B07B-PASK
B07B-PASK
    JST
    插件,P=2mm
    CONN HEADER VERT 7POS 2MM
B07B-PASK 数据手册
PA FAMILY SERIES/PA•PAF•PAL CONNECTOR Wire-to-board (Crimp style/IDC) / Wire-to-wire (Crimp style/IDC) 2.0mm (.079") pitch Features –––––––––––––––––––––––– • Secure locking device The housing has a locking device to prevent accidental disconnection because of routing of wires or of vibration, and also reverse and different circuit numbers mating. • Interchangeable between crimp and IDC socket Both crimp and IDC sockets use the same headers and wire-towire mating halves. • Secondary retainers Secondary retainers enhance safety in case of partial insertion or accidental release of the contact. • Harness variation PAL, wire-to-wire crimp style connector, increases wire harness variation. PA connector (Standard type, Retainer mountable type) • Highly reliable contact Based upon wire-to-board crimp style PA connectors, the PA series family of connector have been expanded to meet the requirement of complex wire harness of 2.0mm (.079") pitch connectors with secure locking mechanism thanks to the additional line up of wire-to-board IDC style PAF connectors and wire-to-wire crimp style PAL connectors. The box contact supplies stable contact performance even under conditions of vibration, distortion, low voltage or low current. • Insertion guide mechanism Header has housing insertion guides for easy and secure insertion. • Flanged press pin Top entry type header has flanged press pins, preventing accidental removal of the pins that might result from the distorted unmating especially in the case of small No. of circuits. PAF connector • The industry’s first secure lock IDC connectors Retainer PA Receptacle (Crimp style Standard type) Retainer PAF Receptacle (IDC style) Retainer PA Receptacle (Crimp style Retainer mountable type) • Metallic strain relief PA Shorouded header (Top entry type) PA Shorouded header (Side entry type) PAF Receptacle (IDC style) PA Shorouded header (Top entry type) PAL (Crimp style Wire-to-wire) Retainer * Contact JST if Lead-Free product is required. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 1 By separating ID section and secure lock section, the industry’s first secure lock specification has been achieved for IDC that was said to be impossible. Our fully automatic IDC machines, BCD-M5BP (for simple harness) and CAM-M12B, SAD-M12E (for multiharness), can be applied for harness making. Recognized E60389 Metallic strain relief on the contact securely grips wire insulation that can avoid direct stress of vibration or impact. The same grip strength as insulation barrel of crimp style contact could be achieved. • Retainer with four locking points The new four locking points design ensures wire retention force of every direction that is almost superior to contact retention force of crimp style connectors. It also completely covers exposed terminated ID contact. PAL connector • The industry’s first wire to wire 2.0mm (.079") pitch retainer mountable type connector. • Either with or without panel lock can be selected according to application. Certified LR20812 61 PA FAMILY SERIES /PA•PAF•PAL CONNECTOR List of combinations –––––––––––––––––––––––––––––––––––––––––––––––––––––– Crimp style Standard type Contact SPHD-001T-P0.5 SPHD-002T-P0.5 Housing Shrouded header Top entry type Side entry type B( )B-PASK B( )B-PASK-1 S( )B-PASK-2 PAP-( )V-S Shrouded header High box type BH( )B-PASK BH( )B-PASK-1 Crimp style Retainer mountable type Contact SPA-001T-P0.5 Housing PARP-( )V Retainer PMS-( )V-S