior to
use.
USAGE INSTRUCTIONS
For industrial use only.
Read MSDS carefully prior to use.
Hold pen vertically and briefly depress tip to
start liquid flow. Rub pen tip on surface to be
cleaned. Wipe tip on a ControlWipe™ dry
wipe to remove buildup.
CAUTION: Product is Flammable - Do not use
near sources of ignition and energized equipment.
AVAILABILITY
CW9100 9 gm (0.32 oz) No Clean Flux Remover Pen
CW9200 8 gm (0.28 oz) Rosin Flux Remover Pen
NOTE: This information is believed to be accurate. It is
intended for professional end users having the skills to
evaluate and use the data properly.
CHEMTRONICS® does not guarantee the accuracy of the
data and assumes no liability in connection with damages
incurred while using it.
ITW CHEMTRONICS
MSDS #3114
SECTION 1: CHEMICAL PRODUCT AND COMPANY INFORMATION
Product Information: 800-TECH-401
Product Identification
CIRCUITWORKS® NO CLEAN FLUX REMOVER PEN
Product Code: CW9100
SECTION 2: COMPOSITION/INFORMATION ON INGREDIENTS
Chemical Name
CAS No.
Hexamethyldisiloxane
107-46-0
Propylene glycol methyl ether
107-98-2
N-methyl pyrrolidone
872-50-4
Acetone
67-64-1
Wt. % Range
60.0-70.0
3.0-7.0
1.0-8.0
10.0-25.0
SECTION 3: HAZARD IDENTIFICATION
Emergency Overview:Clear, colorless liquid with a mild sweet odor. This product is flammable. Liquid will irritate eyes and skin under repeated or prolonged
exposure. Breathing high concentrations of product may produce drowsiness and a headache.
Potential Health Effects:
Eyes: Liquid and vapors of this product are irritating and can cause pain, tearing, reddening and swelling accompanied by a stinging sensation.
Skin: Contact causes skin irritation. Symptoms may include redness and burning.
Ingestion: Harmful if swallowed. Large amounts may be irritating to the mouth, throat and stomach. May cause vomiting.
Inhalation: Harmful if inhaled. High concentrations in immediate area can displace oxygen and cause dizziness, unconsciousness and even death, with longer exposure.
Keep people away from such vapors without self-contained breathing apparatus.
Preexisting Medical Conditions Aggravated by exposure: Skin, eyes, liver, kidneys
SECTION 4: FIRST AID MEASURES
Eyes:
Immediately flush with plenty of water. After initial flushing, remove any contact lenses and continue flushing for at least 15 minutes. Have eyes examined
and tested by medical personnel if irritation develops or persists.
Skin: Wash skin with soap and water. Remove contaminated clothing. Get medical attention if irritation develops or persist. Wash clothing separately before reuse.
Ingestion: If swallowed, do not induce vomiting. Give lukewarm water to victim (pint) if victim is conscious and alert. Keep head below knees to minimize chance of
aspirating material into the lungs. Never give anything by mouth to an unconscious person. Get medical attention immediately.
Inhalation: Remove to fresh air. If not breathing, give artificial respiration. If breathing is difficult, give oxygen. Get medical attention.
SECTION 5: FIRE FIGHTING MEASURES
Flash Point: 102 °F (39C) (TCC)
LEL/UEL: Not established (% by volume in air)
Extinguishing Media: Use alcohol foam, carbon dioxide or water spray when fighting fires involving this material.
Fire Fighting Instructions: As in any fire, wear self-contained breathing apparatus (pressure demand, OSHA/NIOSH approved or equivalent) and full protective gear.
SECTION 6: ACCIDENTAL RELEASE MEASURES
Large Spills: Not likely to occur.
Small Spills: Absorb spill with inert material (i.e. dry sand or earth), then place in a chemical waste container for proper disposal.
SECTION 7: HANDLING AND STORAGE
Avoid prolonged or repeated contact with skin, eyes or clothing. Wash hands before eating. Use with adequate ventilation. Avoid breathing product vapor. Do not
reuse this container. Store in a cool dry place, away from heat, sparks or flames. Keep container tightly closed when not in use. Do not store in direct sunlight.
KEEP OUT OF REACH OF CHILDREN.
SECTION 8: EXPOSURE CONTROLS/PERSONAL PROTECTION
Exposure Guidelines:
CHEMICAL NAME
ACGIH TLV
OSHA PEL
OTHER
NA
NA
200 ppm*
100 ppm
100 ppm
150 ppm STEL
N-Methyl pyrrolidone
NA
NA
NA
Acetone
500 ppm
1000 ppm
750 ppm STEL
*Manufacturer’s Occupational Exposure Limit (OEL)
Work/Hygienic Practices: Good general ventilation should be sufficient to control airborne levels. Local exhaust ventilation may be necessary to control any air
contaminants to within their TLVs during the use of this product. If vapor concentration exceeds TLV, use NIOSH approved organic vapor cartridge respirator. Wear
safety glasses with side shields (or goggles) and rubber or other chemically resistant gloves when handling this material.
