HS-5876
HS-5876
    TECHSPRAY
    PLATO SLDER TIP BEVEL 5.0 MM
HS-5876 数据手册
PRODUCT CATALOG & APPLICATION GUIDE ® Quality Tools for Electronics Assembly and Repair ITW Chemtronics® is proud to offer Plato® tools for electronic soldering applications. Whether your requirements are for soldering tips, solder pots or cutters, Plato has the right solutions for your soldering requirements. Plato quality tools include: • Replacement soldering tips • Shear cutters • Solder pots YOUR ONE SOURCE FOR SOLDERING TIPS Plato is one of the largest manufacturers of soldering tips in the world, producing tips to fit all of the most popular soldering stations. The long life and fast heat recovery of Plato soldering tips increases soldering speed. Long Life Proprietary iron plating is optimized for lead-free solders, increasing tip life. Rapid Heat Recovery Plato soldering tips are constructed from highly conductive premium grade copper to transmit heat to the work more quickly. Rapid heat recovery enables more joints to be soldered per minute. Constructed with high-grade copper for maximum heat conductivity. • Solder accessories, sponges and flux bottles Coated with a proprietary iron plating for long life. Tips are coated with lead-free solder to protect against oxidation and improve heat transfer. Toll-Free Customer Support: Tel: 1-800-645-5244 Need Technical Information? Contact our Technical Hotline at: 1-800-TECH-401 (800-832-4401) 1-770-424-4888 ext 137 Email us at AskChemtronics@chemtronics.com or visit us at www.chemtronics.com We acknowledge the following trademarks: A.P.E.® is a registered trademark of Automated Production Equipment, Inc.; American Beauty® is a trademark of Assembly Technologies International, Inc.; Edsyn® is a registered trademark of Edsyn®; Ersa® is a registered trademark of Ersa. Esico® is a trademark of Electronic Soldering Iron Co.; Hakko® is a registered trademark of Hakko Metal Industries, Ltd.; Loner® is a registered trademark of Edsyn®; Metcal® is a registered trademark of O.K.® Industries; Pace® is a registered trademark of Pace, Inc.; Hexacon® Select-O-Trac® and Therm-O-Trac® are registered trademarks of Hexacon Electric Co.; Weller® is a registered trademark of Cooper Industries, Inc.; Ungar® is a registered trademark of Ungar®. Plato® is a registered trademark of Illinois Tool Works®. All rights reserved. Chemtronics® is a registered trademark of ITW Chemtronics®. All rights reserved. All other trademarks or registered trademarks included herein are the trademarks or registered trademarks of their respective owners. LEAD CUTTERS ® ® LEAD CUTTERS Plato cutters give you the precision of a high-end tool, but at a disposable cutter price. They flush cut component leads as large as 18 AWG copper wire (.040"/1.0mm). Assemblers love the effortless shearing action, comfort, and safety. Plato cutters use the shear cutting method, which requires 50% less operator effort and extends cutting life. The thin profile design is perfect for hard-to-reach areas in electronic assembly. Handles are cushioned for comfort all