DK01003JS
DK01003JS
    JABIL(捷普)
    钻头 碳化物 1mm
DK01003JS 数据手册
Data Sheet Mold steel cutter High precision endmill for mold steel. Applicable for working material HRC 50±2 machining. Radius tolerance: ±0.005mm; Flute diameter tolerance: +0/ -0.01mm Cutter specification • • • • • • • • P/N: DK01003JS Specification: M35 D1XFL1.5XL6X4T_L45 Shank diameter: 4mm Working material: Mold steel HRC 50 ±2 Radius tolerance: ±0.005mm Flute diameter tolerance: +0/ -0.01mm Total length: 45mm Weight: 10g Recommend cutting parameter Parameter RPM Feed rate Cutting depth (Ap) Cutting width (Ae) Working material Machining type Rough finishing 40000 2000 mm/min 0.05 mm 0.4 mm Semi-fine finishing 40000 2000 mm/min 0.03 mm 0.4 mm Mold steel Fine finishing 40000 600 mm/min 0.03 mm 0.4 mm
DK01003JS 价格&库存
很抱歉,暂时无法提供与“DK01003JS”相匹配的价格&库存,您可以联系我们找货
DK01003JS
    • 1+121.291631+15.17599
    库存:103