NFPA and HMIS Codes:
NFPA
HMIS
Health
1
1
Flammability
3
3
Reactivity
Personal Protection
B
SECTION 9: PHYSICAL AND CHEMICAL PROPERTIES
Physical State: Clear, colorless liquid
Odor: Mild solvent
pH: NA
Viscosity: >1 (Water =1)
Percent Volatile: 100 %
Solubility in Water: Negligible
Specific Gravity: 0.79 @75°F
Evaporation Rate: 1 (Air = 1)
Boiling Point:: 208F (98C) ( Hexamethyldisiloxane)
Page 1 of 2
ITW CHEMTRONICS
MSDS #3114
SECTION 10: STABILITY AND REACTIVITY
Stability: This product is stable.
Conditions to Avoid: Do not spray near open flames, red hot surfaces or other sources of ignition.
Incompatibility: Do not mix powdered alkali and alkaline earth metals or strong oxidizing agents.
Products of Decomposition: Thermal decomposition may release carbon monoxide, carbon dioxide and incompletely burned hydrocarbons.
Hazardous Polymerization: Will not occur.
Conditions to avoid: NA
SECTION 11: TOXICOLOGICAL INFORMATION
Inhalation:
rat TCLo
Skin:
Acetone
Propylene Glycol Methyl Ether
(rbt) LD50
(rbt) LD50
Ingestion:
Acetone
(rat) LD50
(rat) LD50
Propylene Glycol Methyl Ether (rat) LD50
150 ppm/6H
500 mg/24H MLD
8000 mg/kg
9500 mg/kg
Eye:
(rabbit)
Propylene Glycol Methyl Ether (human)
Acetone
(human)
Cancer Information: No ingredients listed as human carcinogens by NTP or IARC.
Reproductive effects: N-Methyl pyrrolidone
Teratogenic effects: none
5800 mg/kg
3914 mg/kg
5135 mg/kg
100 mg MOD
8 mg MLD
500 ppm
Mutagenic effects: none
SECTION 12: ECOLOGICAL INFORMATION
Environmental Impact Information
Avoid runoff into storm sewers and ditches which lead to waterways. Water runoff can cause environmental damage.
REPORTING
US regulations require reporting spills of this material that could reach any surface waters. The toll free number for
the US Coast Guard National Response Center is: 1-800-424-8802
SECTION 13: DISPOSAL CONSIDERATIONS
Dispose of in accordance with all federal, state and local regulations.
SECTION 14: TRANSPORTATION INFORMATION
Proper
UN Number
Shipping Name
Air:
Flammable liquids, n.o.s.
(Acetone )
Ground:
Consumer Commodity
ORM-D
UN 1993
NA
Hazard
Class
Sub.
Risk
Pkg.
Group
3
NA
II
NA
Hazard
Label
Flammable
Liquid
NA
ORM-D
Pkg.
Instr./Auth.
305
Max.
Quantity
5L
173.150
SECTION 15: REGULATORY INFORMATION
SECTION 313 SUPPLIER NOTIFICATION
This product contains the following toxic chemicals subject to the reporting requirements of Section 313 of the Emergency Planning and Community Right-To- Know
Act of 1986 (40 CFR 372).
CAS# 872-50-4
1.0-8.0%
This information should be included on all MSDSs copied and distributed for this material.
CALIFORNIA PROPOSITION 65: This product contains N-methyl pyrrolidone, a chemical known to the state of California to cause birth defects or other
reproductive harm.
All ingredients of this product are listed on the TSCA Inventory.
TOXIC SUBSTANCES CONTROL ACT (TSCA).
WHMIS: Class B3; Class D2B
This product has been classified according to the hazard criteria of the CPR and the MSDS contains all of the information required by the CPR.
SECTION 16: OTHER INFORMATION
Normal ventilation for standard manufacturing practices is usually adequate. Local exhaust should be used when large amounts are released.
To the best of our knowledge, the information contained herein is accurate. However, all materials may present unknown hazards and should be used with caution. In
particular, improper use of our products and their inappropriate combination with other products and substances may produce harmful results which cannot be
anticipated. Final determination of the suitability of any material is the sole responsibility of the user. Although certain hazards are described herein, we cannot
guarantee that these are the only hazards that may exist.
Page 2 of 2
很抱歉,暂时无法提供与“CW9200”相匹配的价格&库存,您可以联系我们找货