day, and automatically spring back to their original position after each use. OPTIONAL SAFETY GUARD 175 and 175LX cutters come with a lead catcher, which holds onto a trimmed lead until the shear is opened. This prevents leads from flying off, which can lead to eye injury or contaminate the assembly. Safety Guard PLATOSHEAR GENERAL PURPOSE LEAD CUTTER Our best-selling cutters! Precise, reliable cutting action at an economical price. Thin profile handle and light weight design is ideal for smaller hands. • Economical, disposable cutter • Thin blade profile for trimming in tight areas • Ergonomic handle design • Spring-back action 170LX • 175LX PLATOSHEAR LX ERGONOMIC, ESD-SAFE LEAD CUTTER Sculpted handle design made of ESD-safe material gives the Platoshear LX cutters the look and feel of a high-end shear cutter. • Ergonomic handled designed for comfort • ESD-safe handle to prevent static discharge 170LX 175LX 170 • 175 170 175 1755 1 cutter, 10/case 1 cutter w/safety guard, 10/case PLATO BIG SHEAR HEAVY DUTY CUTTER Cuts round and flat cable, co-ax, nickel, Kovar, and other wire with a clean shearing cut that reduces cable cut-end distortion. Lightweight design significantly reduces operator fatigue. • For heavy gauge wire • Cushioned rubber handles • Spring-back action 1 cutter, 10/case 1 cutter w/safety guard, 10/case 1755 ESD-safe For more information: askchemtronics@chemtronics.com 1 cutter, 10/case Customer Service 1-800-645-5244 www.chemtronics.com 3 SOLDER POTS ® ® SOLDER POTS Plato® solder pots are known around the world for their durable construction and precise controls. Ideal for tinning lead wires, pre-tinning small electrical parts, or dip soldering small assemblies and circuit devices. Porcelain Coated Crucibles Plato’s porcelain coated crucible is easy to clean and offers a long service life. Solder will not adhere to the porcelainized surface, allowing for easy maintenance. The coating also resists corrosion common with activated fluxes and high tin content solders. Ground stud is installed through coating to control ESD. Solder beads off the porcelain coating like water on a freshly waxed car SP-101/P • SP-201P • SP301/P • SP401P GENERAL PURPOSE SOLDER POTS Plato general purpose solder pots control temperature ± 6°C through the use of a thermal timer switch with automatic correction for voltage fluctuations. • Safety heat shield & removable dross tray • 64mm dia. x 38mm deep crucible • 907g solder capacity • Adjustable leveling feet • All metal construction for ESD protection Product Crucible PRECISION ELECTRONIC SOLDER POTS Plato’s Precision Solder Pots exceed the requirements of military specifications ANSI J-STD-001B. The pots control temperatures to ±2.75°C of a preselected setting and have an LCD temperature display. Designed for voltage sensitive components. Electronics compensate for incoming power fluctuations, limiting transient voltage spiking to 2mV peak-to-peak. • High precision temperature control ± 2.75°C • LCD displays preset temperature and operating temperature • Safety heat shield & removable