DK04001JS
DK04001JS
    JABIL(捷普)
    钻头 碳化物 4mm
DK04001JS 数据手册
Data Sheet Mold steel cutter High precision endmill for mold steel. Applicable for working material HRC 50±2 machining. Radius tolerance: ±0.005mm; Flute diameter tolerance: +0/ -0.015mm Cutter specification • • • • • • • • P/N: DK04001JS Specification: M30 R2xFL4xL16x2T_L50 Shank diameter: 6mm Working material: Mold steel HRC 50 ±2 Radius tolerance: ±0.005mm Flute diameter tolerance: +0/ -0.015mm Total length: 50mm Weight: 18.5g Recommend cutting parameter Parameter RPM Feed rate Cutting depth (Ap) Cutting width (Ae) Working material Machining type Rough finishing 22000 3000 mm/min 0.2 mm 0.2 mm Semi-fine finishing 22000 3000 mm/min 0.16 mm 0.16 mm Mold steel Fine finishing 22000 2500 mm/min 0.08 mm 0.08 mm
DK04001JS 价格&库存
很抱歉,暂时无法提供与“DK04001JS”相匹配的价格&库存,您可以联系我们找货
DK04001JS
    • 1+242.080191+31.31677
    库存:42
