Data Sheet
Mold steel cutter
High precision endmill for mold steel. Applicable for working material HRC
50±2 machining. Radius tolerance: ±0.003mm; Flute diameter tolerance:
+0/ -0.01mm
Cutter specification
P/N: DK02006JS
Specification: M30 R1XFL3XL6X2T_45L
Shank diameter: 4mm
Working material: Mold steel HRC 50 ±2
Flute diameter tolerance: +0/ -0.01mm
Total length: 45mm
Weight: 10g
Recommend cutting parameter
Parameter
RPM
Feed rate
Cutting depth (Ap)
Cutting width (Ae)
Working material
Machining type
Rough finishing
35000
3000 mm/min
0.1 mm
0.1 mm
Semi-fine finishing
35000
3000 mm/min
0.1 mm
0.1 mm
Mold steel
Fine finishing
35000
2400 mm/min
0.06 mm
0.06 mm
很抱歉,暂时无法提供与“DK02006JS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+148.029811+19.14992