dross tray • 64mm dia. x 38mm deep crucible • 907g solder capacity • Adjustable leveling feet • All metal construction for ESD protection Product Crucible SP-500T Uncoated Iron Volts Watts Temp. Range 120 350 Ambient - 496oC SP-500TP Porcelain Coated Iron 120 350 Ambient - 496oC SO-150TP Porcelain Coated Iron 240* 350 Ambient - 496oC * 240V does not include plug. Power cable needs to have locally compatible plug stripped on. SP-600TP • SP-750TP HIGH CAPACITY SOLDER POTS High capacity pot for pre-tinning large assemblies and for use as a mini-wave. Precision electronic controls have the same features as listed above. Volts Watts Temp. Range • 102mm width x 152mm length x 102mm deep crucible • Large capacity – holds 14.5 kg of solder • Safety crucible cover • Adjustible leveling feet • All metal construction SP-101 Uncoated Iron 120 350 260oC - 524oC SP-101P Porcelain Coated Iron 120 350 260oC - 524oC SO-201P Porcelain Coated Iron 240* 350 260oC - 524oC SP-301 Uncoated Iron 120 500 260oC - 593oC Product Crucible Volts Watts Temp. Range SP-301P Porcelain Coated Iron 120 500 260oC - 593oC SP-600TP Porcelain Coated Iron 120 1000 Ambient - 399oC SP-401P Porcelain Coated Iron 240* 500 260oC - 593oC SO-750TP Porcelain Coated Iron 240* 1000 Ambient - 399oC * 240V does not include plug. Power cable needs to have locally compatible plug stripped on. 4 SP-500T/P • SP-150TP For more information: askchemtronics@chemtronics.com * 240V does not include plug. Power cable needs to have locally compatible plug stripped on. Customer Service 1-800-645-5244 www.chemtronics.com BOTTLES ® BC-250 • SF-250 ® WATER & LIQUID DISPENSING BOTTLES DISPENSING BOTTLES Each bottle is available with standard plastic or with optional ESD-safe cover. Plato’s ESD-safe bottles are surrounded by permanently static dissipative sleeves that stay out of contact with flux and other liquids. This prevents conductive “hot spots” on the surface of the bottle. • • • • Polyethylene bottle, screw cap, and dispensing tube with 237ml capacity. Inexpensive way to wet sponges and dispense liquids without waste at the work bench. BC-250 SF-250 1 bottle, 1 bottle, ESD-safe Protects voltage sensitive devices from static discharge Meets ANSI J-STD-001B Meets the requirements of DOD-STD-1686 for containers Physical characteristics comply with MIL-B-81705, Type 2 FD-2 • FD-21 • SD-01 • SD-02 NEEDLE FLUX DISPENSERS Needle bottles are ideal for precisely controlled flux applications. Two different needle sizes are available: 0.25mm for low viscosity no-clean and aqueous fluxes, and 0.50mm for higher viscosity rosin-based fluxes. BC-250 • Dispense precise amount of flux without dripping, spilling, or waste • Unique, no leak design ESD-safe SB-2N • SF-B2HH SF-250 BRUSH SCRUB BOTTLES Brush bottles are a great way to aggressively but safely clean white flux residues, adhesives, and other difficult soils from electronic assemblies. Natural hog bristles are neutral charge and static dissipative when saturated. Pos-A-Loc® No Leak Assembly 0.25mm needle for No-Clean & Aqueous Fluxes FD-21 1 bottle