195204-227
195204-227
    JOHNSON
    间断 占空比螺线管 封闭框架(拉),管状 型 0.625"(15.88mm) 行程 12VDC 面板安装
195204-227 数据手册
Size 75–STA® Pull Tubular Solenoids — 3/4" Dia. x 1-1/2" Part Number: 195204 - X XX LINEAR Tubular All products are RoHS Compliant Coil AWG Number (from performance chart below) Plunger Configurations and anti-rotation flat on mounting 1 Flat face plunger without anti-rotation flat 2 60° plunger without anti-rotation flat 5 Flat face plunger with anti-rotation flat 6 60° plunger with anti-rotation flat Performance Specifications Maximum Duty Cycle 100% 50% 25% 10% Maximum ON Time (sec) when pulsed continuously1 ∞ 230 25 6 Maximum ON Time (sec) for single pulse2 ∞ 265 63 15 Watts (@ 20°C) 7 14 28 70 855 1200 1700 2700 Ampere Turns (@ 20°C) Coil Data awg Resistance # (0XX)3 (@20°C) Turns4 24 25 26 27 28 29 30 31 32 33 1.10 2.13 2.90 5.27 9.15 12.50 20.70 33.60 53.50 83.50 330 488 544 760 1026 1146 1491 1904 2394 2970 VDC VDC VDC VDC (Nom) (Nom) (Nom) (Nom) 2.7 3.8 3.9 5.5 4.5 6.4 6.1 8.6 8.0 11.3 9.4 13.2 12.0 17.0 15.0 22.0 19.4 27.0 24.0 34.0 5.6 7.7 9.0 12.1 16.0 18.7 24.0 31.0 39.0 48.0 Continuously pulsed at stated watts and duty cycle Single pulse at stated watts (with coil at ambient room temperature 20°C) 3 Other coil awg sizes available — please consult factory 4 Reference number of turns 8.8 12.2 14.2 19.2 25.0 30.0 38.0 48.0 61.0 76.0 Dielectric Strength Recommended Minimum Heat Sink Coil Resistance Holding Force Weight Plunger Weight 1000 VRMS Maximum watts dissipated by solenoid are based on an unrestricted flow of air at 20°C, with solenoid mounted on the equivalent of an aluminum plate measuring 3” square by 1/8” thick ±5% tolerance Flat Face: 5.24 lb (23.3 N) @ 20°C 60°: 2.88 lb (12.8 N) @ 20°C 2.95 oz (83.6 g) 0.71oz (20.1 g) How to Order Add the plunger number and the coil awg number to the part number (for example: to order a unit with a 60° plunger configuration without an anti-rotation flat rated for 12.1 VDC at 25% duty cycle, specify 195204-227. 1 2 Please see www.johnsonelectric.com for our list of stock products available through distribution. All specifications subject to change without notice. Ledex® Solenoids www.johnsonelectric.com 1.937.454.2345 Fax: 1.937.898.8624 Size 75–STA® Pull Tubular Solenoids — 3/4" Dia. x 1-1/2" Flat Face Plunger 10 (44.48) 50  10% Duty Cycle 70W  25% Duty Cycle 28W  50% Duty Cycle 14W  100% Duty Cycle 7W  10% Duty Cycle 70W  25% Duty Cycle 28W  50% Duty Cycle 14W  100% Duty Cycle 7W 40 Speed – ms 8 (35.58) Force – lbs (N) Typical Speed @ No Load, 20°C Typical Force @ 20°C 6 (26.69) 4 (17.79) 2 (8.90) 30 20 10 0 0.1 (2.54) 0.2 (5.08) 0.3 (7.62) Stroke – in (mm) 0.4 (10.16) 0.5 (12.70) 0.1 (2.54) 0 0.2 (5.08) 0.3 (7.62) Stroke – in (mm) 0.4 (10.16) 0.5 (12.70) 60° Plunger 6 (26.69) Typical Force @ 20°C  10% Duty Cycle 70W  25% Duty Cycle 28W  50% Duty Cycle 14W  100% Duty Cycle 7W 5 (22.24) 4 (17.79) Typical Speed @ No Load, 20°C  10% Duty Cycle 70W  25% Duty Cycle 28W  50% Duty Cycle 14W  100% Duty Cycle 7W 40 Speed – ms Force – lbs (N) 50 3 (13.34) 30 20 2 (8.90) 10 1 (4.45) 0 0.1 (2.54) 0.2 (5.08) 0.3 (7.62) 0.4 (10.16) Stroke – in (mm) 0.5 (12.70) 0.6 (15.24) 0.7 (17.78) 0 0.1 (2.54) 0.2 (5.08) 0.3 (7.62) 0.4 (10.16) Stroke – in (mm) 0.5 (12.70) 0.6 (15.24) 0.7 (17.78) Force values for reference only. Inches (mm) Dimensions 1.125 R min (28.58) All solenoids are illustrated in energized state Chamfer 0.020/0.030 (0.51/0.76) x 45° ±5° 0.188 ± 0.010 (4.76 ± 0.30) 0.308 ± 0.003 dia (Ø7.82 ± 0.08) 0.375 ± 0.010 (9.52 ± 0.30) 0.092/0.097 dia thru (Ø2.34/2.46) 1.550 0.750 ± 0.015 (39.37)max (19.05 ± 0.38) 0.375 ± 0.010 (9.52 ± 0.30) 0.770 dia max (Ø19.56) 0.090 dia ref (Ø2.29) 0.093 ± 0.010 (2.36 ± 0.30) 0.235 (5.97) Ledex® Solenoids 0.5625–18 UNF threads 0.085 min. panel thickness Mounting Nut: 0.13 (3.3) thick x 0.69 (17.5) flats. Shipped as loose item. 10.0 min leads, (254.0) #24 awg PVC www.johnsonelectric.com 1.937.454.2345 Fax: 1.937.898.8624 Size 75–STA® Push Tubular Solenoids — 3/4" Dia. x 1-1/2" Part Number: 195205 - X XX LINEAR Tubular All products are RoHS Compliant Coil AWG Number (from performance chart below) Plunger Configurations and anti-rotation flat on mounting 1 Flat face plunger without anti-rotation flat 2 60° plunger without anti-rotation flat 5 Flat face plunger with anti-rotation flat 6 60° plunger with anti-rotation flat Specifications Performance Maximum Duty Cycle 100% 50% 25% 10% Maximum ON Time (sec) when pulsed continuously1 ∞ 230 25 6 Maximum ON Time (sec) for single pulse2 ∞ 265 63 15 Watts (@ 20°C) 7 14 28 70 855 1200 Ampere Turns (@ 20°C) Coil Data awg Resistance # (0XX)3 (@20°C) Turns4 24 25 26 27 28 29 30 31 32 33 1700 2700 1.10 2.13 2.90 5.27 9.15 12.50 20.70 33.60 53.50 83.50 330 488 544 760 1026 1146 1491 1904 2394 2970 VDC VDC VDC VDC (Nom) (Nom) (Nom) (Nom) 2.7 3.9 4.5 6.1 8.0 9.4 12.0 15.0 19.4 24.0 3.8 5.5 6.4 8.6 11.3 13.2 17.0 22.0 27.0 34.0 5.6 8.8 7.7 12.2 9.0 14.2 12.1 19.2 16.0 25.0 18.7 30.0 24.0 38.0 31.0 48.0 39.0 61.0 48.0 76.0 Continuously pulsed at stated watts and duty cycle Single pulse at stated watts (with coil at ambient room temperature 20°C) 3 Other coil awg sizes available — please consult factory 4 Reference number of turns Dielectric Strength Recommended