DK20002JS
DK20002JS
    JABIL(捷普)
    钻头 碳化物 2mm
DK20002JS 数据手册
Data Sheet Mold steel cutter High precision endmill for mold steel. Applicable for working material HRC 50±2 machining. Radius tolerance: ±0.005mm; Flute diameter tolerance: +0/ -0.01mm Cutter specification • • • • • • • • P/N: DK20002JS Specification: M35 D2R0.1XFL4XL8X2T_L45 Shank diameter: 4mm Working material: Mold steel HRC 50 ±2 Radius tolerance: ±0.005mm Flute diameter tolerance: +0/ -0.01mm Total length: 45mm Weight: 10g Recommend cutting parameter Parameter RPM Feed rate Cutting depth (Ap) Cutting width (Ae) Working material Machining type Rough finishing 38000 3000 mm/min 0.1 mm 0.8 mm Semi-fine finishing 38000 3000 mm/min 0.1 mm 0.8 mm Mold steel Fine finishing 38000 1000 mm/min 0.05 mm 0.8 mm
DK20002JS 价格&库存
很抱歉,暂时无法提供与“DK20002JS”相匹配的价格&库存,您可以联系我们找货
DK20002JS
    • 1+113.701581+14.70904
    库存:90