Shrouded header BM( )B-PASS SMT type Top entry type BM( )B-PASS-1 Side entry type SM( )B-PASS SM( )B-PASS-1 Insulation displacement type Receptacle ( )PAF-6S Retainer PAFS-( )V-S Contact Wire to wire Connectors SPAL-001T-P0.5 SPAL-002T-P0.5 Receptacle housing PALR-( )V(F) Retainer PMS-( )V-S Specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– PA Connector (Standard type) PAF Connector • Current rating: 3A AC, DC (AWG#22) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: AWG #28 to #22 • Applicable PC board thickness: 1.6mm(.063") • Current rating: 1.0A AC, DC (AWG#26) • Voltage rating: 100V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/15m Ω max. After environmental testing/25m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: UL1061(Contact JST for details regarding other UL wires.) AWG #26 Conductor/7 strands, tin-coated annealed copper Insulation O.D./0.9 to 1.0mm(.035" to .039") PA Connector (Retainer mountable type) • Current rating: 3A AC, DC (AWG#22) • Voltage rating: 100V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/15m Ω max. After environmental testing/25m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: AWG #28 to #22 62 PAL Connector • Current rating: 3A AC, DC (AWG#22) • Voltage rating: 100V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/15m Ω max. After environmental testing/25m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: AWG #28 to #22 • Applicable panel thickness : 0.5 to 2.0mm(.020" to .079") PA FAMILY SERIES /PA CONNECTOR (Crimp style Standard type) Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– 1.5(.059) Model No. mm2 SPHD-001T-P0.5 SPHD-002T-P0.5 Applicable wire Insulation O.D. mm(in.) AWG # 0.13 to 0.33 26 to 22 1.0 to 1.5(.039 to .059) 0.08 to 0.21 28 to 24 0.9 to 1.5(.035 to .059) Q'ty / reel 8,000 Material and Finish 6.5(.256) Phosphor bronze, tin-plated 2.85(.112) 1.3(.051) Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– (2 to 9 circuits) B [2.0(.079)] 2.0(.079) 8.0(.315) 5.8(.228) 4.6(.181) 7.3(.287) A Circuit No.1 (10 to 15 circuits) B [2.0(.079)] 2.0(.079) 5.8(.228) Model No. 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 PAP-02V-S PAP-03V-S PAP-04V-S PAP-05V-S PAP-06V-S PAP-07V-S PAP-08V-S PAP-09V-S PAP-10V-S PAP-11V-S PAP-12V-S PAP-13V-S PAP-14V-S PAP-15V-S PAP-16V-S 8.0(.315) 4.6(.181) 7.3(.287) A Circuits Dimensions mm(in.) A B 2.0( .079) 6.0( .236) 4.0( .157) 8.0( .315) 6.0( .236) 10.0( .394) 8.0( .315) 12.0( .472) 10.0( .394) 14.0( .551) 12.0( .472) 16.0( .630) 14.0( .551) 18.0( .709) 16.0( .630) 20.0( .787) 18.0( .709) 22.0( .866) 20.0( .787) 24.0( .945) 22.0( .866) 26.0(1.024) 24.0( .945) 28.0(1.102) 26.0(1.024) 30.0(1.181) 28.0(1.102) 32.0(1.260) 30.0(1.181) 34.0(1.339) Q'ty / bag 5,000 5,000 5,000 5,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 Material Nylon 66, UL94V-0, natural (white) Circuit No.1 (16 circuits) B [2.0(.079)] 2.0(.079) 5.8(.228) 4.6(.181) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 8.0(.315) ex. 7.3(.287) A PAP-02V-SS…natural (white) K…black R…red E…blue M…green O…orange N…brown P…purple PK…pink Y…yellow L…lemon yellow FY…vivid yellow LE…light blue H…gray TR…tomato red Circuit No.1 63 PA FAMILY SERIES /PA CONNECTOR (Crimp style Standard type) Through-hole type shrouded header ––––––––––––––––––––––––––––––––––––––––– Circuits 2 (Note1) 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Top entry type (2 to 9 circuits) B A 5.3(.209) 5.9(.232) 1.2(.047) 3.0 7.7(.303) (.118) Circuit No.1 0.8(.031)dia. 0.5(.020) 2.0 (.079) 1.7(.067) 1.5(.059) Model No. With