Data Sheet
Mold steel cutter
High precision endmill for mold steel. Applicable for working material HRC
50±2 machining. Radius tolerance: ±0.003mm; Flute diameter tolerance:
+0/ -0.01mm
Cutter specification
P/N: DK02007JS
Specification: M30 R1xFL3xL12x2T_45L
Shank diameter: 4mm
Working material: Mold steel HRC 50 ±2
Flute diameter tolerance: +0/ -0.01mm
Total length: 45mm
Weight: 9.5g
Recommend cutting parameter
Parameter
RPM
Feed rate
Cutting depth (Ap)
Cutting width (Ae)
Working material
Machining type
Rough finishing
35000
2400 mm/min
0.08 mm
0.08 mm
Semi-fine finishing
35000
2400 mm/min
0.08 mm
0.08 mm
Mold steel
Fine finishing
35000
1920 mm/min
0.05 mm
0.05 mm
很抱歉,暂时无法提供与“DK02007JS”相匹配的价格&库存,您可以联系我们找货
