DK10006JS
DK10006JS
    JABIL(捷普)
    钻头 碳化物 2mm
DK10006JS 数据手册
Data Sheet Mold steel cutter High precision endmill for mold steel. Applicable for working material HRC 50±2 machining. Radius tolerance: ±0.003mm; Flute diameter tolerance: +0/ -0.01mm Cutter specification • • • • • • • • P/N: DK10006JS Specification: M30 R1xFL3xL8x2T_L45 Shank diameter: 4mm Working material: Mold steel HRC 50 ±2 Radius tolerance: ±0.003mm Flute diameter tolerance: +0/ -0.01mm Total length: 45mm Weight: 10g Recommend cutting parameter Parameter RPM Feed rate Cutting depth (Ap) Cutting width (Ae) Working material Machining type Rough finishing 35000 3000 mm/min 0.1 mm 0.1 mm Semi-fine finishing 35000 3000 mm/min 0.1 mm 0.1 mm Mold steel Fine finishing 35000 2400 mm/min 0.06 mm 0.06 mm
DK10006JS 价格&库存
很抱歉,暂时无法提供与“DK10006JS”相匹配的价格&库存,您可以联系我们找货
DK10006JS
    • 1+148.171161+18.53915
    库存:50
