DK03001JS
DK03001JS
    JABIL(捷普)
    钻头 碳化物 3mm
DK03001JS 数据手册
Data Sheet Mold steel cutter High precision endmill for mold steel. Applicable for working material HRC 50±2 machining. Radius tolerance: ±0.005mm; Flute diameter tolerance: +0/ -0.01mm Cutter specification • • • • • • • • P/N: DK03001JS Specification: M30 R1.5xFL3xL15x2T_L50 Shank diameter: 6mm Working material: Mold steel HRC 50 ±2 Radius tolerance: ±0.005mm Flute diameter tolerance: +0/ -0.01mm Total length: 50mm Weight: 17.5g Recommend cutting parameter Parameter RPM Feed rate Cutting depth (Ap) Cutting width (Ae) Working material Machining type Rough finishing 28000 3000 mm/min 0.12 mm 0.12 mm Semi-fine finishing 28000 3000 mm/min 0.09 mm 0.09 mm Mold steel Fine finishing 28000 2400 mm/min 0.06 mm 0.06 mm
DK03001JS 价格&库存
很抱歉,暂时无法提供与“DK03001JS”相匹配的价格&库存,您可以联系我们找货
DK03001JS
    • 1+205.143951+26.57332
    库存:39
