DK04009JS
DK04009JS
    JABIL(捷普)
    钻头 碳化物 4mm
DK04009JS 数据手册
Data Sheet Mold steel cutter High precision endmill for mold steel. Applicable for working material HRC 50±2 machining. Radius tolerance: ±0.005mm; Flute diameter tolerance: +0/ -0.015mm Cutter specification • • • • • • • • P/N: DK04009JS Specification: M30 D4R0.2xFL12xL12x2T_L50 Shank diameter: 6mm Working material: Mold steel HRC 50 ±2 Radius tolerance: ±0.005mm Flute diameter tolerance: +0/ -0.015mm Total length: 50mm Weight: 18.5g Recommend cutting parameter Parameter RPM Feed rate Cutting depth (Ap) Cutting width (Ae) Working material Machining type Rough finishing 18000 3500 mm/min 0.15 mm 1.6 mm Semi-fine finishing 18000 3500 mm/min 0.15 mm 1.6 mm Mold steel Fine finishing 18000 1000 mm/min 0.05 mm 4 mm
DK04009JS 价格&库存
很抱歉,暂时无法提供与“DK04009JS”相匹配的价格&库存,您可以联系我们找货
DK04009JS
    • 1+204.368241+26.43815
    库存:42
