DK01005JS
DK01005JS
    JABIL(捷普)
    钻头 碳化物 0.040"(1.02mm)
DK01005JS 数据手册
Data Sheet Mold steel cutter High precision endmill for mold steel. Applicable for working material HRC 50±2 machining. Radius tolerance: ±0.003mm; Flute diameter tolerance: +0/ -0.01mm Cutter specification • • • • • • • • P/N: DK01005JS Specification: M30 R0.5xFL2xL4x2T_45L Shank diameter: 4mm Working material: Mold steel HRC 50 ±2 Radius tolerance: ±0.003mm Flute diameter tolerance: +0/ -0.01mm/ Total length: 45mm Weight: 10g Recommend cutting parameter Parameter RPM Feed rate Cutting depth (Ap) Cutting width (Ae) Working material Machining type Rough finishing 40000 2000 mm/min 0.05 mm 0.05 mm Semi-fine finishing 40000 2000 mm/min 0.05 mm 0.05 mm Mold steel Fine finishing 40000 1600 mm/min 0.025 mm 0.025 mm
DK01005JS 价格&库存
很抱歉,暂时无法提供与“DK01005JS”相匹配的价格&库存,您可以联系我们找货