a boss Without a boss B02B-PAFYK-A B02B-PASK B03B-PASK B04B-PASK B05B-PASK B06B-PASK B07B-PASK B08B-PASK B09B-PASK B10B-PASK B11B-PASK B12B-PASK B13B-PASK B14B-PASK B15B-PASK B16B-PASK Dimensions mm(in.) A B B02B-PAFYK-1A 2.0( .079) 6.0( .236) B02B-PASK-1 2.0( .079) 6.0( .236) 4.0( .157) B03B-PASK-1 8.0( .315) 6.0( .236) 10.0( .394) B04B-PASK-1 8.0( .315) 12.0( .472) B05B-PASK-1 B06B-PASK-1 10.0( .394) 14.0( .551) B07B-PASK-1 12.0( .472) 16.0( .630) B08B-PASK-1 14.0( .551) 18.0( .709) B09B-PASK-1 16.0( .630) 20.0( .787) B10B-PASK-1 18.0( .709) 22.0( .866) B11B-PASK-1 20.0( .787) 24.0( .945) B12B-PASK-1 22.0( .866) 26.0(1.024) B13B-PASK-1 24.0( .945) 28.0(1.102) B14B-PASK-1 26.0(1.024) 30.0(1.181) B15B-PASK-1 28.0(1.102) 32.0(1.260) B16B-PASK-1 30.0(1.181) 34.0(1.339) Q'ty / box 1,000 1,000 1,000 1,000 500 500 500 500 500 500 250 250 250 250 250 250 Material and Finish (10 to 15 circuits) Post: Copper alloy, copper-undercoated, tin/lead-plated Wafer: Glass-filled PBT, UL94V-0, natural (white) (Note1) Nylon 66, UL94V-0, vivid yellow B A 0.5(.020) 2.0 (.079) 5.3(.209) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 5.9(.232) 1.2(.047) 3.0 7.7(.303) (.118) Circuit No.1 ex. 0.8(.031)dia. 1.5(.059) 1.7(.067) (16 circuits) B A Circuit No.1 0.5(.020) 2.0 (.079) 64 0.8(.031)dia. 1.5(.059) 5.9(.232) 1.2(.047) 3.0 7.7(.303) (.118) 5.3(.209) 1.7(.067) B02B-PASKS…natural (white) K…black R…red E…blue M…green O…orange N…brown P…purple PK…pink Y…yellow L…lemon yellow FY…vivid yellow LE…light blue H…gray TR…tomato red PA FAMILY SERIES /PA CONNECTOR (Crimp style Standard type) Through-hole type shrouded header ––––––––––––––––––––––––––––––––––––––––– Side entry type (2 to 9 circuits) B A 6.5(.256) 6.1(.240) [3.4(.134)] 8.2(.323) 11.7(.461) 5.9(.232) 7.7(.303) 2.0(.079) Circuit No.1 Circuits Model No. 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 S02B-PASK-2 S03B-PASK-2 S04B-PASK-2 S05B-PASK-2 S06B-PASK-2 S07B-PASK-2 S08B-PASK-2 S09B-PASK-2 S10B-PASK-2 S11B-PASK-2 S12B-PASK-2 S13B-PASK-2 S14B-PASK-2 S15B-PASK-2 S16B-PASK-2 Dimensions mm(in.) A B 2.0( .079) 6.0( .236) 4.0( .157) 8.0( .315) 6.0( .236) 10.0( .394) 8.0( .315) 12.0( .472) 10.0( .394) 14.0( .551) 12.0( .472) 16.0( .630) 14.0( .551) 18.0( .709) 16.0( .630) 20.0( .787) 18.0( .709) 22.0( .866) 20.0( .787) 24.0( .945) 22.0( .866) 26.0(1.024) 24.0( .945) 28.0(1.102) 26.0(1.024) 30.0(1.181) 28.0(1.102) 32.0(1.260) 30.0(1.181) 34.0(1.339) Q'ty / box 1,000 1,000 500 500 500 250 250 250 250 250 250 250 200 200 200 Material and Finish Post: Copper alloy, copper-undercoated, tin/lead-plated Wafer: Glass-filled PBT, UL94V-0, natural (white) (10 to 15 circuits) B A 8.2(.323) 6.1(.240) 5.9(.232) 7.7(.303) [3.4(.134)] As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 11.7(.461) 6.5(.256) 2.0(.079) Circuit No.1 S03B-PASK-2S…natural (white) K…black R…red E…blue M…green O…orange N…brown P…purple PK…pink Y…yellow L…lemon yellow LE…light blue H…gray TR…tomato red (16 circuits) B A 6.1(.240) 5.9(.232) 7.7(.303) [3.4(.134)] 8.2(.323) 11.7(.461) 6.5(.256) 2.0(.079) Circuit No.1 65 PA FAMILY SERIES /PA CONNECTOR (Crimp style Standard type) SMT type shrouded header ––––––––––––––––––––––––––––––––––––––––––––––––– Top entry type (2 to 3 circuits) Side entry type (2 to 3 circuits) B B A A 2.0 (.079) 2.0 (.079) 5.7(.224) 1.8 7.1(.280) (.071) 1.8 7.1(.280) (.071) 5.7(.224) Circuit No.1 Circuit No.1 (4 to 9 circuits) (4 to 9 circuits) B B A A 2.0(.079) 2.0(.079) 5.7(.224) 1.8 7.1(.280) (.071) 1.8 7.1(.280) (.071) 5.7(.224) Circuit No.1 Circuit No.1 (10 to 13 