SF-01 1 bottle, ESD-safe 0.50mm needle for Rosin-based Fluxes FD-2 1 bottle SF-02 1 bottle, ESD-safe ESD-safe • Inexpensive and safe method to spot clean PCB assemblies • Compatible with IPA, hexane, and acetone SB-2N SF-B2HH ESD-safe 1 bottle 1 bottle, ESD-safe ESD-safe SB-2N SF-B2HH FD-21 SF-01 FD-2 SF-02 For more information: askchemtronics@chemtronics.com Customer Service 1-800-645-5244 www.chemtronics.com 5 SPONGES & TINNER ® CS-14M—10 sponges/pack, 55mm x 70mm x 25mm thick Fits Weller 52241999 REPLACEMENT SPONGES Manufactured with pure cellulose (a wood derivative) which has the ability to absorb many times its weight in water. Also resistant to abrasion and tearing when wiping tips. Meets ANSI J-STD001B for low sulphur content and fine porosity. • Remove Surface Oxides • Remove Excess Solder CS-33—10 sponges/pack, 70mm x 114mm x 25mm thick Fits Weller EC-205 • Extend Tip Life CS-44—10 sponges/pack, 69mm x 69mm x 25mm thick Fits Weller TC-205 Cheap synthetic sponges, like common household sponges, are not recommended for tip cleaning. They contain colorings, plasticizers, stiffeners, and other contaminants which will shorter tip life. CS-17 PLATO CUT-TO-FIT SHEET For difficult to find sponge sizes or special applications, Plato offers full sheets of sponge material that can be trimmed to exact size. CS-44M—10 sponges/pack, 69mm x 69mm x 25mm thick Fits Weller TC-205 CS-47 METCAL & UNGAR COMPATIBLE REPLACEMENT SPONGES CS-47—10 sponges/pack, 53mm x 81mm x 25mm thick Fits Metcal STSS-YS3 and Ungar 455, UTC234 CS-17—1 sheet, 216mm x 432mm x 25mm thick CS-17/625—Thinner Economy Sponge (1 sheet, 216mm x 432mm x 16mm thick) CS-43 • CS-44/44M CS-36 (SCISSORS NOT INCLUDED) HAKKO COMPATIBLE REPLACEMENT SPONGES HEXACON COMPATIBLE REPLACEMENT SPONGES CS-9/625—10 sponges/pack, 89mm x 114mm x 16mm thick Fits Hexacon 8101, 8101C, 8121, 8121C CS-43—10 sponges/pack, 45mm x 102mm x 25mm thick Fits Hakko 926-029B CS-44—10 sponges/pack, 69mm x 69mm x 25mm thick Fits Hakko 609-0229, A-1042 CS-44M—10 sponges/pack, 69mm x 69mm x 25mm thick Fits Hakko 609-0229, A-1042 C-1 • CS-14/14M • CS-33 • CS-44/44M WELLER COMPATIBLE REPLACEMENT SPONGES CS-1—10 sponges/pack, 38mm x 54mm x 25mm thick Fits Weller SP-60 CS-36—10 sponges/pack, 57mm x 89mm x 25mm thick Fits Hexacon 8141, 8141C TT-95 TIP TINNER/TIP CLEANER Plato’s Tip Cleaner provides fast, efficient cleaning and re-tinning of highly oxidized soldering iron tips. This thermallystable compound is lead-free, environmentally safe, and in an ESD-safe container. Tip Cleaner brings oxidized tips back to life, which improves soldering speed. Roll a hot soldering tip in the Tip Cleaner for a few seconds until the bright tinning surrounds the end of the tip. • • • TT-95 CS-14—10 sponges/pack, 55mm x 70mm x 25mm thick Fits Weller 52241999 6 For more information: askchemtronics@chemtronics.com ® Extends tip life Lead-free Easy to use 1 – 20g container, 10 per case Customer Service 1-800-645-5244 www.chemtronics.com HAKKO® Soldering Stations • 926 • 928 • 936 • 937 • 951 • 952 • 958 • 959 • 701 • 702B