a module solution provider
MM5D91E00
MM5D91-00 Presence Detection
Evaluation Kit
User Guide
Draft 0.1
Prepared By
Reviewed By
Copyright © JORJIN TECHNOLOGIES INC. 2020
http://www.jorjin.com.tw
CONFIDENTIAL
Approved By
Doc No: MM5D91E00-UG-D01
Index
1. INTRODUCTION ................................................................................................................... 2
2. HARDWARE DESCRIPTION................................................................................................... 3
3. CONFIGURABILITY ............................................................................................................... 4
4. SCHEMATIC DIAGRAMS ....................................................................................................... 5
5. DIMENSION.......................................................................................................................... 7
6. HISTORY CHANGE ................................................................................................................ 7
CONFIDENTIAL
Page 1
1. INTRODUCTION
The MM5D91-00 is the presence detection sensor module which integrates 60GHz
mmWave technology. The module simplifies the implementation of mmWave sensors in
the band of 61.0 to 61.5GHz, and it includes the ARM Cortex-M4F based processor
system, 1Tx 3Rx antenna and onboard regulator. This presence detection sensor module
targets low power and high resolution presence detection in smart home, office, security
and diverse applications.
Based on the MM5D91-00 Radar sensor module, the MM5D91E00 evaluation board is
built to demonstrate the function of presence detection of the 60 GHz radar sensor with
its sophisticated radar presence detection algorithms.
TOP side
Bottom side
Figure 1-1. MM5D91E00 mmWave Radar Evaluation Kit
CONFIDENTIAL
Page 2
The following figure and table describe physical sections of the board.
A
E
C
B
D
F
Figure 2-1. Hardware description of Evaluation Kit
Table 2-1. Evaluation Kit component descriptions list
Region
Description
A
Jorjin mmWave Radar sensor module.
B
Radar sensor module reset switch.
C
Red LED light when the evaluation kit is power on.
D
LED of radar detect status:
- Green color : No presence.
- Red color : Presence detected.
E
Interface setting: Turn up of left two / Turn down of right two.
Please keep the setting always.
F
Micro USB connector. Connected to PC (config tool) or power bank to demo.
CONFIDENTIAL
Page 3
3. CONFIGURABILITY
Easy Configuration UART port for the end user to change parameters
Standard mode: Detection range, Sensitivity, Reset etc.
The detection range, sensitivity and status settings are stored in the flash and
remain set after power reboot.
If the OS is win7 or lower , please find the USB driver as the link.
Figure 3-1. Radar module connect to PC
Figure 3-2. Radar Module Configuration software
CONFIDENTIAL
Page 4
Figure 4-1. Pin assignment of P1 and P2
Figure 4-2. LED indication for presence detection
CONFIDENTIAL
Page 5
Figure 4-3. UART to USB Conversion
CONFIDENTIAL
Page 6
5. DIMENSION
42.2 mm
26 mm
Figure 5-1. MM5D91E00 Board Dimension
6. HISTORY CHANGE
Revision
Date
Description
Draft 0.1
2020-07-21
Draft version.
CONFIDENTIAL
Page 7
很抱歉,暂时无法提供与“MM5D91E00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+999.438901+129.46229