circuits) (10 to 12 circuits) B B A A 2.0(.079) 5.7(.224) 2.0(.079) 1.8 7.1(.280) (.071) 1.8 7.1(.280) (.071) 5.7(.224) Circuit No.1 Circuit No.1 Top entry type Side entry type Model No. Dimensions mm(in.) Model No. Dimensions mm(in.) A B Q'ty / reel SM02B-PASS-1-(*) 2.0(.079) 8.0( .315) 1,000 SM03B-PASS-1-(*) 4.0(.157) 10.0( .394) 1,000 SM04B-PASS-(*) SM04B-PASS-1-(*) 6.0(.236) 12.0( .472) 1,000 5 SM05B-PASS-(*) SM05B-PASS-1-(*) 8.0(.315) 14.0( .551) 1,000 500 6 SM06B-PASS-(*) SM06B-PASS-1-(*) 10.0(.394) 16.0( .630) 1,000 12.0(.472) 18.0( .709) 500 7 SM07B-PASS-(*) SM07B-PASS-1-(*) 12.0(.472) 18.0( .709) 1,000 BM08B-PASS-1-(*) 14.0(.551) 20.0( .787) 500 8 SM08B-PASS-(*) SM08B-PASS-1-(*) 14.0(.551) 20.0( .787) 1,000 BM09B-PASS-(*) BM09B-PASS-1-(*) 16.0(.630) 22.0( .866) 500 9 SM09B-PASS-(*) SM09B-PASS-1-(*) 16.0(.630) 22.0( .866) 1,000 10 BM10B-PASS-(*) BM10B-PASS-1-(*) 18.0(.709) 24.0( .945) 500 10 SM10B-PASS-(*) SM10B-PASS-1-(*) 18.0(.709) 24.0( .945) 1,000 11 BM11B-PASS-(*) BM11B-PASS-1-(*) 20.0(.787) 26.0(1.024) 500 11 SM11B-PASS-(*) SM11B-PASS-1-(*) 20.0(.787) 26.0(1.024) 1,000 12 BM12B-PASS-(*) BM12B-PASS-1-(*) 22.0(.866) 28.0(1.102) 500 12 SM12B-PASS-(*) SM12B-PASS-1-(*) 22.0(.866) 28.0(1.102) 1,000 13 BM13B-PASS-(*) BM13B-PASS-1-(*) 24.0(.945) 30.0(1.181) 500 Circuits Without a boss With a boss A B 2 BM02B-PASS-(*) BM02B-PASS-1-(*) 2.0(.079) 8.0( .315) 500 3 BM03B-PASS-(*) BM03B-PASS-1-(*) 4.0(.157) 10.0( .394) 500 4 BM04B-PASS-(*) BM04B-PASS-1-(*) 6.0(.236) 12.0( .472) 5 BM05B-PASS-(*) BM05B-PASS-1-(*) 6 BM06B-PASS-(*) 7 Circuits Without a boss With a boss 2 SM02B-PASS-(*) 3 SM03B-PASS-(*) 500 4 8.0(.315) 14.0( .551) 500 BM06B-PASS-1-(*) 10.0(.394) 16.0( .630) BM07B-PASS-(*) BM07B-PASS-1-(*) 8 BM08B-PASS-(*) 9 Material and Finish Post: Brass, copper-undercoated, tin-plated Wafer: Polyamide resin, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated Note: 1. (*): TF…taping product TFT…taping product with suction tape. 2. BM13B-PASS-(*) and BM13B-PASS-1-(*) are not UL/CSA approved. 66 Q'ty / reel Material and Finish Post: Brass, copper-undercoated, tin-plated Wafer: Polyamide resin, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated Note: (*): TB…taping product TBT…taping product with suction tape. PA FAMILY SERIES /PA CONNECTOR (Crimp style Standard type) Taping specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––– Feeding direction 380±2.0(14.961±.079)dia. Feeding direction W1 +- 2.5 1.0 ( +- .098 .039 ) Cover tape leader Leader part 100(3.937)min. The end part Connector 160(6.299)min. mounting part 400(15.748)min. 2.0±0.5(.079±.020) Top entry type (2 to 5 circuits) 1.75±0.1 (.069±.004) (6 to 13 circuits) Feeding direction Carrier tape F±0.1(.004) 1.55±0.05 4.0±0.1 (.157±.004) (.061±.002)dia. 2.9±0.1 (.114±.004) 1.55±0.05 4.0±0.1 (.157±.004) (.061±.002)dia. 2.9±0.1 (.114±.004) 1.75±0.1 (.069±.004) Feeding direction S±0.1(.004) F±0.1(.004) W±0.3(.012) Cover tape Carrier tape Cover tape W±0.3(.012) [13(.512)dia.] Carrier tape 16.0±0.1 (.630±.004) 16.0±0.1 (.630±.004) Side entry type (2 to 5 circuits) Feeding direction Cover tape Carrier tape S±0.1(.004) W±0.3(.012) F±0.1(.004) Cover tape Carrier tape W±0.3(.012) 1.55±0.05 2.0±0.1 (.079±.004) (.061±.002)dia. 1.55±0.05 2.0±0.1 (.079±.004) (.061±.002)dia. F±0.1(.004) 4.0±0.1 (.157±.004) 4.0±0.1 (.157±.004) 1.75±0.1 (.069±.004) Feeding direction 1.75±0.1 (.069±.004) (6 to 12 circuits) 12.0±0.1 (.472±.004) 12.0±0.1 (.472±.004) Circuits Taping dimensions mm(in.) Reel dimensions mm(in.) Q'ty / reel Top entry type Side entry type F S W W1 11.5(.453) – 24.0( .945) 25.5(1.004) 500 1,000 6, 7 14.2(.559) 28.4(1.118) 32.0(1.260) 33.5(1.319) 500 1,000 8 to 13 20.2(.795) 40.4(1.591) 44.0(1.732) 45.5(1.791) 500 1,000 2 to 5 Note: 1. Specifications conform to JIS C 0806. The tape width, connector loading recess square hole dimensions, etc. are determined by the number of circuits and external shape of the connector to be loaded. 