Soldering Handpieces • 900M • 900M-ESD • 907 • 907-ESD Tip drawings are actual size Hakko® REPLACEMENT SOLDERING & DESOLDERING TIPS Tip drawings are actual size Hakko® Plato® Plato® ( ) = mm 900M-T-H ( ) = mm 900M-T-B 900M-T-1C 900M-T-2C 900M-T-LB 900M-T-3C 900M-T-1 900M-T-4C 900M-T-K 900M-T-0.8D 900M-T-S1 900M-T-1.2D 900M-T-S3 900M-T-1.2LD 900M-T-S4 900M-T-1.6D 900M-T-S5 900M-T-2.4D SMD Flow Tip 900M-T-3.2D 900M-T-0.2RB For more information: askchemtronics@chemtronics.com SMD Flow Tip Customer Service 1-800-645-5244 www.chemtronics.com 7 Soldering Stations 928 • 936 • 937 • 951 • 952 • 958 • 959 Soldering Handpieces • 900L • 900L-ESD • 908 • 908-ESD HAKKO® Tip drawings are actual size Hakko® ( ) = mm Plato® 900L-T-5C Hakko® ( ) = mm Plato® 900L-T-S1 900L-T-K Desoldering Irons • 474 • 475 • 701 • 702B — Handpieces • 808 • 809 HAKKO® Tip drawings are actual size. (mm) Hakko® Plato® D1 A-1002 HK-0878 .030" (0.8) .070" (1.8) A-1004 HK-0880 .030" (0.8) .090" (2.3) A-1003 A-1005 A-1006 A-1007 HK-0879 HK-0881 HK-0882 HK-0883 WELLER® .040" (1.0) .040" (1.0) .050" (1.3) .060" (1.5) • Premium quality for long life • Iron plated outside and stainless steel tube insert prevents solder path erosion • All dimensions are shown before tinning and are subject to manufacturing tolerances (mm) D2 .080" (2.0) .100" (2.5) .120" (3.0) .120" (3.0) Soldering Stations • WSL • WSL2 • WD1 • WD2 • WS80 • WSD80 • WSD81 Soldering Handpieces • WSP 80 • MPR 80 LONG LIFE LEAD-FREE TIPS • Longer Life • Designed for lead-free soldering • Look for tips with an LF added to the end of the part number Weller® 8 Plato® — MS-4140 LT1 MS-4120 LT1L MS-4110 LT1LX MS-4101 LT1S MS-4100 LT4W MS-5160 Tip drawings are actual size Weller® ( ) = mm For more information: askchemtronics@chemtronics.com LT4X MS-3125 LTA LTA LF MS-3200 MS-3200LF LTB LTB LF MS-3300 MS-3300LF LTD LTD LF MS-3600 MS-3600LF LTC LTC LF ( ) = mm Plato® 28˚ 0.085 (2.1) 0.047 (1.2) 0.016" (0.4) MS-3400 MS-3400LF Customer Service 1-800-645-5244 www.chemtronics.com Soldering Stations • WTCPT • WTCPTD • WTCPTFE • WTCPN • WTCPS Soldering Handpieces • TC201T • TC201FE Be sure to add temperature indicating number to Plato® part number when ordering Plato® C-Tips. Choose the desired temperature and add it to the end of the Plato part number* (Example C-3039-7) Desired 700°F / 800°F / 900°F / Temperature 370°C 425°C 480°C Tip drawings are actual size Weller® Plato® Suffix to Add to Plato Part Number -7 -8 -9 ( ) = mm PTA WELLER® Tip drawings are actual size Weller® ( ) = mm Plato® PTK PTL PTM PTO PTB PTP PTC PTS PTD PTBB PTF PTCC PTH *Indicated temperature ranges are nominal and will vary according to style of tip, condition of iron, manner of use, and other variables. All dimensions are shown before tinning and are subject to manufacturing tolerances. Soldering Stations • WSL • WSL2 • WD1 • WD2 • WS80 • WSD80 • WSD81 Soldering Handpieces • WSP 80 • MPR 80 Tip drawings are actual size. Weller ® Plato ® LTGW LTGW LF MS-0100 MS-0100LF LTH MS-3110 LTHX MS-3101 LTK MS-3150 LTL MS-3250 LTM MS-3450 ( ) = mm For more