DK00602ZO
DK00602ZO
    JABIL(捷普)
    钻头 碳化物 0.6mm
DK00602ZO 数据手册
Data Sheet CBN cutter Long-lasting high precision CBN endmill for mold steel. Applicable for working material Mold Steel HRC 50-68 finishing machining. Radius tolerance: ±0.003mm; Flute diameter tolerance: +0/ -0.01mm Cutter specification • • • • • • • • P/N: DK00602ZO Specification: R0.3xFL3-CBN Shank diameter: 4mm Working material: Mold steel HRC 50-68 Radius tolerance: ±0.003mm Flute diameter tolerance: +0/ -0.01mm Total length: 50mm Weight: 11.5g • • • • • • Working material: Mold steel Machining type: Fine finishing Rpm: 32000 Feed rate: 800mm/min Cutting depth (Ap): 0.005mm Cutting width (Ae): 0.015mm Recommend cutting parameter
DK00602ZO 价格&库存
很抱歉,暂时无法提供与“DK00602ZO”相匹配的价格&库存,您可以联系我们找货
DK00602ZO
    • 1+1654.565051+214.04325
    库存:25