2. Specifications are subject to change without prior notice. 67 PA FAMILY SERIES /PA CONNECTOR (Crimp style Standard type) Shrouded header ––––––––––––––––––––––––––––––––––––––––––– 7.1(.280) 5.3(.209) (5, 6 circuits) B A 2.0 (.079) 7.1(.280) 5.3(.209) 3.0 13.9(.547) (.118) B A 3.0 13.9(.547) (.118) (2 circuits) Circuit No.1 Circuit No.1 (7 to 9 circuits) B A 7.1(.280) 5.3(.209) 7.1(.280) 5.3(.209) 3.0 13.9(.547) (.118) 2.0 (.079) B A 2.0 (.079) 3.0 13.9(.547) (.118) (3 circuits) Circuit No.1 Circuit No.1 (4 circuits) (10 to 12, 15 circuits) B A 2.0 (.079) 7.1(.280) 5.3(.209) B A 7.1(.280) 5.3(.209) 3.0 13.9(.547) (.118) 3.0 13.9(.547) (.118) 2.0 (.079) Circuit No.1 Circuit No.1 Model No. Dimensions mm(in.) Without a boss With a boss A B Q'ty / box 2 BH02B-PASK BH02B-PASK-1 2.0( .079) 6.0( .236) 900 3 BH03B-PASK BH03B-PASK-1 4.0( .157) 8.0( .315) 675 4 BH04B-PASK BH04B-PASK-1 6.0( .236) 10.0( .394) 550 5 BH05B-PASK BH05B-PASK-1 8.0( .315) 12.0( .472) 450 6 BH06B-PASK BH06B-PASK-1 10.0( .394) 14.0( .551) 375 7 BH07B-PASK BH07B-PASK-1 12.0( .472) 16.0( .630) 325 8 BH08B-PASK BH08B-PASK-1 14.0( .551) 18.0( .709) 300 9 BH09B-PASK BH09B-PASK-1 16.0( .630) 20.0( .787) 275 10 BH10B-PASK BH10B-PASK-1 18.0( .709) 22.0( .866) 250 11 BH11B-PASK BH11B-PASK-1 20.0( .787) 24.0( .945) 225 12 BH12B-PASK BH12B-PASK-1 22.0( .866) 26.0(1.024) 200 15 BH15B-PASK BH15B-PASK-1 28.0(1.102) 32.0(1.260) 150 Circuits Material and Finish Post: Copper alloy, copper-undercoated, tin/lead-plated Wafer: Glass-filled PBT, UL94V-0, natural (white) 68 PA FAMILY SERIES /PA CONNECTOR (Crimp style Retainer mountable type) Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– 1.5 (.059) Model No. SPA-001T-P0.5 mm2 0.13 to 0.33 Applicable wire Insulation O.D. mm(in.) AWG # 26 to 22 0.9 to 1.5(.035 to .059) Q'ty / reel 10,000 Material and Finish Phosphor bronze, tin-plated 8.4(.331) 2.85(.112) 2.2 (.087) 1.3 (.051) Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– (2 circuits) B Q'ty / bag PARP-02V 2.0( .079) 5.4( .213) 1,000 PARP-03V 4.0( .157) 7.4( .291) 1,000 4 PARP-04V 6.0( .236) 9.4( .370) 1,000 5 PARP-05V 8.0( .315) 11.4( .449) 1,000 6 PARP-06V 10.0( .394) 14.0( .551) 1,000 7 PARP-07V 12.0( .472) 16.0( .630) 1,000 8 PARP-08V 14.0( .551) 18.0( .709) 1,000 9 PARP-09V 16.0( .630) 20.0( .787) 1,000 10 PARP-10V 18.0( .709) 22.0( .866) 1,000 15 PARP-15V 28.0(1.102) 32.0(1.260) 500 Model No. 2 3 (3 circuits) B A B A 7.2(.283) 7.2(.283) 11.4(.449) 11.4(.449) 2.0(.079) Circuit No.1 Circuit No.1 (4 circuits) (5 circuits) B A B A 7.2(.283) 7.2(.283) 11.4(.449) 11.4(.449) Nylon 66, UL94V-0, natural (white) Circuit No.1 Note: PARP-15V is not CSA approved. