Data Sheet
Mold steel cutter
High precision endmill for mold steel. Applicable for working material HRC
50±2 machining. Radius tolerance: ±0.003mm; Flute diameter tolerance:
+0/ -0.01mm
Cutter specification
P/N: DK01002JS
Specification: M30 R0.5XFL2XL6X2T_L45
Shank diameter: 4mm
Working material: Mold steel HRC 50 ±2
Flute diameter tolerance: +0/ -0.01mm
Total length: 45mm
Weight: 10.5g
Recommend cutting parameter
Parameter
RPM
Feed rate
Cutting depth (Ap)
Cutting width (Ae)
Working material
Machining type
Rough finishing
40000
1500 mm/min
0.04 mm
0.04 mm
Semi-fine finishing
40000
1500 mm/min
0.04 mm
0.04 mm
Mold steel
Fine finishing
40000
1200 mm/min
0.025 mm
0.025 mm
很抱歉,暂时无法提供与“DK01002JS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+148.211271+19.17339