information: askchemtronics@chemtronics.com WELLER® Tip drawings are actual size. Weller® LTS LTO LF LTBB LF ( ) = mm Plato® MS-4130 0.039" (0.9) MS-4200LF 0.094" (2.4) MS-5300LF 0.125" (3.2) LTCC LF LTKN LF MS-5400LF MS-0201LF 0.162" (4.0) 0.002" (0.05) 0.06" (1.5) 0.228" (5.7) Customer Service 1-800-645-5244 www.chemtronics.com 9 WELLER® Tip drawings not actual size Weller® Soldering Stations • WES50 • WES51 • WD1 • WD2 Soldering Handpieces • EC1201A • EC1204A • PES50 • PES51 • WCC101 EW303 • EW305 • EW307 • EW103 • EW105• EW0574 ( ) = mm Plato® Weller® ETA ETO ETB ETP ETC ETR ( ) = mm Plato® ETD ETS ETE ETT ETGW ETV ETH ETJ ETAA ETK ETBB ETL ETCC ETM Desoldering Tips to Replace Pace Endura Tips Desoldering Irons SX90, SX-80 and SX-70 with Paper Chamber 3/16" Diameter PACE® Pace® Plato® 1121-0625 1121-0624 1121-0626 1121-0627 30-0301 30-0401 30-0601 30-0901 1121-0681 1121-0682 1121-0683 30-1020 30-1030 30-1040 1121-0628 1121-0629 1121-0630 1121-0631 1121-0680 1121-0678 1121-0679 1121-0690 30-1003 30-1004 30-1006 30-1060 30-1200 30-1300 30-1400 30-1600 ID (mm) .03" .04" .06" .09" (0.8) (1.0) (1.5) (2.3) .02" .03" .04" (0.5) (0.8) (1.0) .03" .04" .06" .06" .02" .03" .04" .06" (0.8) (1.0) (1.5) (1.5) (0.5) (0.8) (1.0) (1.5) OD (mm) .08" .09" .12" .20" (2.0) (2.3) (3.1) (5.1) .07" .08" .09" (1.8) (2.0) (2.3) .09" .10" .12" .19" .07" .08" .09" .11" D2 D2 (2.3) (2.5) (3.1) (4.8) (1.8) (2.0) (2.3) (2.8) 10 For more information: askchemtronics@chemtronics.com D1 – Hole Diameter D1 – Hole Diameter D2 D2 D1 – Hole Diameter D2 Customer Service 1-800-645-5244 D1 – Hole Diameter D1 – Hole Diameter www.chemtronics.com Desoldering Irons SX90, SX-80 and SX-70 with Glass Chamber 3/16" Diameter Pace® Plato® 1121-0342 1121-0463 --- 30-0400 30-040 30-050 D1 (mm) D2 (mm) .040" .040" .050" (1.0) (1.0) (1.3) .085" (2.2) .085" (2.2) .095" (2.4) Pace® Plato® 1121-0368 1121-0464 1121-0507 30-0600 30-060 30-0900 Desoldering Irons • Pace® • Air-Vac® • A.P.E. Pace® Plato® L (mm) D1 (mm) D2 (mm) Plato® Tips to fit Pace® SX-20, SX-25, SX-25V SODR-X-TRACTORS® 1121-0480 20-0114 1.00" (25.4) .030" (0.8) .060" (1.5) --20-0815 1.00" (25.4) .036" (0.9) .065" (1.7) 1121-0479 20-0110 1.00" (25.4) .040" (1.0) .080" (2.0) 1121-0216 20-0113 1.00" (25.4) .050" (1.3) .090" (2.3) 1121-0217 20-0111 1.00" (25.4) .060" (1.5) .100" (2.5) D1 (mm) D2 (mm) .060" .060" .090" AIR-VAC® Pace® PACE® (1.5) (1.5) (2.3) .115" (2.9) .115" (2.9) .190" (4.8) A.P.E.® Plato® L PACE® (mm) D1 (mm) Plato® Tips to fit Pace® SX-40A, SX-55A, SX-65A, SX-70 SODR-X-TRACTORS® with Plato Adapter 33-0001 1121-0485 20-025 1.75" (44.5) .030" (0.8) .080" (2.0) 1121-0486 20-040 1.75" (44.5) .040" (1.0) .080" (2.0) 1121-0255 20-060 1.75" (44.5) .060" (1.5) .100" (2.5) Soldering Stations • SMT 60 • Digital 2000 with Micro Tool Twin 80 A with Micro Tool Tip drawings are actual size Ersa® ( ) = mm Plato® 212BD Ersa® ERSA® ( ) = mm Plato® 212SD 0.004" (0.1) ER-4007 0.06" (1.6) ER-4001 QUICK Soldering Stations • 203 • 203H • 204 • 204H Tip drawings are actual size Quick 200-1C ( ) = mm Plato® 1 mm 0.028" (0.7) 200-2.4D 