DK01001ZO
DK01001ZO
    JABIL(捷普)
    钻头 碳化物 0.040"(1.02mm)
DK01001ZO 数据手册
Data Sheet CBN cutter Long-lasting high precision CBN endmill for mold steel. Applicable for working material Mold Steel HRC 50-68 finishing machining. Radius tolerance: ±0.003mm; Flute diameter tolerance: +0/ -0.010mm Cutter specification • • • • • • • • P/N: DK01001ZO Specification: R0.5xL4xD4x50L_CBN Shank diameter: 4mm Working material: Mold steel HRC 50-68 Radius tolerance: ±0.003mm Flute diameter tolerance: +0/ -0.010mm Total length: 50mm Weight: 11.5g • • • • • • Working material: Mold steel Machining type: Fine finishing Rpm: 28000 Feed rate: 1500mm/min Cutting depth (Ap): 0.008mm Cutting width (Ae): 0.03mm Recommend cutting parameter
DK01001ZO 价格&库存
很抱歉,暂时无法提供与“DK01001ZO”相匹配的价格&库存,您可以联系我们找货
DK01001ZO
  • 1+1490.516081+186.49312
库存:24