Minimum Heat Sink Coil Resistance Holding Force Weight Plunger Weight 1000 VRMS Maximum watts dissipated by solenoid are based on an unrestricted flow of air at 20°C, with solenoid mounted on the equivalent of an aluminum plate measuring 3” square by 1/8" thick ±5% tolerance Flat Face: 4.95 lb (22.0 N) @ 20°C 60°: 2.85 lb (12.7 N) @ 20°C 3.08 oz (87.3 g) 0.53 oz (15.0 g) How to Order Add the plunger number and the coil awg number to the part number (for example: to order a unit with a 60° plunger configuration without an anti-rotation flat rated for 12.1 VDC at 25% duty cycle, specify 195205-227. 1 2 Please see www.johnsonelectric.com for our list of stock products available through distribution. All specifications subject to change without notice. Ledex® Solenoids www.johnsonelectric.com 1.937.454.2345 Fax: 1.937.898.8624 Size 75–STA® Push Tubular Solenoids — 3/4" Dia. x 1-1/2" Flat Face Plunger Typical Force @ 20°C 8 (35.58) 50 ■ 10% Duty Cycle 70W ■ 25% Duty Cycle 28W ■ 50% Duty Cycle 14W ■ 100% Duty Cycle 7W 4 (17.79) 2 (8.90) 0.1 (2.54) 0.2 (5.08) 0.3 (7.62) Stroke – in (mm) 60° Plunger 0.4 (10.16) 20 0.5 (12.70) 0.1 (2.54) 0 0.2 (5.08) 0.3 (7.62) Stroke – in (mm) 0.4 (10.16) 0.5 (12.70) Typical Speed @ No Load, 20°C Typical Force @ 20°C 50 ■ 10% Duty Cycle 70W ■ 25% Duty Cycle 28W ■ 50% Duty Cycle 14W ■ 100% Duty Cycle 7W 5 (22.24) 4 (17.79) ■ 10% Duty Cycle 70W ■ 25% Duty Cycle 28W ■ 50% Duty Cycle 14W ■ 100% Duty Cycle 7W 40 Speed – ms Force – lbs (N) 30 10 0 6 (26.69) ■ 10% Duty Cycle 70W ■ 25% Duty Cycle 28W ■ 50% Duty Cycle 14W ■ 100% Duty Cycle 7W 40 Speed – ms Force – lbs (N) 6 (26.69) Typical Speed @ No Load, 20°C 3 (13.34) 2 (8.90) 30 20 10 1 (4.45) 0 0.1 (2.54) 0.2 (5.08) 0.3 (7.62) 0.4 (10.16) Stroke – in (mm) 0.5 (12.70) 0.6 (15.24) 0.7 (17.78) 0.1 (2.54) 0 0.2 (5.08) Force values for reference only. 0.4 (10.16) 0.5 (12.70) 0.6 (15.24) 0.7 (17.78) Inches (mm) Dimensions All solenoids are illustrated in energized state 0.770 dia max (Ø19.56) 1.125 ± 0.015 (28.58 ± 0.38) 0.235 (5.97) 1.550 (39.37) max 0.140 (3.56) max 0.375 ± 0.010 (9.52 ± 0.30) 0.094 ± 0.003 dia (Ø2.39 ± 0.08) Ledex® Solenoids 0.3 (7.62) Stroke – in (mm) 0.5625–18 UNF threads 0.085 min. panel thickness Mounting Nut: 0.13 (3.3) thick x 0.69 (17.5) flats. Shipped as loose item. 10.0 min leads, (254.0) #24 awg PVC www.johnsonelectric.com 1.937.454.2345 Fax: 1.937.898.8624
195204-227 价格&库存
很抱歉,暂时无法提供与“195204-227”相匹配的价格&库存,您可以联系我们找货
  • 1+456.873231+59.10353
  • 10+406.9056010+52.63945
  • 25+388.5395925+50.26353
  • 50+375.1893750+48.53648
  • 100+362.28835100+46.86753
  • 250+345.90155250+44.74765
库存:208
