DK30001JS
DK30001JS
    JABIL(捷普)
    钻头 碳化物 6mm
DK30001JS 数据手册
Data Sheet Mold steel cutter High precision endmill for mold steel. Applicable for working material HRC 50±2 machining. Radius tolerance: ±0.005mm; Flute diameter tolerance: -0.01/ -0.025mm Cutter specification • • • • • • • • P/N: DK30001JS Specification: M30 R3XFL12X2T_L50 Shank diameter: 6mm Working material: Mold steel HRC 50 ±2 Radius tolerance: ±0.005mm Flute diameter tolerance: -0.01/ -0.025mm Total length: 50mm Weight: 21.5g Recommend cutting parameter Parameter RPM Feed rate Cutting depth (Ap) Cutting width (Ae) Working material Machining type Rough finishing 14000 3000 mm/min 0.2 mm 0.2 mm Semi-fine finishing 14000 3000 mm/min 0.18 mm 0.18 mm Mold steel Fine finishing 14000 3200 mm/min 0.1 mm 0.1 mm
DK30001JS 价格&库存
很抱歉,暂时无法提供与“DK30001JS”相匹配的价格&库存,您可以联系我们找货
DK30001JS
    • 1+195.217831+24.48069
    库存:33
