Data Sheet
Mold steel cutter
High precision endmill for mold steel. Applicable for working material HRC
50±2 machining. Flute diameter tolerance: -0.01/ -0.025mm
Cutter specification
P/N: DK06032JS
Specification: M35 D6XFL15XL24X4T_L50
Shank diameter: 6mm
Working material: Mold steel HRC 50 ±2
Total length: 50mm
Weight: 21g
Recommend cutting parameter
Parameter
RPM
Feed rate
Cutting depth (Ap)
Cutting width (Ae)
Working material
Machining type
Rough finishing
13000
4000 mm/min
0.15 mm
2.4 mm
Semi-fine finishing
13000
4000 mm/min
0.1 mm
2.4 mm
Mold steel
Fine finishing
13000
1500 mm/min
0.05 mm
3.6 mm
很抱歉,暂时无法提供与“DK06032JS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+220.731791+28.55503