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. Circuit No.1 (6 to 9 circuits) B A Material 2.0(.079) 2.0(.079) ex. (10, 15 circuits) B A 7.2(.283) 7.2(.283) PARP-02V-oo(blank)…natural (white) R…red E…blue Y…yellow M…green 2.0(.079) 11.4(.449) 11.4(.449) 2.0(.079) Dimensions mm(in.) A Circuits Circuit No.1 Circuit No.1 69 PA FAMILY SERIES /PA CONNECTOR (Crimp style Retainer mountable type) Retainer ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– (6 to 15 circuits) B A 2.4(.094) 1.5(.059) 2.4 (.094) 3.1 (.122) 7.0(.276) 2.85 (.112) 1.5(.059) 7.0(.276) Dimensions mm(in.) A B Q'ty / bag PMS-02V-S 2.0( .079) 7.3( .287) 1,000 PMS-03V-S 4.0( .157) 9.3( .366) 1,000 4 PMS-04V-S 6.0( .236) 11.3( .445) 1,000 5 PMS-05V-S 8.0( .315) 13.3( .524) 1,000 6 PMS-06V-S 10.0( .394) 11.55( .455) 1,000 7 PMS-07V-S 12.0( .472) 13.55( .533) 1,000 8 PMS-08V-S 14.0( .551) 15.55( .612) 1,000 9 PMS-09V-S 16.0( .630) 17.55( .691) 1,000 10 PMS-10V-S 18.0( .709) 19.55( .770) 1,000 15 PMS-15V-S 28.0(1.102) 29.55(1.163) 1,000 Circuits Model No. 2 3 B A 2.0(.079) 2.0(.079) (2 to 5 circuits) Material Glass-filled nylon 66, UL94V-0, natural (ivory) Note: PMS-09V-S, PMS-10V-S and PMS-15V-S are not CSA approved. 70 PA FAMILY SERIES /PAF CONNECTOR (Insulation displacement type) Receptacle –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits 2.0(.079) Q'ty / box 02PAF-6S 2.0( .079) 6.0( .236) 1,000 03PAF-6S 4.0( .157) 8.0( .315) 1,000 4 04PAF-6S 6.0( .236) 10.0( .394) 500 5 05PAF-6S 8.0( .315) 12.0( .472) 500 6 06PAF-6S 10.0( .394) 14.0( .551) 500 7 07PAF-6S 12.0( .472) 16.0( .630) 500 8 08PAF-6S 14.0( .551) 18.0( .709) 250 9 09PAF-6S 16.0( .630) 20.0( .787) 250 10 10PAF-6S 18.0( .709) 22.0( .866) 250 11 11PAF-6S 20.0( .787) 24.0( .945) 250 12 12PAF-6S 22.0( .866) 26.0(1.024) 250 13 13PAF-6S 24.0( .945) 28.0(1.102) 250 14 14PAF-6S 26.0(1.024) 30.0(1.181) 250 15 15PAF-6S 28.0(1.102) 32.0(1.260) 250 3.1(.122) 2.0(.079) 5.1(.201) B 3 13.0(.512) 8.0(.315) Circuit No.1 A 2 B A Dimensions mm(in.) Model No. Material and Finish C o n t a c t : Phosphor bronze, tin-plated Housing: Nylon 66, UL94V-0, natural (white) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 02PAF-6SS…natural (white) R…red E…blue M…green Y…yellow Retainer ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Model No. Dimensions mm(in.) A B Q'ty / bag 2 PAFS-02V-S 2.0( .079) 7.4( .291) 1,000 3 PAFS-03V-S 4.0( .157) 9.4( .370) 1,000 4 PAFS-04V-S 6.0( .236) 11.4( .449) 1,000 5 PAFS-05V-S 8.0( .315) 13.4( .528) 1,000 6 PAFS-06V-S 10.0( .394) 15.4( .606) 1,000 7 PAFS-07V-S 12.0( .472) 17.4( .685) 1,000 8 PAFS-08V-S 14.0( .551) 19.4( .764) 1,000 9 PAFS-09V-S 16.0( .630) 21.4( .843) 1,000 10 PAFS-10V-S 18.0( .709) 23.4( .921) 1,000 11 PAFS-11V-S 20.0( .787) 25.4(1.000) 1,000 12 PAFS-12V-S 22.0( .866) 27.4(1.079) 1,000 13 PAFS-13V-S 24.0( .945) 29.4(1.157) 1,000 14 PAFS-14V-S 26.0(1.024) 31.4(1.236) 1,000 15 PAFS-15V-S 28.0(1.102) 33.4(1.315) 1,000 A B 2.0 (.079) Circuits 4.1(.161) 8.9(.350) Material Glass-filled nylon 66, UL94V-0, natural (ivory) Note: PAFS-09V-S, PAFS-10V-S, PAFS-11V-S, PAFS-12V-S, PAFS-13V-S, PAFS-14V-S and PAFS-15V-S are not UL/CSA approved. 71 PA FAMILY SERIES /PAL CONNECTOR (Wire-to-wire type) Model No. 1.6(.063) 0.5(.020) Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– SPAL-001T-P0.5 SPAL-002T-P0.5 Applicable wire Insulation O.D. mm(in.) AWG # mm2 0.13 to 0.33 26 to 22 1.0 to 1.5(.039 to .059) 0.08 to 0.21 28 to 24 0.9 to 1.5(.035 to .059) Q'ty / reel 10,000 Material and Finish 12.8(.504) Phosphor bronze, tin-plated 2.4(.094) 0.5(.020) 2.85(.112) 1.3(.051) Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Without panel locks Circuits Circuits (2 to 5 circuits) 3.7(.146) 6.3(.248) 3.4(.134) B A 2.0(.079) 20.0(.787) 20.0(.787) A 2.0(.079) 4.7 (.185) Circuit No.1 3.7(.146) AA 4.4 (.173) Circuit No.1 Q'ty Q'ty // bag bag BB 2 PARP-02V PALR-02VF 2.0( .079) 2.0 (.079) 5.4( .213) 9.4 (.370) 1,000 1,000 3 PARP-03V PALR-03VF 4.0( .157) 4.0 (.157) 7.4( (.449) .291) 11.4 1,000 1,000 4 PARP-04V PALR-04VF 6.0( .236) 6.0 (.236) 