200-3C Quick 200-B DN-1C 2.4 mm DN-2.4D D2 (mm) 200-K ( ) = mm Plato® 1 mm DN-B 5 mm 0.1 mm 2 mm DN-K 6.8 mm 3.0 mm DN-3C For more information: askchemtronics@chemtronics.com 200-SK 3 mm 0.1 mm 1.6 mm DN-SK 3.8 mm Customer Service 1-800-645-5244 www.chemtronics.com 11 TIP CROSS REFERENCE ® Ersa® Plato® Pg. Hakko® Plato® Pg. 212BD 212SD ER-4007 ER-4001 900L-T-5C 900L-T-K 900L-T-S1 900M-T-0.2RB 900M-T-0.8D 900M-T-1.2D 900M-T-1.2LD 900M-T-1.6D 900M-T-1.8H 900M-T-1C 900M-T-2.4D 900M-T-2C 900M-T-3.2D 900M-T-3C 900M-T-4C 900M-T-B 900M-T-H 900M-T-1 900M-T-K 900M-T-LB 900M-T-S1 900M-T-S3 900M-T-S4 900M-T-S5 A-1002 A-1003 A-1004 A-1005 A-1006 A-1007 SMD Flow Tip SMD Flow Tip HS-5876 HS-0922 HS-1666 HS-4791 HS-2863 HS-2796 HS-6030 HS-2751 HS-0926 HS-5701 HS-2752 HS-5702 HS-2753 HS-5703 HS-5875 HS-4785 HS-0925 HS-4787 HS-0927 HS-4786 HS-2796 HS-1665 HS-8175 HS-8157 HK-0878 HK-0879 HK-0880 HK-0881 HK-0882 HK-0883 HS-0530 HS-0531 1121-0216 1121-0217 1121-0255 1121-0342 1121-0368 1121-0463 1121-0464 1121-0479 20-0113 20-0111 20-060 30-0400 30-0600 30-040 30-060 20-0110 Pace® Plato® 11 11 8 8 8 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 8 8 8 8 8 8 8 8 Pg. 11 11 11 11 11 11 11 11 1121-0480 1121-0485 1121-0486 1121-0507 1121-0624 1121-0625 1121-0626 1121-0627 1121-0628 1121-0629 1121-0630 1121-0631 1121-0678 1121-0679 1121-0680 1121-0681 1121-0682 1121-0683 1121-0690 20-0114 20-025 20-040 30-0900 30-0401 30-0301 30-0601 30-0901 30-1003 30-1004 30-1006 30-1060 30-1300 30-1400 30-1200 30-1020 30-1030 30-1040 30-1600 200-1C 200-2.4D 200-3C 200-B 200-K 200-SK DN-1C DN-2.4D DN-3C DN-B DN-K DN-SK ETA ETAA ETB ETBB ETC ETCC ETD ETE ETGW ETH ETJ ETK ETL ETM ETO ETP ETR ETS EW-303 EW-513 EW-305 EW-515 EW-307 EW-517 EW-103 EW-105 EW-0574 EW-301 EW-302 EW-304 EW-306 EW-308 EW-404 EW-403 EW-101 EW-402 Quick Weller® 11 11 11 11 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Plato® Pg. Plato® Pg. 11 11 11 11 11 11 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 ® 8125 Cobb Center Drive ■ Kennesaw, GA 30152-4386 Tel: 770-424-4888 ■ Toll Free: 1-800-645-5244 Fax: 770-423-0748 ■ Toll Free Fax: 1-800-243-6003 www.chemtronics.com © 2012 ITW Chemtronics®. All rights reserved. Plato 12227 2M platoproducts.com ETT ETV LT1 LT1L LT1LX LT1S LT4W LT4X LTA LTA LF LTB LTB LF LTBB LF LTC LTC LF LTCC LF LTD LTD LF LTGW LTGW LF LTH LTHX LTK LTKN LF LTL LTM LTO LF LTS LTBB LF LTCC LF LTKN LF PTA* PTB* PTBB* PTC* PTCC* PTD* PTF* PTH* PTK* PTL* PTM* PTO* PTP* PTS* EW-401 EW-511 MS-4120 MS-4110 MS-4101 MS-4100 MS-5160 MS-3125 MS-3200 MS-3200LF MS-3300 MS-3300LF MS-5300LF MS-3400 MS-3400LF MS-5400LF MS-3600 MS-3600LF MS-0100 MS-0100LF MS-3110 MS-3101 MS-3150 MS-0201LF MS-3250 MS-3450 MS-4200LF MS-4130 MS-5300LF MS-5400LF MS-0201LF C-3039 C-3040 C-5143 C-3036 C-5141 C-1016 C-593 C-3100 C-3043 C-3044 C-3102 C-4223 C-462 C-494 10 10 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 *A temperature designating number is used by both Plato and Weller, e.g. Weller PTA7 is equivalent to Plato C-3039-7
HS-5876 价格&库存
很抱歉,暂时无法提供与“HS-5876”相匹配的价格&库存,您可以联系我们找货
