Data Sheet
Mold steel cutter
High precision endmill for mold steel. Applicable for working material HRC
50±2 machining. Flute diameter tolerance: +0/ -0.015mm
Cutter specification
P/N: DK04003JS
Specification: M35 D4xFL5xL16x4T_L45
Shank diameter: 6mm
Working material: Mold steel HRC 50 ±2
Total length: 45mm
Weight: 17g
Recommend cutting parameter
Parameter
RPM
Feed rate
Cutting depth (Ap)
Cutting width (Ae)
Working material
Machining type
Rough finishing
18000
800 mm/min
0.8 mm
1.6 mm
Semi-fine finishing
18000
3000 mm/min
0.1 mm
1.6 mm
Mold steel
Fine finishing
20000
1000 mm/min
0.05 mm
1.6 mm
很抱歉,暂时无法提供与“DK04003JS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+163.769971+20.48387