9.4( (.528) .370) 13.4 1,000 1,000 5 PARP-05V PALR-05VF 8.0( .315) 8.0 (.315) 11.4( .449) 15.4 (.606) 1,000 1,000 6 PARP-06V PALR-06VF 10.0( .394) 10.0 (.394) 14.0( .551) 17.4 (.685) 1,000 1,000 7 PARP-07V PALR-07VF 12.0( .472) 12.0 (.472) 16.0( .630) 19.4 (.764) 1,000 1,000 8 PARP-08V PALR-08VF 14.0( .551) 14.0 (.551) 18.0( .709) 21.4 (.843) 1,000 1,000 9 PARP-09V 16.0( .630) 20.0( .787) 1,000 10 PARP-10V 18.0( .709) 22.0( .866) 1,000 15 PARP-15V 32.0(1.260) 28.0(1.102) Nylon 66, UL94V-0, natural (white) 500 6.3(.248) 3.4(.134) 11.2(.441) B Dimensions Dimensions mm(in.) mm(in.) Model Model No. No. (6 to 8 circuits) Material Material With panel locks Circuits Model No. (2 to 4 circuits) 1.0 (.039) 20.0(.787) 4.0(.157) 4.6±0.05(.181±.002) 6.3 (.248) 3.4 (.134) 3.25(.128) +.004 6.5 +0.1 0 (.256 0 ) 3.2(.126) B A 3.7(.146) 2.0(.079) B C D Q'ty / bag 2 PALR-02V 2.0(.079) 9.8(.386) 13.4( .528) 1,000 3 PALR-03V 4.0(.157) 11.4(.449) 11.8(.465) 15.4( .606) 1,000 4 PALR-04V 6.0(.236) 13.4(.528) 13.8(.543) 17.4( .685) 1,000 6 PALR-06V 10.0(.394) 17.4(.685) 19.8(.780) 21.4( .843) 1,000 7 PALR-07V 12.0(.472) 19.4(.764) 21.8(.858) 23.4( .921) 1,000 8 PALR-08V 14.0(.551) 21.4(.843) 23.8(.937) 25.4(1.000) 1,000 9.4(.370) Material +.004 C+0.1 0 ( 0 ) D±0.1(.004) Circuit No.1 Dimensions mm(in.) A Nylon 66, UL94V-0, natural (white) (6 to 8 circuits) 6.3(.248) 3.4(.134) 5.15 (.203) Circuit No.1 1.6(.063) 4.4 (.173) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. +.004 6.5 +0.1 0 (.256 0 ) 5.1±0.05(.201±.002) 3.2(.126) 3.7(.146) 5.8(.228) 20.0(.787) B A 2.0(.079) ex. PALR-02V(F)-oo(blank)…natural (white) R…red E…blue M…green Y…yellow +.004 C+0.1 0 ( 0 ) D±0.1(.004) Retainer ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Retainers are interchangeable with those of the PA crimp style retainer mountable type. 72 PA FAMILY SERIES /PA•PAF•PAL CONNECTOR PC board layout (viewed from component side) and Assembly layout –––––––––––––––––– Through-hole type Top entry type [5.8(.228)] 7.2(.283) 1.5±0.05(.059±.002) +0.1 1.7±0.05(.067±.002) +0.1 0.7 0 +.004 (.028 0 )dia. 9.8(.386) 1.0 0 +.004 (.039 0 )dia. 2.0±0.05(.079±.002) PA Receptacle + PA Header (Standard type) [14.9(.587)] A±0.05(.002) [14.7(.579)](retainer included) 5.8(.228) PA Receptacle + PA Header (Retainer mountable type) PAF Receptacle + PA Header Side entry type A±0.05(.002) 1.5±0.05 (.059±.002) [18.8(.740)](retainer included) 13.8(.543) [18.9(.744)] +0.1 0.7 0 +.004 (.028 0 )dia. 8.2(.323) 8.2(.323) [7.0(.276)] 7.0(.276) 2.0±0.05 (.079±.002) 2.1±0.05 (.083±.002) 1.1 +.004 (.043 0 )dia. [8.4(.331)] +0.1 0 8.2(.323) PA Receptacle + PA side entry PA Receptacle + PA side entry type type header (Standard type) header (Retainer mountable type) PAF Receptacle + PA side entry type header Note: 1. Tolerances are non-cumulative: ±0.05mm (±.002") for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. SMT type Top entry type [7.6(.299)] 4.9±0.1 (.193±.004) Connector outline 2.2±0.05(.087±.002) 0.8 + 00.1 (.031 +.004 0 )dia. 3.6±0.1 (.142±.004) 5.0±0.1 2.9 (.197±.004)(.114)min. 0.4+ 00.1(.016 +.004 0 )R 2.0±0.05 (.079±.002) [1.4(.055)] [16.2(.638)] 1.7±0.1 A±0.1 (.067±.004) (.004) 1.0(.039)min. 11.1(.437) 1.0±0.1 (.039±.004) [6.2(.244)] [1.4(.055)] [16.0(.630)](retainer included) [6.2(.244)] [1.4(.055)] 1.8±0.1(.071±.004) 1.45±0.1(.057±.004) PA Receptacle + PA Header (Standard type) PA Receptacle + PA Header (Retainer mountable type) PAF Receptacle + PA Header Note: 1. Tolerances are non-cumulative: ±0.05mm (±.002") for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. 