APLMK SZE003-03
APLMK SZE003-03
    JST
    APPLICATOR FOR JST APK2N PRESS
APLMK SZE003-03 数据手册
.1ST MKS-L DIES CONSTRUCTION SHEET SPH-002T-PO.5S -­ -­ Terminal/Contact Model No. Die set Model No. I SPH-002-05S Appl icator Model No. -I Cr imp shape (wi re) I N-1. 4 Cr imp shape (i ns) I N-1. 4 -­ MKS-L, MKS-LS ! Clearance between Crimper ( B) and Shear blade No. 63821 64671 65120 Description Crimper (A) Crimper (6) Spacer (A) Spacer (6) Spacer (C) Punch Die holder Sp ring Wire block Insulation block 65011 68270 67360 87100 390 326 rr-. ) 81510 82500 84310 83170 87001 Guide plate (L) Guide plate (R) Feed plate Pressure plate Pressure spring(2pcs) Wi re and Crimp height I Wi re Type i Crimp height (mm) Wi re I Size Ins ULl 007 #30 ULl 007 #28 i 0.55"'0.60 1.5 ULl 007 #26 I 0.57"'0.62 1.6 ULl 007 !i #24 0.62"'0.67 1.7 0.52"'0.57 I, i I O. 1 Description Crimper anv i I (A) Crimper anv i I (6) No. 75055 Spacer Shear btade Shear blade supporter Shear blade base Shear blade spring 77360 74310 73120, 78010 87010 Feed finger Feed finger holder 86180 86040 Stripper Stripper bracket Stripper pin 91450 92290 . Scrap cover 95310 Remarks Dies construction is the same as that for SPH-002-05L, though crimp heights are different. 1.5 I i Prepared by I"L .... _1 ....... ..1 L..•• /I., » J~ , -) Issue date AI ... I I Apr 16,1996 i rp-U~l'n Side-Feeding APPI icator MKS-L Die Set AssemblY APPlicable terminal/ contact . SPH-002-05S -05L -001-05S 390 32~ ~ 65120 63821 64671 87100 83170 81510 84310 87001 74370 73120 .95310 75055 D ate JUN 12.98 Drawn bY Y. OKADA
APLMK SZE003-03 价格&库存
很抱歉,暂时无法提供与“APLMK SZE003-03”相匹配的价格&库存,您可以联系我们找货
