Jabil PA 4500 Filament
Technical Data Sheet
_______________________________________________________________________________
Product Description
PA 4500 Filament is a low warp, neat nylon copolymer that has good lay flat/low warp properties, excellent
appearance, strength in both XY and XZ directions, toughness, and can be printed at lower temps (240-260°
C).
Applications for this material include component production of less than 20,000 per year with complex
geometries that require good wear properties and appearance are required but also strength and durability,
such as slides, screen printing pallets, automation sleds, adaptors for fluid and materials handling, end of arm
tooling (EOAT), masking covers, die cast models and patterns, clips, covers, housings, and gears.
Advantages
Along with easier printability, PA 4500 filament also delivers better appearance, over 100% elongation at
break and better overall strength compared to other commercial PA’s and products like PETg and PLA.
Storage and Use
PA 4500 is highly hygroscopic, meaning it will quickly absorb and retain moisture from the atmosphere,
affecting visual quality and mechanical properties. For best results, print and store filament in a dry
environment. If necessary, dry filament in an oven at up to 75 °C (165 °F) for 6 - 12 hours.
Download Jabil's optimized print profile by clicking here.
Properties
Mechanical Properties - Dry as Printed1
Test Condition
Tensile Modulus (MPa)
Tensile Elongation at Break (%)
Ultimate Tensile Strength (MPa)
Flexural Modulus (MPa)
Flexural Strength (MPa)
Flexural Strain (%)
Izod Impact, notched (J/m)
Izod impact, un-notched (J/m)
1. Testing conducted on bars printed
are for reference only.
XY coupons, Ambient
XY coupons, Ambient
XY coupons, Ambient
XY coupons, Ambient
at 260 °C and tested at
Typical
Method
Value
1930
ASTM D638, Type I
>100
56.0
1440
ASTM D790
56.9
>5
61.5
ASTM D256
830
500
41.6
497
XY coupons, Ambient
ASTM D790
20.4
Flexural Strain (%)
>5
XY coupons, Ambient
282
ASTM D256
XY coupons, Ambient
1714
1. Testing conducted on bars printed at 260 °C and conditioned for 14 days at 23 °C and 50 %
RH. Typical values are for reference only.
Test Condition
Thermal Properties
Test Condition
Heat Deflection Temperature (°C)
Melt Temperature, Peak (°C)
0.455 Mpa
20°C/min ramp
Typical
Value
62
190
Method
DMA
DSC
Other Physical Properties
Test Condition
Density (g/cm3)
Ambient
Typical
Value
1.10
Method
ASTM D792
Dimensional Properties
Test Condition
Diameter: Mean, Indiv. Axis (mm)
In-line, 100% inspection
Typical
Value
1.75±0.05
2.85±0.05
Method
Laser Micrometer
________________________________________________________________________________________
United States: en
19-MT60-00048 Rev A
Page 2 of 3
Disclaimer: The information in this technical data sheet, including material properties, are obtained from testing
representative samples under carefully controlled conditions and are provided for reference only. Material properties
may be impacted by storage, handling, processing equipment/parameters, and product design, among other factors.
The information is not a substitute for user testing to determine fitness for any specific use and the user is responsible
for ensuring safe and lawful use of the product.
No express or implied warranties are provided and the implied warranties of merchantability or fitness for a particular
purpose are expressly disclaimed. No representations are made, and no liability is assumed arising from or relating to
the product.
Copyright/Trademark: © 2019 Jabil Inc. All rights reserved. JABIL® and the JABIL logo are registered trademarks
of Jabil Inc.
United States: en
19-MT60-00048 Rev A
Page 3 of 3
很抱歉,暂时无法提供与“JA3D-C1001280”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+599.970071+77.65988
- 10+532.2614610+68.89570