73 PA FAMILY SERIES /PA•PAF•PAL CONNECTOR PC board layout (viewed from component side) and Assembly layout –––––––––––––––––– SMT type Side entry type 1.0±0.1 (.039±.004) Connector outline 1.7±0.1(.067±.004) PA Receptacle + PA side entry type header (SMT) (Standard type) [7.6(.299)] [1.1(.043)] [16.2(.638)] 8.9(.350) [6.2(.244)] [16.0(.630)](retainer included) 8.9(.350) 5.7(.224) 0.8+ 00.1(.031+.004 0 )dia. 2.2±0.05(.087±.002) [1.1(.043)] 11.1(.437) 8.9(.350) 5.7(.224) )R [1.1(.043)] [6.2(.244)] 0.4 (.016 1.8±0.1(.071±.004) 5.7(.224) + 0.1 0 +.004 0 1.45±0.1(.057±.004) 3.8±0.1 2.8 (.150±.004) (.110) 7.95±0.1 (.313±.004) 2.7 7.8±0.1(.307±.004) (.106)min A±0.1(.004) 2.0±0.05(.079±.002) 1.0(.039)min. PA Receptacle + PA side entry type header (SMT) (Retainer mountable type) PAF Receptacle + PA side entry type header (SMT) 7.2(.283) 7.1(.280) High box type A±0.05(.002) +0.1 1.1 0 +.004 (.043 0 )dia. 1.7±0.05 (.067±.002) 0.7 +.004 (.028 0 )dia. 1.5±0.05 (.059±.002) 2.0±0.05 (.079±.002) 15.9(.626) +0.1 0 PA Receptacle + PA high box type header (Standard type) PA Receptacle + PA high box type header (Retainer mountable type) 20.9(.823) [20.7(.815)](retainer included) 7.1(.280) PAF Receptacle + PA high box type header Note: 1. Tolerances are non-cumulative: ±0.05mm (±.002") for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Assembly layout –––––––––––––––––––––––––––––––––––––––––––––––––––––––––– [25.8(1.016)](retainer included) [8.9(.350)] (retainer included) [8.4(.331)] (retainer included) PA Receptacle + PAL Receptacle (Standard type) 74 [26.0(1.024)](retainer included) PA Receptacle + PAL Receptacle (Retainer mountable type) [7.6(.299)] (retainer included) [21.5(.846)](retainer included) PAF Receptacle + PAL Receptacle PA FAMILY SERIES /PA•PAF•PAL CONNECTOR Applicator for the semi-automatic press AP-K2N ––––––––––––––––––––––––––––––– Contact SPHD-001T-P0.5 SPHD-002T-P0.5 SPA-001T-P0.5 SPAL-001T-P0.5 SPAL-002T-P0.5 Crimp applicator MKS-L(-10) with safety cover without safety cover Compact crimp applicator MKS-LS-10 with safety cover without safety cover Strip-crimp applicator MKS-SC-10 with safety cover APLMK SPHD001-05 APLNC SPHD001-05 APLMKLS SPHD001-05 APLLSNC SPHD001-05 APLSC SPHD001-05 APLMK SPHD002-05 APLNC SPHD002-05 APLMKLS SPHD002-05 APLLSNC SPHD002-05 APLSC SPHD002-05 APLMK SPA001-05 APLNC SPA001-05 – – – APLMK SPAL001-05 APLNC SPAL001-05 – – – APLMK SPAL002-05 APLNC SPAL002-05 – – – 75
B07B-PASK
物料型号:JST品牌的PA系列连接器,包括PA、PAF和PAL型号。
器件简介: - PA系列连接器具有防意外脱落的锁定装置,增强了安全性。 - 支持压接和IDC(绝缘位移)两种插座,使用相同的端子和配对组件。 - 提供了额外的锁定装置,以增强在部分插入或意外释放接触时的安全性。 - PAL型号支持2.0mm(.079")间距的线对线压接式连接器,增加了线束的多样性。
引脚分配:文档中提供了不同型号连接器的引脚分配和组合方式,包括顶入式和侧入式,以及压接式和IDC式。
参数特性: - 工作电流:PA和PAL连接器为3A,PAF连接器为1.0A。 - 电压等级:PA为250V,PAF和PAL为100V。 - 工作温度范围:-25°C至+85°C。 - 接触电阻和绝缘电阻:初始值和环境测试后的最大值。 - 耐电压:800V AC/分钟。
功能详解: - PAF连接器是业界首个具有安全锁定机制的IDC连接器。 - PAL连接器是业界首个支持线对线连接的2.0mm间距连接器。 - 提供了插入引导机制,便于插入。 - 某些型号的连接器提供了带法兰的压针,防止因变形而意外脱落。
应用信息:适用于需要复杂线束配置的应用,如汽车、工业设备等。
封装信息:提供了不同型号连接器的尺寸、材料和表面处理信息,如磷青铜镀锡的接触件,尼龙66材质的外壳等。
B07B-PASK 价格&库存
很抱歉,暂时无法提供与“B07B-PASK”相匹配的价格&库存,您可以联系我们找货
B07B-PASK
    • 100+1.14700
    库存:9078
    B07B-PASK
      库存:10290
      B07B-PASK
        • 10+0.93060
        • 500+0.84700
        库存:3530
        B07B-PASK
        • 1+3.802201+0.49188
        • 10+3.2233310+0.41699
        • 100+2.74068100+0.35455
        • 500+2.44550500+0.31637
        • 1000+2.328741000+0.30126
        • 5000+2.078635000+0.26891
        • 10000+1.9794210000+0.25607
        库存:381
        B07B-PASK
          • 500+1.02770
          库存:500
