Data Sheet
Mold steel cutter
High precision endmill for mold steel. Applicable for working material HRC
50±2 machining. Radius tolerance: ±0.005mm; Flute diameter tolerance:
+0/ -0.01mm
Cutter specification
P/N: DK01004JS
Specification: M35 D1xFL1.5xL4x4T_L45
Shank diameter: 4mm
Working material: Mold steel HRC 50 ±2
Flute diameter tolerance: +0/ -0.01mm
Total length: 45mm
Weight: 10g
Recommend cutting parameter
Parameter
RPM
Feed rate
Cutting depth (Ap)
Cutting width (Ae)
Working material
Machining type
Rough finishing
40000
2000 mm/min
0.05 mm
0.4 mm
Semi-fine finishing
40000
2000 mm/min
0.03 mm
0.4 mm
Mold steel
Fine finishing
40000
1600 mm/min
0.03 mm
0.4 mm
很抱歉,暂时无法提供与“DK01004JS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+129.309231+16.68123
